Securing Conduit
riveteddragon(at)gmail.co
PostPosted: Mon Nov 23, 2015 2:15 pm    Post subject: Securing Conduit Reply with quote
When running conduit through lightening holes (generally much bigger than the conduit diameter), what have people used to secure it? RTV? Make brackets and clamps? Just leave them free to flop?
Steven DeFord
flying-nut(at)cfl.rr.com
PostPosted: Mon Nov 23, 2015 2:35 pm    Post subject: Securing Conduit Reply with quote
I would not let them flop. I used 1/2" Sched. 40 (thin wall) PVC pipe
and plastic 'hangars' made to hold the pipe under a ceiling joist ...
picture the pipe clamp with vertical 'ears'. I riveted the pipe hangar
to the side of the larger lightening hole. The plastic clamp has to be
spread out to fit around the PVC pipe .... I tried the ribbed plastic
conduit and just couldn't make it work for me .... all of it ended up in
the recycle bin ..... and the smooth PVC pipe makes running more wires
really easy.
Linn
Steven DeFord
cooprv7(at)yahoo.com
PostPosted: Mon Nov 23, 2015 2:36 pm    Post subject: Securing Conduit Reply with quote
I drilled two opposing holes across the lightening hole and used safety wire to trap the conduit in the center. Just did enough ribs to keep it reasonably secure.
Marcus
On Nov 23, 2015, at 5:11 PM, Steven DeFord <riveteddragon(at)gmail.com> wrote:
Steven DeFord
rleffler
If you use the black conduit from Van's, just enlarge the small hole in the rib to 3/4" and th conduit will stay in place just fine. Much easier than attempting to secure it in the lightening holes.
Steven DeFord
Bob Leffler
N410BL - Phase I
http://mykitlog.com/rleffler
carl.froehlich(at)verizon
PostPosted: Mon Nov 23, 2015 4:00 pm    Post subject: Securing Conduit Reply with quote
If you are talking about the lighting holes in the side fuselage, you can
get a rubber grommet that fits it just right - and the ID provides a good
friction fit for the conduit (I got mine from Stein Air
http://www.steinair.com/store.cfm?tlcatid=14 ). For under the rear floor I
make a strap. For new holes, as Bob says make the hole small enough to be a
friction fit for the conduit. Do not make the turns too tight so you can
use a string to run wires.
I ran three conduits on each side and ended up filling five of them.
Carl
 Filesize:  109.05 KB
 Viewed:  3860 Time(s)
 Filesize:  132.54 KB
jmjones2000(at)mindspring
PostPosted: Mon Nov 23, 2015 4:18 pm    Post subject: Securing Conduit Reply with quote
I used a small piece of angle riveted to the rib, then used an Adel clamp to clamp the conduit to the angle.
Steven DeFord
rene(at)felker.com
PostPosted: Mon Nov 23, 2015 4:33 pm    Post subject: Securing Conduit Reply with quote
I think I got this from Vans.
Small hole in the rib and a wire tie to hold the conduit down.
Rene'
801-721-6080
Mauledriver(at)nc.rr.com
PostPosted: Mon Nov 23, 2015 8:49 pm    Post subject: Securing Conduit Reply with quote
Try Googling "cable tie bulkhead hole mount"
Specifically it turned up something called a "Panduit LHMS-xnn-xnn". I
used a couple dozen of something very similar to support both conduit
and insulated wire bundles going thru lightening holes. Very handy item
The challenge is finding someone who sells it in small quantities. I
used to use TerminalTown.com but they seem to have closed up shop.
Steven DeFord
glastar(at)gmx.net
PostPosted: Mon Nov 23, 2015 11:14 pm    Post subject: Securing Conduit Reply with quote
Steve,
I used some clamps mounted either on an L shaped alu angle or on a strip of scrap alu
[img]cid:part1.01050800.05050504(at)gmx.net[/img]
--> RV10-List message posted by: Steven DeFord <riveteddragon(at)gmail.com> (riveteddragon(at)gmail.com)
 Filesize:  2.3 MB
 Viewed:  3848 Time(s)
