jmjones2000(at)mindspring Guest
Posted: Thu Nov 12, 2015 4:57 pm Post subject: Stratux Build |
For those of you looking for an inexpensive solution for an ADS-B in (with AHRS if desired), this appears to be a relatively easy project. I am going to tackle it early next month.
The website has step-by-step instructions and a list of exact parts to purchase.
https://github.com/ssokol/stratux/wiki/Stratux-Beginner's-Guide
markdonahue
Joined: 16 Dec 2012 Posts: 16 Location: bainbridge island washington
Posted: Thu Nov 12, 2015 5:15 pm Post subject: Stratux Build |
Would love to hear how your project works out and how difficult it is (was)
to get it put together an place in service.
Mark Donahue
_________________ Mark Donahue |
n992dn(at)gmail.com Guest
Posted: Thu Nov 12, 2015 5:40 pm Post subject: Stratux Build |
Me too
Would like to hear the progress, interesting......
Nati Niv
On Thu, Nov 12, 2015 at 7:14 PM, Mark Donahue <marktdonahue(at)comcast.net (marktdonahue(at)comcast.net)> wrote:
[quote]--> AeroElectric-List message posted by: "Mark Donahue" <marktdonahue(at)comcast.net (marktdonahue(at)comcast.net)>
Mark Donahue
yellowduckduo(at)gmail.co Guest
Posted: Thu Nov 12, 2015 5:59 pm Post subject: Stratux Build |
I bought the exact items except the (battery) and it seems to work fine.
I use fltplango (it's free) on an ipad.
To my surprise there were no tricks or hassles involved. Anyone who can
type on this list and download a program should have no problem.
My only reservation is that it is one more thing to distract me from
looking outside...
Ken
On 12/11/2015 7:55 PM, Justin Jones wrote:
deej(at)deej.net Guest
Posted: Thu Nov 12, 2015 6:02 pm Post subject: Stratux Build |
On 11/12/2015 7:55 PM, Justin Jones wrote:
| Quote: | For those of you looking for an inexpensive solution for an ADS-B in (with AHRS if desired), this appears to be a relatively easy project. I am going to tackle it early next month.
It is very easy. I gathered the parts together and assembled it inside
a 3D printed case during one of our EAA meetings.
I had a chance to fly with it a couple of weeks ago, and the
iPad/Stratux/WingX combination saw the same ADS-B traffic as the
SkyRadar/GRT-HX combination.
There is a beginners guide here:
The 3D case files can be found at:
http://www.thingiverse.com/thing:1019324
-Dj
Dj Merrill - N1JOV - EAA Chapter 87
Sportsman 2+2 Builder #7118 N421DJ - http://deej.net/sportsman/
Glastar Flyer N866RH - http://deej.net/glastar/
bbradburry(at)verizon.net Guest
Posted: Fri Nov 13, 2015 8:48 am Post subject: Stratux Build |
As I understand it, this device is an ADS-B in only. Aren't we going to
need ADS-B out as well??
Posted: Fri Nov 13, 2015 8:57 am Post subject: Stratux Build |
On 11/13/2015 11:47 AM, Bill Bradburry wrote:
| Quote: | As I understand it, this device is an ADS-B in only. Aren't we going to
Correct, as of Jan 2020.
-Dj
Posted: Fri Nov 13, 2015 9:04 am Post subject: Stratux Build |
Yes, but there are some less expensive "out" options you could combine with the Stratux to wind up with a low cost overall solution.
[quote] On Nov 13, 2015, at 11:47 AM, "Bill Bradburry" <bbradburry(at)verizon.net> wrote:
Posted: Fri Nov 13, 2015 9:22 am Post subject: Stratux Build |
| Quote: | On Nov 14, 2015, at 01:47, Bill Bradburry <bbradburry(at)verizon.net> wrote:
It depends on the type of flying you do. If you fly in uncontrolled airspace under 10k feet and do not enter a mode C ring, then you won't need it. If you do that sort of flying, then you will.
There are guys up here in Alaska without an electrical system, that fly in and out of Lake Hood (Class C and right next to Anchorage international). They will not need the "out" either. Many of them use an iPad and foreflight (or similar) to fly as it requires no aircraft power source.
[quote] --
schmoboy
Posted: Fri Nov 13, 2015 9:46 am Post subject: Stratux Build |
Here's a good link to some videos. Chapter two defines when 978 vs 1090ES.
http://www.freeflightsystems.com/ads-b-university
[quote] Justin Jones <mailto:jmjones2000(at)mindspring.com>
November 13, 2015 at 11:21 AM
> On Nov 14, 2015, at 01:47, Bill Bradburry<bbradburry(at)verizon.net> wrote:
Posted: Fri Nov 13, 2015 10:18 am Post subject: Stratux Build |
What are those options? Can both in and out be combined in one box? Does
the Stratux have an out option?
Posted: Fri Nov 13, 2015 10:37 am Post subject: Stratux Build |
On 11/13/2015 01:16 PM, Bill Bradburry wrote:
| Quote: | What are those options? Can both in and out be combined in one box? Does
Stratux is "IN" only, similar to SkyRadar, Stratus, and a bunch of other
ADS-B receive solutions. It's claim to fame is the extreme low cost and
DIY nature.
There are "IN" and "OUT" solutions in a box. Check out Navworx as one
example.
My installed "OUT" solution is a TT22 transponder with ES (ADS-B Out on
1090 Mhz) coupled to a GNS480 WAAS GPS position source, which at the
time was one of the lowest cost solutions overall, especially if you
already have an acceptable GPS position source.
My "IN" solution is a dual-band SkyRadar ADS-B receiver using USB to
talk to a GRT HX EFIS.
Cost and options are very dependent upon what equipment you already have
in your aircraft that might be usable for part of the ADS-B solution, or
if you are installing everything from scratch.
-Dj
ceengland7(at)gmail.com Guest
Posted: Fri Nov 13, 2015 11:03 am Post subject: Stratux Build |
There are quite a few options that are relatively inexpensive now, and
I'm pretty confident that prices will continue to fall.
A mode S transponder with 'extended squitter' and a 'certified' WAAS GPS
source is one way to get 'out' (1090 mhz), but far from the only way.
The FAA is dancing around allowing uncertified boxes with built-in WAAS
GPS that meet performance criteria to transmit into the 'system'. If
that idea holds up, we should see in/out boxes for well under $2K pretty
soon; possibly a lot cheaper.
In the short term, those of us who don't fly IFR & don't need to
regularly enter Class B/C airspace can get by just fine with in only (or
nothing).
The stratux is in-only, and it's very unlikely it will ever be more than
that.
If you use an Android phone/tablet, there's an even cheaper solution
than the stratux.
With
https://play.google.com/store/apps/details?id=com.ds.avare&hl=en
(free)
and
https://play.google.com/store/apps/details?id=bs.Avare.ADSB.Pro&hl=en
(~$3)
and
http://smile.amazon.com/gp/product/B00P2UOU72?psc=1&redirect=true&ref_=oh_aui_detailpage_o04_s00
(~$22)
and
http://smile.amazon.com/gp/product/B014AQOZSW?psc=1&redirect=true&ref_=oh_aui_detailpage_o04_s00
(~$5)
you can have a fully functional ADSB-in system that can receive both 978
and 1090 mhz data (must be manually selected at this point, but I
wouldn't be surprised to see auto switching implemented sometime soon).
I've got Avare & ADSB on Android running on an old Nexus 7 (original
version). I've used Avare for a couple of years, but haven't had a
chance to fly with the adsb add-on. It does pick up airliners & Mode S
a/c flying in my area, even with me sitting on the ground. Once I'm in
the air, I'll be able to get weather, notams, metars, etc in addition to
(most) traffic. The limit on traffic if you don't have 'out', is that
you're dependent on nearby a/c flying with 'out' to trigger traffic
data, and the traffic they get (basically a donut of airspace around
them) won't exactly match the donut of airspace around you. I can live
with that, since I've been living with less since I started flying.
Charlie
efraim.otero(at)gmail.com Guest
Posted: Fri Nov 13, 2015 12:52 pm Post subject: Stratux Build |
Cool!
We do not have ADS-B in South America and I find it difficult to justify forking up 800 dollars to buy a Stratus II to get AHRS and Virtual attitude data on my foreflight (which works amazing here in South America).
This sounds like an interesting project. Even though I have never really soldered anything well… it could work!!
(yes I am THAT incompetent! haha!)
Ephraim Otero
On Nov 12, 2015, at 8:58 PM, C&K <yellowduckduo(at)gmail.com> wrote:
I bought the exact items except the (battery) and it seems to work fine. I use fltplango (it's free) on an ipad.
To my surprise there were no tricks or hassles involved. Anyone who can type on this list and download a program should have no problem.
My only reservation is that it is one more thing to distract me from looking outside...
Ken
cyav8r(at)yahoo.com Guest
Posted: Fri Nov 13, 2015 2:14 pm Post subject: Stratux Build |
I had the L-3 NGT-9000 installed in my airplane and it does both in and out in a single box that replaced my KT76A. Traffic and weather products are displayed on the transponder touchscreen, and it also pushes TIS-B and FIS-B data to an iPad via wifi.
There are other options out there as well, this is just what I chose to do to get traffic on the panel without needing more 'stuff'.
Sent: Friday, November 13, 2015 12:16 PM
Subject: RE: Stratux Build
--> AeroElectric-List message posted by: "Bill Bradburry" <bbradburry(at)verizon.net (bbradburry(at)verizon.net)>
rampil
Posted: Fri Nov 13, 2015 3:57 pm Post subject: Re: Stratux Build |
"Even though I have never really soldered anything "
No soldering required. Some familiarity with Linux helps but not essential.
AHRS is not yet working well (as of 4r4) with a precession problem but it
is being worked on
Posted: Fri Nov 13, 2015 4:16 pm Post subject: Stratux Build |
Well, ok, here is a request for suggestions.
What would be the best (cheapest!) option if I have the following avionics:
Garmin GNS430W Com/Nav/GPS
Garmin GTX327 Transponder
KMD150 MFD/GPS
I am considering purchasing a tablet as well, IPad or Galaxy. What are the
recommendations here as well.
B2
Posted: Fri Nov 13, 2015 6:35 pm Post subject: Stratux Build |
The *easiest* (and likely cheapest, due to minimal labor) path for
'out', with a G430W already installed and a G327 tray installed, would
probably be a G330 ES transponder for 'out', and just about any cheap
'in' solution. Cheapest 'in' is an android phone/tablet running the
Avare + SDR I described in the previous email (could be under $100 for a
complete 'in' solution). Note that the above is purely plug & play; load
the apps, plug in the cable to the tablet & SDR, and go.
But I'm in no hurry to install 'out'. Stuff will change. FAA says they
won't move the deadline, but according to many sources, we're already
too close to the deadline for existing shops to get all a/c upgraded in
time. And regardless, the equipment will get cheaper.
Charlie
KMD150 MFD/GPS
B2
Posted: Sat Nov 14, 2015 7:46 am Post subject: Stratux Build |
I think you can upgrade the GTX330 to the ES version for about $1K, but per
the Q&A at AC Spruce the GTX327 tray and harness is not interchangeable.
Will the GTX 330 ES fit the same rack as the GTX 327? How about the harness?
The Garmin GTX 330 ES and the GTX 327 use both different racks and
harnesses.
Bill
stephencliverichards(at)g Guest
Posted: Sat Nov 14, 2015 9:42 am Post subject: Stratux Build |
A similar self build device using a raspberry Pi B+ is being developed as open source in the UK see http://www.pilotaware.com/ for ADS-B in this will also provide ADS-B out for connection to a ES equipped transponder and transmission to another pilotaware device I will wait for further development & testing before I build one. I read some prototypes have been tested with a GPS plugin dongle & air pressure sensing boards added all at a low cost but transmitter needs further screening work to make reliable.I assume it would also be usable in USA
Clive
On 13 November 2015 at 23:57, rampil <ira.rampil(at)gmail.com (ira.rampil(at)gmail.com)> wrote:
| Quote: | --> AeroElectric-List message posted by: "rampil" <ira.rampil(at)gmail.com (ira.rampil(at)gmail.com)>
is being worked on
Ira N224XS
http://forums.matronics.com/viewtopic.php?p=449369#449369
br> fts!)
r> > w.buildersbooks.com" rel="noreferrer" target="_blank">www.buildersbooks.com
-Matt Dralle, List Admin.
FORUMS -
b Site -
