rocknpilot(at)hotmail.com Guest
Posted: Fri Oct 09, 2015 11:33 am Post subject: Oil Tank / Engine Heater |
Hi, Redstars!
Well, our 3 weeks of Summer flew by (pun intended!) quickly in WI and I am now faced with the dismal prospect of a multi-month "no fly zone" due to ridiculously impending cold weather and harsh climate. Can anyone offer advice on engine / oil pre-heat for a Yak 52? I've done some propane ducted-heat experimentation and have seen limited / marginal success. I would really like a dependable method so I can maintain my "chops" over the Winter months. If anyone has any solid advice / experience and / or if anyone has a system for sale, or feels confident in directing me to someone offering one, please talk to me. I think we can keep this topic "on-list" as it may be of interest to other pilots...?
Thank you in advance - and 'hoping this finds you all healthy, happy and thriving!
Rico Jaeger
915 S. 11th Ave.
Wausau, WI. 54401
715.529.7426
1966 Cessna 150F ^/---//-X
N8558G // Hangar #35 / AUW
1992 Yakovlev Yak 52 ^/---//-X
N21YK //
Hangar #21 / AUW
cjpilot710(at)aol.com Guest
Posted: Fri Oct 09, 2015 1:51 pm Post subject: Oil Tank / Engine Heater |
Jaeger, (German for 'hunter', I think)
I seen (but never had to use) electric heating pads and oil dip sticks. I've seen pad pasted not only to sides of the oil tank but to the oil sump as well. One can buy electric oil tank emersion heater elements. Another cheap way is infrared lamps placed under the cowl with a large blanket drape over the entire cowling to keep the heat in. When I lived in CT, I kept two 100w light bulbs under the cowling of my Pitts with a blanket draped over the cowl in the winter (Not that I flew it that much in the winter). Or you could do like a lot Alaskans do. Drain the oil in large bucket and take it home to keep it warm. Simply it pour back in the tank when you're ready to fly.
I personally believe I'd look for a way to heat not just the oil but the engine it self at the same time. It not good to get cold metal to moving with all the contraction of the cold in it parts.
Jim "Pappy" Goolsby
PS Its WHY I live in Florida BTW.
In a message dated 10/9/2015 4:20:21 P.M. Eastern Daylight Time, rocknpilot(at)hotmail.com writes:
Hi, Redstars!
Rico Jaeger
915 S. 11th Ave.
Wausau, WI. 54401
715.529.7426
N21YK //
Hangar #21 / AUW
flying(at)jeffhove.com Guest
Posted: Fri Oct 09, 2015 7:47 pm Post subject: Oil Tank / Engine Heater |
Rico,
The owner of EZ-Heat <http://e-zheat.com/store/> is also a Yak-52 owner
and has electric heat pads that perfectly fit the Yak's oil tank, sump,
and oil cooler (don't forget about the cold oil there at the end of six
foot long oil lines!). The kits are complete and easy to install (just
be sure to thoroughly sand and clean the areas the pads adhere to).
He is also a neighbor of yours based in Chetek, WI. Go tour the
factory right on the airport.
This warms everything gently without introducing a lot of water vapor or
exhaust fumes like combustion pre-heaters and is safe to leave
unattended. Add a cell-phone controlled GSM relay system
<http://relaysupply.com/gsm-relays/gsm-auto-high-amperage-remote-control-device-2-x-relays-ac-100-240v-powered.html/>,
and you can start the pre-heat the night before fly so it is already
warm when you get to the hangar.
Jeff Hove
Lake Elmo, MN
Cessna 150F N8353G
RV-7A N347RV
Yak-52 NX52BS
On 10/9/2015 2:28 PM, Rico Jaeger wrote:
Hi, Redstars!
other pilots...?
and thriving!
Rico Jaeger
915 S. 11th Ave.
Wausau, WI. 54401
715.529.7426
N8558G //
Hangar #35 / AUW
N21YK //
Hangar #21 / AUW
Posted: Fri Oct 09, 2015 8:36 pm Post subject: Oil Tank / Engine Heater |
Thanks, Jeff! Most helpful!
________________________________________
From: owner-yak-list-server(at)matronics.com <owner-yak-list-server(at)matronics.com> on behalf of Jeff Hove <flying(at)jeffhove.com>
Sent: Friday, October 9, 2015 10:44 PM
To: yak-list(at)matronics.com
Subject: Re: Oil Tank / Engine Heater
Rico,
Jeff Hove
Lake Elmo, MN
Cessna 150F N8353G
RV-7A N347RV
Yak-52 NX52BS
Hi, Redstars!
other pilots...?
and thriving!
Rico Jaeger
915 S. 11th Ave.
Wausau, WI. 54401
715.529.7426
N8558G //
Hangar #35 / AUW
N21YK //
Hangar #21 / AUW
richard.goode(at)russiana Guest
Posted: Sat Oct 10, 2015 12:25 am Post subject: Oil Tank / Engine Heater |
It is worth noting that the original Russian instructions say that if the M 14 P is not going to be used for only a week, then it should have short-term conservation, to prevent internal corrosion on an engine that has been used and so has combustion by-products in the engine. If you are leaving the engine for an entire winter, it should have full conservation. Of course they were incredibly conservative, but I pass this on for what it is worth!
Richard Goode Aerobatics
Rhodds Farm
Lyonshall
Hereford
HR5 3LW
Tel: +44 (0) 1544 340120
Fax: +44 (0) 1544 340129
www.russianaeros.com
From: owner-yak-list-server(at)matronics.com [mailto:owner-yak-list-server(at)matronics.com] On Behalf Of Rico Jaeger
Sent: 09 October 2015 20:29
Subject: Oil Tank / Engine Heater
Hi, Redstars!
Rico Jaeger
915 S. 11th Ave.
Wausau, WI. 54401
715.529.7426
N8558G //
Hangar #35 / AUW
N21YK //
Hangar #21 / AUW
[/b]http://forums.matronics.comhttp://www.matronics.com/contribution==== [/quote]
believed to be clean.
www.avast.com [quote][b]
heaysr(at)telus.net Guest
Posted: Sat Oct 10, 2015 12:09 pm Post subject: Oil Tank / Engine Heater |
I fly my Yak 55/M14P throughout the winter here in Vancouver BC, except on
very cold days when ambient is below freezing.
The O&M manual indicates preheat in necessary below 5 deg C
My hangar is unheated.
I have installed a EZ heat butterfly pad on the bottom of the oil tank, and
a single EZ Heat pad on one end of the oil cooler and another on the sump
located at the front of the engine bottom center (where the metal filings
sensor and drain valve is located).
I leave the tank heater on for a minimum of an hour and the oil cooler and
sump heaters on for 30 min before engine start. I get quite a lot of oil
draining down to the sump over a week. Hence the sump heater.
In addition I use a propane space heater to heat the cylinders. I remove the
lower half cowling and leave the upper half cowling on and cover it with a
blanket.
With stove piping, the space heater output is directed straight up from the
hangar floor under the engine watching to make sure things don't get too hot
inside the cowling. The engine gets cozy warm after 30 min. I check
cylinder and engine component temps using one of those hand held temp
reading guns.
On start up the oil pressure is within limits. After warming the engine at
46% RPM for about 5 minutes, the oil pressure suddenly drops to the lower
limit and stays there for a while, then gradually increases back to normal
as the oil temp rises to the green arc. I suppose the drop is the oil being
routed to the oil cooler where the cold oil has a high viscosity until
flushed through.
I use Phillips 66 X/C 25W-60 Radial engine oil
Royden
Viperdoc
Posted: Sat Oct 10, 2015 12:16 pm Post subject: Oil Tank / Engine Heater |
Move south young man.
Doc
On Oct 9, 2015, at 2:28 PM, Rico Jaeger <rocknpilot(at)hotmail.com (rocknpilot(at)hotmail.com)> wrote:
Hi, Redstars!
Rico Jaeger
915 S. 11th Ave.
Wausau, WI. 54401
715.529.7426
N21YK //
Hangar #21 / AUW
_________________ Viperdoc |
Posted: Sun Oct 11, 2015 10:24 am Post subject: Oil Tank / Engine Heater |
Thnax, Richard!!
Rico Jaeger
915 S. 11th Ave.
Wausau, WI. 54401
715.529.7426
N21YK //
Hangar #21 / AUW
From: owner-yak-list-server(at)matronics.com <owner-yak-list-server(at)matronics.com> on behalf of Richard Goode <richard.goode(at)russianaeros.com>
Sent: Saturday, October 10, 2015 3:22 AM
Subject: RE: Oil Tank / Engine Heater
Rhodds Farm
Lyonshall
Hereford
HR5 3LW
Hi, Redstars!
Rico Jaeger
915 S. 11th Ave.
Wausau, WI. 54401
715.529.7426
N8558G //
Hangar #35 / AUW
N21YK //
Hangar #21 / AUW
| Quote: | | http://www.matronics.com/Navigator?Yak-List |
MailScanner | The #1 Open Source Email Filter
MailScanner is a highly respected open source email security system design for Linux-based email gateways. It is used at over 30,000 sites around the world ...
Read more...
www.avast.com
="http://www.matronics.com/Navigator?Yak-List">http://www.matronics.com/Navigator?Yak-List
="http://forums.matronics.com">http://forums.matronics.com
="http://www.matronics.com/contribution">http://www.matronics.com/contribution
Posted: Sun Oct 11, 2015 10:26 am Post subject: Oil Tank / Engine Heater |
Doc,
I can be there as early as Tuesday. I just need hangar space and a room w/ cable, internet, fridge (dorm size OK) laundry, RR, girl and bed. Let me know...
Thanks!
Rico Jaeger
915 S. 11th Ave.
Wausau, WI. 54401
715.529.7426
N21YK //
Hangar #21 / AUW
From: owner-yak-list-server(at)matronics.com <owner-yak-list-server(at)matronics.com> on behalf of Roger Kemp <f16viperdoc(at)me.com>
Sent: Saturday, October 10, 2015 3:12 PM
Doc
Hi, Redstars!
Rico Jaeger
915 S. 11th Ave.
Wausau, WI. 54401
715.529.7426
N21YK //
Hangar #21 / AUW
a>
Viperdoc
Posted: Sun Oct 11, 2015 11:50 am Post subject: Oil Tank / Engine Heater |
😉 most are workable. The girl, you'll have to on your own.
Doc
On Oct 11, 2015, at 1:22 PM, Rico Jaeger <rocknpilot(at)hotmail.com (rocknpilot(at)hotmail.com)> wrote:
Doc,
Thanks!
Rico Jaeger
915 S. 11th Ave.
Wausau, WI. 54401
715.529.7426
N21YK //
Hangar #21 / AUW
From: owner-yak-list-server(at)matronics.com (owner-yak-list-server(at)matronics.com) <owner-yak-list-server(at)matronics.com (owner-yak-list-server(at)matronics.com)> on behalf of Roger Kemp <f16viperdoc(at)me.com (f16viperdoc(at)me.com)>
Doc
Hi, Redstars!
Rico Jaeger
915 S. 11th Ave.
Wausau, WI. 54401
715.529.7426
N21YK //
Hangar #21 / AUW
a>
ist"">http://www.matronics.com/Navigator?Yak-List
PaulW
Posted: Mon Oct 12, 2015 9:17 am Post subject: Re: Oil Tank / Engine Heater |
Hi
This is how I do it:
I use a portable on wheels airconditioner, a small heater and a aluminium foil type duct which can be bought at a DIY store.
Normally an airconditioner will take warm air from the rear inlet, cool it and blow the cold air out in front and the hot resultant air out of its "exhaust outlet". This outlet pipe is usually routed out of a window or maybe a hole in the ceiling and out.
So what I do is to extend the standard outlet with the aluminium flxible duct and route it in to the engine bay between the fuselage and cowling.
I place the little heater at the rear of the airconditioner at the inlet.
The hot air from the exhaust is hot and a strong airflow.
This works much better than just a small heater with a fan or other sump heaters.
I set this up as a first thing and then start pre-flight. By the time I am done with the pre-flight, the CHT temp raised by at least 20 degrees Celsius.
This way you heat up the whole engine and not only the sump as with some sump heaters.
I must say that the winters never really get colder than -2 to -3 degrees Celsius and the YAK-52 live inside a hanger.
regards
Paul
45.19 KB |
19270 Time(s) |
81.57 KB |
19270 Time(s) |
danbooker
Posted: Tue Oct 13, 2015 6:50 am Post subject: Re: Oil Tank / Engine Heater |
Hey Rico,
I have oil pan heat strips installed. They work great. Only problem is I preheated engine compartment and still blue an oil line going to wing/oil cooler. I suggest an additional heater strip on your oil cooler "radiator". Of course, a heated hanger would be best, but I do not have that option! Good luck.
_________________ Daniel Booker
"Stealth-Eagle Aviation"
2312457798
danbooker@hotmail.com |
Posted: Tue Oct 13, 2015 7:41 am Post subject: Oil Tank / Engine Heater |
I've mentioned this before, but it is worth repeating I suppose.
The original YAK-50 came with a type of "Veritherm", think of it as working the same way as the thermostat in your engines cooling system. It screws into the standard M-14 oil cooler that is found on both the 50, 52, 55 and Sukhoi's as well. You'll also find a Veritherm in U.S. made oil coolers on many models.
For reasons unknown, Russia put out a directive to remove these devices from the YAK-50's. However they can still be found in the Russian helicopter oil coolers. Long story short, they are not easy to find, but they are out there, and they do work extremely well. Vladimir Yastremski happened to come across one, and I had him put it back in my otherwise stock oil cooler.
I immediately noticed faster oil warm-up times, and a much more stable oil temperature reading. This also gives a pressure by-pass to the oil cooler when the oil is cold. The oil temp also remains much more stable when flying, obviously because it is now regulated just like your car engines water temperature (more or less anyway).
There has to be some reason why the Russians pulled this thing out, but it can't be THAT bad since they left them in every helicopter oil cooler. In any case, I've run this one over 500 hours without an issue.
The only problem is finding one, but it's worth thinking about.
Mark
jan.mevis(at)informavia.b Guest
Posted: Tue Oct 13, 2015 8:37 am Post subject: Oil Tank / Engine Heater |
I fully concur. I have one on my Yak 50 too.
Jan
On 13/10/15 17:38, "Bitterlich, Mark G CIV NAVAIR, WD"
<owner-yak-list-server(at)matronics.com on behalf of
mark.bitterlich(at)navy.mil> wrote:
<mark.bitterlich(at)navy.mil>
stock oil cooler.
Mark
jblake207(at)comcast.net Guest
Posted: Tue Oct 13, 2015 9:55 am Post subject: Oil Tank / Engine Heater |
I flew various helicopters for years... the OH-58 series (almost the same as a Jet Ranger) has the Vernatherm valve for that very purpose... to aid in cooling and warming the oil in cold weather ops. The valve is also found on most H.O. engines such as Lycoming and Continental. Anyway, here's a good article on the subject. http://www.avweb.com/news/maint/182617-1.html
From: "Mark G CIV NAVAIR Bitterlich, WD" <mark.bitterlich(at)navy.mil>
Sent: Tuesday, October 13, 2015 10:38:16 AM
Subject: RE: Re: Oil Tank / Engine Heater
--> Yak-List message posted by: "Bitterlich, Mark G CIV NAVAIR, WD" <mark.bitterlich(at)navy.mil>
Mark
drc(at)wscare.com Guest
Posted: Tue Oct 13, 2015 10:27 am Post subject: Oil Tank / Engine Heater |
Mark, this is a good point and ultimately what I believe the problem is / was with the TWs The TW had all of the oil overheat problems early on and people came up with all types of solutions, including sealing or raising the doghouse under the nose.
Others tried extending the exhaust thinking hot exhaust was directed right inot the cooler intake.
We even moved ours to the wing. This required a cooler replacement from Positech. They do sell coolers that work with a vernatherm. Mine works well now, but I believe it is due to the vernatherm, not the change in location to the wingroot.
I think several other TW owners have solved their oil cooling problems with help from Positech, either replacing the cooler or the vernatherm.
Anyone on the list that can verify their experience??
Dr. Herbert Coussons
main 920.338.6868
fax 888.876.4773
cell 920.639.8434
(at)DrC_WSC
[img]cid:0AEC9E78-9DFD-4F58-A5BE-DA155CD5EC8A[/img]
Green Bay • Appleton • Marinette
womens-specialtycare.com
This message is being sent by Dr Herbert Coussons, MD. It is intended exclusively for the individuals and entities to which it is addressed. This communication, including any attachments, may contain information that is proprietary, privileged, confidential, including information that is protected under the HIPAA privacy rules, or otherwise legally exempt from disclosure. If you are not the named addressee, you are not authorized to read, print, retain, copy or disseminate this message or any part of it. If you have received this message in error, please notify the sender immediately by email and delete all copies of this message. This message is protected by applicable legal privileges and is confidential.
[quote] On Oct 13, 2015, at 10:38 AM, Bitterlich, Mark G CIV NAVAIR, WD <mark.bitterlich(at)navy.mil (mark.bitterlich(at)navy.mil)> wrote:
--> Yak-List message posted by: "Bitterlich, Mark G CIV NAVAIR, WD" <mark.bitterlich(at)navy.mil (mark.bitterlich(at)navy.mil)> I've mentioned this before, but it is worth repeating I suppose. The original YAK-50 came with a type of "Veritherm", think of it as working the same way as the thermostat in your engines cooling system. It screws into the standard M-14 oil cooler that is found on both the 50, 52, 55 and Sukhoi's as well. You'll also find a Veritherm in U.S. made oil coolers on many models. For reasons unknown, Russia put out a directive to remove these devices from the YAK-50's. However they can still be found in the Russian helicopter oil coolers. Long story short, they are not easy to find, but they are out there, and they do work extremely well. Vladimir Yastremski happened to come across one, and I had him put it back in my otherwise stock oil cooler. I immediately noticed faster oil warm-up times, and a much more stable oil temperature reading. This also gives a pressure by-pass to the oil cooler when the oil is cold. The oil temp also remains much more stable when flying, obviously because it is now regulated just like your car engines water temperature (more or less anyway). There has to be some reason why the Russians pulled this thing out, but it can't be THAT bad since they left them in every helicopter oil cooler. In any case, I've run this one over 500 hours without an issue. The only problem is finding one, but it's worth thinking about. Mark --
25.01 KB |
19226 Time(s) |
csprjm(at)aol.com Guest
Posted: Tue Oct 13, 2015 10:40 am Post subject: Oil Tank / Engine Heater |
Posted: Tue Oct 13, 2015 10:51 am Post subject: Oil Tank / Engine Heater |
Humph Humph. (nose in air) I have four (4) vernatherm on the airplane I fly. ONE for each engine for the B-24. So there.
Jim "Pappy" Goolsby
In a message dated 10/13/2015 1:55:46 P.M. Eastern Daylight Time, jblake207(at)comcast.net writes:
[quote] I flew various helicopters for years... the OH-58 series (almost the same as a Jet Ranger) has the Vernatherm valve for that very purpose... to aid in cooling and warming the oil in cold weather ops. The valve is also found on most H.O. engines such as Lycoming and Continental. Anyway, here's a good article on the subject. http://www.avweb.com/news/maint/182617-1.html
Mark
Posted: Tue Oct 13, 2015 7:00 pm Post subject: Oil Tank / Engine Heater |
Yes I do. Its a GWTFG (Goolsby Watch The Fr*&^%g Gage).
In a message dated 10/13/2015 3:13:30 P.M. Eastern Daylight Time, mark.bitterlich(at)navy.mil writes:
[quote]--> Yak-List message posted by: "Bitterlich, Mark G CIV NAVAIR, WD" <mark.bitterlich(at)navy.mil>
Yeah, but do you have one on your CJ?
