Cruzer-list
dlj04(at)josephson.com
PostPosted: Fri Oct 02, 2015 8:55 am    Post subject: Cruzer-list Reply with quote
On 10/2/15 12:03 AM, Zenith-List Digest Server wrote:
Time: 08:23:03 PM PST US
Subject: Cruzer List
Well now the deed is done. I've managed to strip out the 601's engine=2C
mount. avionics=2C instruments=2C wiring and everything else non-aluminum i
n the airframe and shelve it=2C pending its reincarnation as a 750 Cruzer.
Now that I am deeply engrossed in a 750 Cruzer quick build kit=2C I was
wondering if there are any Cruzer paisanos out there=2C who can add some ex
perienced advice.
Maybe, what experienced advice are you looking for? The advice I can
offer is (a) the holes *are* in the right place and (b) there is a right
way everything fits together if you stare at it for long enough.
paulrod36(at)msn.com
PostPosted: Fri Oct 02, 2015 1:38 pm    Post subject: Cruzer-list Reply with quote
Yeah, I'm going to be doing a lot of staring, I fear.  I drove over to Mexico with my vertical stabilizer, and Roger told me how they did it.  It's kind of catchy, though, the holes in the vert stab skin are not drilled where the holes in the ribs are, and vice versa. Turns out  also, that you trim the skin to go even with the spar flanges, and cut out the relief at the bottom to accommodate the upper surface of the horizontal stabilizer----all of which is not  addressed in the drawings, and is not in the several step-by-step instructions on the site. Good thing they're such helpful folks.  Fortunately, I got the quick-build kit, which makes things easier.
Paul R
Subject: Zenith-List: Re: Cruzer-list
Date: Fri, 2 Oct 2015 09:54:30 -0700
--> Zenith-List message posted by: D L Josephson <dlj04(at)josephson.com>
> From: <paulrod36(at)msn.com>
> Subject: Zenith-List: Cruzer List
> perienced advice.
&g=======
