Trim servo and antenna routing
wladimirkummer(at)gmail.c
PostPosted: Fri Sep 11, 2015 12:14 pm    Post subject: Trim servo and antenna routing Reply with quote
Hi all,
Any advice on routing the antenna cable and trim wire from tail to cockpit?
Wlad
Europa XS MG kit A193
h&jeuropa
PostPosted: Fri Sep 11, 2015 12:52 pm    Post subject: Re: Trim servo and antenna routing Reply with quote
If you plan on using a copper strip comm antenna as Europa suggests, it will be on the starboard side of the fin, so run the antenna cable on the starboard side of the fuselage to the rear. Run the trim motor cable on the opposite side to minimize the chance of interference from the comm antenna.
Jim Butcher
N241BW
