Kolb-List Digest: gap seal spring
byoungplumbing(at)gmail.c
PostPosted: Thu Aug 06, 2015 7:12 am    Post subject: Kolb-List Digest: gap seal spring Reply with quote
At the top of this picture is a side view at the right side there is a spring attach tab.   The spring goes under the 1 inch square tube to hold the gap seal down and back.    Lower in the picture is a top view that shows lateral position.
Boyd Young
 Filesize:  323.24 KB
 Viewed:  3844 Time(s)
Flylawnchairs
PostPosted: Fri Aug 07, 2015 11:05 am    Post subject: Re: Kolb-List Digest: gap seal spring Reply with quote
Thanks Boyd, is there any way I could get a reprint of your plans or copy them and send them back to you. I would make it worth your while.
I talked with the factory and they say they don't have any plans for the 2004 mk3x.
williamtsullivan(at)att.n
PostPosted: Fri Aug 07, 2015 11:13 am    Post subject: Kolb-List Digest: gap seal spring Reply with quote
Boyd- If you are going to copy your plans, make two copies and send on to the factory for their records. I am sure they will appreciate it.
Bill Sullivan
Windsor Locks, Ct.
On Fri, 8/7/15, Flylawnchairs <Flylawnchairs(at)gmail.com> wrote:
Subject: Re: Kolb-List Digest: gap seal spring
Date: Friday, August 7, 2015, 3:05 PM
"Flylawnchairs" <Flylawnchairs(at)gmail.com>
http://forums.matronics.com/viewtopic.php?p=445676#445676
Forum -
   - MATRONICS WEB FORUMS -
List Contribution Web Site -
              -Matt
Dralle, List Admin.
