Dual battery isolation
Goto page 1, 2  Next
Lew Gallagher
PostPosted: Mon Jul 13, 2015 11:09 am    Post subject: Dual battery isolation Reply with quote
Hey Tim O., et al
A little off topic, but related.
I am restoring a bass boat for my step-son. It will have a main battery for starting, and an auxiliary battery for trolling motor, lights, fish finder etc.
I remember your design for your main and backup batteries having two diodes wired in so that they can be charged from the same source, but not bleed back into the other system. I've checked and they DO sell "battery isolators" and "automatic charging relay with start isolation" specifically for my marine needs, but they're a little pricey. They are affordable, but you know I love a challenge and the opportunity to learn something new.
Can I make my own? If so, what are sources and part numbers for the diodes and a diagram?
Thanks, - Lew
non-pilot
crazy about building
NOW OFICIALLY BUILDER #40549
Fly off completed !
Tim Olson
PostPosted: Mon Jul 13, 2015 11:47 am    Post subject: Dual battery isolation Reply with quote
I just re-worked this a little for my RV-14 and changed things
ever so slightly, but the Schottky I used for the system this
time is the DSS2x121-0045B by IXYS. It handles a lot of
current.
The design basically uses one schottky just to feed from the main
to the aux bus (that feeds the e-bus), just to charge the battery.
(only when the aux master switch is on) The 2nd schottky was used
primarily because: I turned on the e-bus during engine cranking
to prevent brownout, but then turned it off after it was running.
Without a diode feed, during the switch throw, the power would
be out on the e-bus. I did some shuffling a little on the new
system to change how it all operates just a tiny bit. But
one of my initial goals was to NOT have the diode drop (even
the small drop of a schottky) between the main bus that is doing
the charging and the aux batteries, in normal operation. I wanted
that aux battery to get a full voltage charge.
Anyway, above is the part number of the diode I used.
For the diagram, I don't know that what I did will at all
be relevant to what you're trying to do, but it should be
pretty simple to do what you want. You probably could even
just connect the 2 batteries with just the schottky and
be ok. Or, if you want full line voltage, you could
just have a 3 way ON-OFF-ON switch so that one path uses
the diode, one uses a plain wire, and center is off.
It should be pretty easy.
Tim
On 7/13/2015 2:10 PM, Lew Gallagher wrote:
Hey Tim O., et al
Thanks, - Lew
non-pilot
Fly off completed !
http://forums.matronics.com/viewtopic.php?p=444698#444698
Lew Gallagher
PostPosted: Mon Jul 13, 2015 6:18 pm    Post subject: Dual battery isolation Reply with quote
Thanks for the lightning response, Tim. I'm on it. I assume I can just put
the charge wire from the motor to both diodes, then from each diode to each
battery?
Later, - Lew
non-pilot
Fly off completed !
Tim Olson
PostPosted: Tue Jul 14, 2015 3:18 am    Post subject: Dual battery isolation Reply with quote
I would just keep the one battery the way it is, charging off the motor,
and then put
the diode between the positive terminals of the batteries so that the
second battery
charges off the first battery. It won't flow power back from that
second to the
first, but if they're the same type of battery it should keep them both
charged.
Now, if they aren't the same battery chemistry, I'd rethink it all and
probably
buy that special charger. (i.e. if one is a normal starting battery and
one is
deep cycle or something like that) I'm not sure what adjustments you'd
have to
make for the various battery chemistries. It's much easier if you are
dealing with
the same battery types.
Tim
just put the charge wire from the motor to both diodes, then from each
diode to each battery?
Later, - Lew
Lew Gallagher
PostPosted: Tue Jul 14, 2015 5:05 am    Post subject: Dual battery isolation Reply with quote
Hmmm, the part number DSS2x121-0045B looks like it is two diodes side by
side? That's why I was thinking total isolation. I wouldn't want the main
battery to be drained by running the trolling motor for hours while the
engine is off.
For RV application, you might be interested in researching this automatic
charging relay with start isolation by Blue Sea Systems
https://www.bluesea.com/products/7610/SI-ACR_Automatic_Charging_Relay_-_12_24V_DC_120A
I'll see if attaching the pdf instructions to this works.
Later, - Lew
Blue_Sea_7610_SI-ACR.pdf
 Filename:  Blue_Sea_7610_SI-ACR.pdf
 Filesize:  693.56 KB
 Downloaded:  630 Time(s)
non-pilot
Fly off completed !
Tim Olson
PostPosted: Tue Jul 14, 2015 5:56 am    Post subject: Dual battery isolation Reply with quote
Good point.
For a boat, if it were me, I'd either add a switch then
in series so I could get rid of that connection
when trolling, or, you could stick in a relay that
is either tweaked so that it only closes the relay
when you get a charging voltage over a certain
setpoint, like 13.2V or something...or, it only
closes when the engine is running (detected by
some other means). Really, personally, I would probably
in real life not even bother to hack this stuff together.
Parts add up to $$ eventually, and I'd rather buy a
product like that $109.97 automatic charging relay,
that is well made. So I wouldn't even screw with the
stuff you're looking for.
In the plane, it was easy for me to do what I wanted though.
Tim
On 7/14/2015 8:02 AM, lewgall(at)charter.net wrote:
[quote] Hmmm, the part number DSS2x121-0045B looks like it is two diodes side by
main battery to be drained by running the trolling motor for hours while
the engine is off.
automatic charging relay with start isolation by Blue Sea Systems
Later, - Lew
flying-nut(at)cfl.rr.com
PostPosted: Tue Jul 14, 2015 6:19 am    Post subject: Dual battery isolation Reply with quote
Sorry guys ..... I just don't understand.
I've deleted a couple of my 'replies' to this thread before I hit 'send'
already because I can't offer anything really constructive ..... other
than this is what happens when you violate the 'KISS' principle.
Why do you need two batteries? Oh, the 'essential buss'. Well, I have
switches and fuses for removing all items that do not have their own
on/off switch. I can take the time to do that after I get a 'low
voltage' warning from multiple sources.
Want more cranking power? Use a higher CCA battery. Still want to
isolate that battery and load? A switch and a high current relay work
really well but suffers from the human not being automatic .........
So, now we add more and more failure points, weight, and $$$ ........
it all adds up, an ounce here and a penny there .... soon you have
pounds and an 'aviation dollar'.
Linn .... KISS supporter (and IMHO)
On 7/14/2015 9:53 AM, Tim Olson wrote:
Good point.
Tim
> the engine is off.
> Later, - Lew
flysrv10(at)gmail.com
PostPosted: Tue Jul 14, 2015 6:44 am    Post subject: Dual battery isolation Reply with quote
+1
do not archive.
Rob Kermanj
[quote] On Jul 14, 2015, at 10:15 AM, Linn Walters <flying-nut(at)cfl.rr.com> wrote:
I've deleted a couple of my 'replies' to this thread before I hit 'send' already because I can't offer anything really constructive ..... other than this is what happens when you violate the 'KISS' principle.
Why do you need two batteries? Oh, the 'essential buss'. Well, I have switches and fuses for removing all items that do not have their own on/off switch. I can take the time to do that after I get a 'low voltage' warning from multiple sources.
Want more cranking power? Use a higher CCA battery. Still want to isolate that battery and load? A switch and a high current relay work really well but suffers from the human not being automatic .........
So, now we add more and more failure points, weight, and $$$ ........ it all adds up, an ounce here and a penny there .... soon you have pounds and an 'aviation dollar'.
> Good point.
> Tim
>> the engine is off.
>> Later, - Lew
deej(at)deej.net
PostPosted: Tue Jul 14, 2015 6:53 am    Post subject: Dual battery isolation Reply with quote
Brownout.
With a glass panel, cranking the engine causes the panel to reboot,
which is a real PITA.
You can either have independent internal batteries for every electronic
device, or follow the KISS principal and have a single second battery on
an essential buss to keep everything up and running.
-Dj
Dj Merrill - N1JOV - EAA Chapter 87
Sportsman 2+2 Builder #7118 N421DJ - http://deej.net/sportsman/
Glastar Flyer N866RH - http://deej.net/glastar/
carl.froehlich(at)verizon
PostPosted: Tue Jul 14, 2015 8:09 am    Post subject: Dual battery isolation Reply with quote
The reason is you can - at low cost and no weight penalty. With some
thought the result is you can eliminate a plethora of single component
failure scenarios that leave you with a dark panel. Two PC-625 batteries
provide all the cranking power I need, and each having a 17amp/hr rating
provides plenty of margin.
There are many power distribution schemes out there besides the "essential
buss" that seems to be popular. Happy to share how I did this on a series
of RVs if interested.
Carl
Kellym
PostPosted: Tue Jul 14, 2015 8:50 am    Post subject: Dual battery isolation Reply with quote
IMHO, brownout is one of the lowest priority justifications.
If you expect to fly lots of IFR in areas where widespread IFR is
common, that might be a reason.
With a glass panel, you only need one panel on for engine start, to
monitor oil pressure, etc.
Most glass panels today are designed to tolerate down to 8 or 9 volts,
so brownout is unlikely.
With a glass panel you either want mechanical gyro backup or at least a
backup battery for the glass panel, by itself. Navigating and
communicating can be done with portable backups. Keeping upright is
better done with keeping the EFIS alive than depending on a portable
tablet, etc.
Or a couple companies offer mini-EFIS that will run for 3-4 hours on
batteries, in case you lose all your electrics. I am very comfortable
with my choices of single electrical system, single battery, with backup
battery on each of the two EFIS, with a Dynon D1 mini-EFIS for backup
and tie-breaking.
Brownout.
-Dj
Kelly McMullen
KCHD
PostPosted: Tue Jul 14, 2015 9:16 am    Post subject: Dual battery isolation Reply with quote
I do not even turn on my panel before engine start. I really don’t worry about monitoring oil pressure immediately. If my engine has performed yesterday, it is likely to perform the same again today.
Do not archive.
If you expect to fly lots of IFR in areas where widespread IFR is common, that might be a reason.
With a glass panel, you only need one panel on for engine start, to monitor oil pressure, etc.
Most glass panels today are designed to tolerate down to 8 or 9 volts, so brownout is unlikely.
With a glass panel you either want mechanical gyro backup or at least a backup battery for the glass panel, by itself. Navigating and communicating can be done with portable backups. Keeping upright is better done with keeping the EFIS alive than depending on a portable tablet, etc.
Or a couple companies offer mini-EFIS that will run for 3-4 hours on batteries, in case you lose all your electrics. I am very comfortable with my choices of single electrical system, single battery, with backup battery on each of the two EFIS, with a Dynon D1 mini-EFIS for backup and tie-breaking.
> Brownout.
> -Dj
deej(at)deej.net
PostPosted: Tue Jul 14, 2015 9:28 am    Post subject: Dual battery isolation Reply with quote
The beauty of experimental aviation is that we each get to choose our
own priorities. For me, brownout protection is a high priority.
I can confirm that my panel reboots if the secondary battery is not on,
and several others on here have written similar reports, so I'd actually
say it seems like brownout is very likely without having a secondary
power source for the display. In your description you say that you have
secondary batteries for each of your two EFIS units, which provide the
same functionality, with a slightly higher maintenance cost but also
slightly higher redundancy.
That's two different ways to solve the same issues, and I'm sure others
have other possible solutions as well. The important end result is one
that each person feels comfortable with, and none of the solutions are
any more "right" or "wrong" than another.
For me, it is more than just an inconvenience. My flow is to have
everything powered up, freqs set, checks done, flight plan entered, etc
and then start the engine.
Once the engine is started, your attention needs to be outside of the
aircraft, not focused inside on the pretty displays. This is basic
safety 101.
-Dj
PostPosted: Tue Jul 14, 2015 9:40 am    Post subject: Dual battery isolation Reply with quote
My only response to 'brownout' while cranking is ..... you might have an
electrical problem.
Most likely causes would be using the airframe and #4 jumpers across
the engine mount isolators.
Vans uses flat braid and crimp connectors .... but a lot of builders
just bolt them down without cleaning the paint from under the lugs.
I ran a #2 ground wire from the battery to the engine case using
firewall bulkhead connectors (from a race car site). Yes, a little more
weight ...... but should not have any electrical issues.
You're right about the internal batteries though, I have two MGL Odyssey
panels, and each has it's own backup battery ..... same battery used in
most emergency exit lights. Yes, I have to flip a switch to charge
them, and the switches are mounted right next to the panel's power
switch. You do not need another huge battery for today's glass panels
Linn
Brownout.
-Dj
deej(at)deej.net
PostPosted: Tue Jul 14, 2015 10:00 am    Post subject: Dual battery isolation Reply with quote
electrical problem.
Yes, the problem is that the starter load reduces the voltage to the
other electrical devices, causing them to reboot.
This is a well known and much discussed issue. Nothing out of the
ordinary at all.
My setup has two separate grounding cables from the engine to a common
grounding block that passes through the firewall to a "forest of tabs"
on the other side. This is the singular grounding location for the
entire airframe, and nothing uses the airframe itself for grounding.
Exactly. My secondary battery is a small 7ah battery much the same as
used in the emergency exit lights or small UPS. It not only feeds the
two EFIS units, but also the GNS480 and the electronic ignition, so
everything critical has a backup power source.
Rather than having two secondary batteries to maintain like you have, I
just have a single one and it charges automatically via a diode.
Kinda sounds like my system is a bit simpler than yours... *wink*
-Dj
Tim Olson
PostPosted: Tue Jul 14, 2015 10:11 am    Post subject: Dual battery isolation Reply with quote
I feel the same as Dj.
I'm going to disconnect from the conversation because these
days I tire of the same old discussions, but, I'll give one
more senario that I like having everything stay up for.
When flying IFR, I've had a bunch of occasions where I
sat in the plane and fired up my primary screen, and
my WSI system, to get a good look at dark storm cells
adjacent to my area. I wanted to check to see what
they were doing and if I could depart and get routed
out of the airport environment without worry.
It takes a few minutes for any weather system to start
putting together the data to get a good display.
So, I have my WSI set up with a small switch to either
use the e-bus or main bus. But on days like that, I like
to have my panel humming, my flight plan entered and
everything all updated as to WX, before I launch. Sometimes
you have to phone call Clearance delivery and they have you
sit tight a bit. It's nice to be able to shut down the
engine and just sit it out, and then fire it back up without
having to re-enter and re-boot everything. Kelly is
just wrong about the EFIS's not rebooting. They can.
There are too many brands and models to make a blanket
statement like that. Mine does. And even if it didn't,
I'd rather have it keep full line voltage. So my
system does what I want it to do. There are also many
different types of starters, that may draw more or less
current. Mine seems to take quite a bit.
For many people I would suggest you check out
TCW Tech's various things like Intelligent power stabilizers
and such. They have great products that can make
all this much easier for you.
It takes a lot off your thinking-plate when worrying
about such things. At any rate as for the way the
electrical system works, I felt I wanted it,
needed it, and could do it, so I did. To each his own.
With that, I'll exit the discussion because with
9+ years of flying behind the system, I'm very happy
with it and it's not going to do me much good to
argue with anyone on it. To me it's just wasted time
that I can never get back.
Tim
safety 101.
-Dj
PostPosted: Tue Jul 14, 2015 10:29 am    Post subject: Dual battery isolation Reply with quote
Tim, thanks for weighing in before you bailed out .... you raise some
very valid points.
I'm not trying to change anyone's mind .... just offering a different
point of view, a result of my experience troubleshooting other peoples
electrical problems. Typically the problems are grounds related. If
you're suffering brown-out problems go to Sky-Tecs troubleshooting page
.... http://www.skytecair.com/Troubleshooting.htm. It may not help
everyone, but it's worth a try.
Linn
Tim
> safety 101.
> -Dj
Checked by AVG - www.avg.com
07/14/15
Tim Olson
PostPosted: Tue Jul 14, 2015 10:56 am    Post subject: Dual battery isolation Reply with quote
No problem Linn,
I do believe in the KISS principle. It usually makes everything
more reliable. In my case, I actually consider it a pretty
simplistic system....it's just a little complex to think
through on the wiring, but the actual connections involved
aren't complicated at all. A couple diodes and a couple
relays and you're set.
Regarding the starter, yeah, you can reduce the brown-out issues,
but I don't think it's practical to think you can always keep
your avionics above, say, 10V, and I know there are components
that can't handle less than 9 or 10V, so rather than worry about
it, IMHO it's better to just deal with it. Even a great
working starter and perfect ground is likely to see a sag that
goes under 10V.
Beyond that, the more battery you put in the plane, the longer
your endurance is if you lose an alternator. And, the longer
you can run ground tests on items. I have people I know who
can't hardly configure their systems to do software updates
because they'll drain their battery too quick. I want to have
a good amount of time for everything. So there are multiple
goals, and no matter what you do there is a compromise.
The key is fully thinking through YOUR situation with YOUR
equipment, and YOUR goals, and then coming up with what
you need. Then you can optimize your system for your plane
and your methods of flying.
I do, however, agree that KISS counts. I constantly have to
try to convince other builders and even people at work
when designing network and system redundancy, that often
times the more components you throw in the harder it is to
guarantee reliability. But there is also a minimum parts
count that works as well.
Tim
very valid points.
..... http://www.skytecair.com/Troubleshooting.htm. It may not help
Linn
> Tim
>> safety 101.
>> -Dj
Kelly McMullen
PostPosted: Tue Jul 14, 2015 12:18 pm    Post subject: Dual battery isolation Reply with quote
Tim, and others,
I agree that having one screen up and everything running before engine start is useful. Dynon Skyview specifically says it will tolerate cranking with the screen on. I wrongly ass-umed that the other brands would have adopted similar power supplies by now.  Yes, having backup battery eliminates the cranking problem if the EFIS won't tolerate low voltage. Most certified avionics these days are designed to comply with latest DO-160 standard. I believe it calls for tolerating 8-32 volts. Of course that just means it won't do damage, but may reboot. It has been rather infrequent for me to operate from an uncontrolled field and go through the gyrations for IFR clearance/release.
A few systems let you just transfer your flight plan from your Ipad to the PFD/MFD system to eliminate the extra data entry. Heck, in Aridzona it is a really rare day for IFR weather that you would want to penetrate with a single engine piston aircraft.
As always, there is no one right choice for everyone, and experimental lets s all make our own choices.
On Tue, Jul 14, 2015 at 11:52 AM, Tim Olson <Tim(at)myrv10.com (Tim(at)myrv10.com)> wrote:
[quote]--> RV10-List message posted by: Tim Olson <Tim(at)myrv10.com (Tim(at)myrv10.com)>
No problem Linn,
goes under 10V.
Tim
--> RV10-List message posted by: Linn Walters <flying-nut(at)cfl.rr.com (flying-nut(at)cfl.rr.com)>
very valid points.
Linn
Tim
--> RV10-List message posted by: Dj Merrill <deej(at)deej.net (deej(at)deej.net)>
safety 101.
-Dj
Kelly McMullen
A&P/IA, EAA Tech Counselor
KCHD
Kellym
PostPosted: Tue Jul 14, 2015 12:46 pm    Post subject: Dual battery isolation Reply with quote
Another thought...there are major differences between varying starters,
as to current draw. The Skytec PM models have among the highest draw.
Other designs draw a lot less. Peak may be anywhere from 150 amps to 300
amps.
an electrical problem.
Kelly McMullen
KCHD
Goto page 1, 2  Next
Page 1 of 2
