speedy11
Joined: 29 Jun 2015 Posts: 62 Location: Port Orange, FL
Posted: Fri Jul 10, 2015 9:51 am Post subject: L29-List Digest: 1 Msgs - 07/09/15 |
Is there anybody on this list?
I have a L-29 (experimental) and I'd like to replace the expensive battery with Odyssey PC-680s. I understand some guys have done that with two batteries wired in series.
Anyone here done that?
Stan Sutterfield
| | - The Matronics L29-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?L29-List |
bculberson(at)staraviatio Guest
Posted: Fri Jul 10, 2015 10:37 am Post subject: L29-List Digest: 1 Msgs - 07/09/15 |
It works like a champ, I've been running therm in mine for 10 years. Call if you want more info.
Bill Culberson
Red Star Aero
251 716 8119
Sent from my T-Mobile 4G LTE Device
-------- Original message --------
Date: 7/10/2015 13:57 (GMT-05:00)
To: l29-list(at)matronics.com
Subject: Re: L29-List Digest: 1 Msgs - 07/09/15
Stan Sutterfield
ics.com
.matronics.com/contribution
ncam(at)wave.co.nz Guest
Posted: Fri Jul 10, 2015 12:27 pm Post subject: L29-List Digest: 1 Msgs - 07/09/15 |
Odyssey works fine I used 940 approx in series and if you are exp. use a dive bottle. It may require nose ballast but makes you autonomous, and you can land anywhere without a ground team. | Quote: | On 11/07/2015, at 06:39, Bill Culberson <bculberson(at)staraviation.com (bculberson(at)staraviation.com)> wrote:
Bill Culberson
Red Star Aero
251 716 8119
To: l29-list(at)matronics.com (l29-list(at)matronics.com)
Is there anybody on this list? I have a L-29 (experimental) and I'd like to replace the expensive battery with Odyssey PC-680s. I understand some guys have done that with two batteries wired in series. Anyone here done that? Stan Sutterfield
jorgen.nielsen(at)mweb.co Guest
Posted: Tue Jul 14, 2015 7:45 am Post subject: L29-List Digest: 1 Msgs - 07/09/15 |
Been running a set in series that lasted a good 8 years. See the pic for latest. Batteries from Enersys, genesis 42EP. Works great, I have noticed the float voltage a bit higher than any other battery I have tested.
Another tip that may help someone: at some point I could not get hold of a 24V smart charger, the type you can leave connected. I then found an ad in a bike magazine for electric scooters (and parts) that run off 24V, called them, ended up buying a great little 24V charger that may be left connected. Does not put out a lot of amps, but great for keeping battery topped off. Was cheap enough.
From: owner-l29-list-server(at)matronics.com [mailto:owner-l29-list-server(at)matronics.com] On Behalf Of Bill Culberson
Sent: 10 July 2015 20:40
Subject: RE: Re: L29-List Digest: 1 Msgs - 07/09/15
Bill Culberson
Red Star Aero
251 716 8119
Stan Sutterfield | Quote: | | ://www.matronics.com/Navigator?L29-Listics.com.matronics.com/contribution | 0123456789 | Quote: | | ://www.matronics.com/Navigator?L29-List | 0 | Quote: | | ://www.matronics.com/Navigator?L29-List | 1 | Quote: | | ://www.matronics.com/Navigator?L29-List | 2 | Quote: | | ://www.matronics.com/Navigator?L29-List | 3
132.01 KB |
5049 Time(s) |
anthony.royal(at)volvo.co Guest
Posted: Tue Jul 14, 2015 7:56 am Post subject: L29-List Digest: 1 Msgs - 07/09/15 |
Running dual 680’s since 2010 and never failed. I’m considering the 900 series in the Odyssey’s for a little more starting power the next time around. Supposed to fit in the original battery box. Little more money and weight
Anthony (Tony) Royal
L-29 Maj Kissof
*************** Confidentiality Notice ****************
This e-mail transmission and/or attachments are intended solely for the use of the individual(s) or entity to which it is addressed and may contain confidential and/or privileged information. Any forwarding, printing, storing, disseminating, distribution, or copying of this communication, in whole or in part, without the expressed verbal or written consent of the writer is strictly prohibited. If you received this communication in error, please notify the sender immediately by replying to this message and then delete it from your system.
From: owner-l29-list-server(at)matronics.com [mailto:owner-l29-list-server(at)matronics.com] On Behalf Of speedy11(at)aol.com
Sent: Friday, July 10, 2015 1:51 PM
Subject: L29-List: Re: L29-List Digest: 1 Msgs - 07/09/15
Stan Sutterfield | Quote: | | _-============================================================_-= - The L29-List Email Forum -_-= Use the Matronics List Features Navigator to browse_-= the many List utilities such as List Un/Subscription,_-= Archive Search & Download, 7-Day Browse, Chat, FAQ,_-= Photoshare, and much much more:_-=_-= --> http://www.matronics.com/Navigator?L29-List | 0 1 2 3 4 5 6 7 8 9 | Quote: | | _-============================================================ | 0 | Quote: | | _-============================================================ | 1 | Quote: | | _-============================================================ | 2 | Quote: | | _-============================================================ | 3
