More on the red cube...
bob88
PostPosted: Fri Jun 19, 2015 11:00 am    Post subject: More on the red cube... Reply with quote
Has anyone with experience mounting the red cube between the servo and spider hanging free inline (no bracket, just suspended in the hose line)? This looks like it will take 45 deg fittings on the cube and it will hang at about a 45 deg uphill flow position. Seems like this is simplest way to go...
flying-nut(at)cfl.rr.com
PostPosted: Fri Jun 19, 2015 11:21 am    Post subject: More on the red cube... Reply with quote
I'd be worried about engine vibration on an unsupported hose assembly
making the readings inaccurate.
Just thinking out loud.
Linn
http://forums.matronics.com/viewtopic.php?p=443816#443816
Checked by AVG - www.avg.com
Dave Saylor
PostPosted: Fri Jun 19, 2015 1:19 pm    Post subject: More on the red cube... Reply with quote
I initially had mine like you're describing. Accuracy was fine but after a premature failure (400 hrs?) I mounted it to a bracket and it's been good for 1000+.  I believe there's a note about orienting the wires upwards, not sure if that means straight up or mainly up.
FWIW, EI replaced my cube no questions asked.
- D
On Friday, June 19, 2015, bob88 <marty.crooks(at)comcast.net (marty.crooks(at)comcast.net)> wrote:
[quote]--> RV10-List message posted by: "bob88" <[url=javascript:;]marty.crooks(at)comcast.net[/url]>
-List" target="_blank">http://www.matronics.com/Navigator?RV10-List
--Dave
KWVI
rv10rob(at)gmail.com
PostPosted: Fri Jun 19, 2015 2:16 pm    Post subject: More on the red cube... Reply with quote
The simplest way to go is to mount it in the tunnel, per plans.  Perfectly accurate there (at least with my IO-540 w/ a standard FI system).
-Rob
On Fri, Jun 19, 2015 at 12:00 PM, bob88 <marty.crooks(at)comcast.net (marty.crooks(at)comcast.net)> wrote:
--> RV10-List message posted by: "bob88" <marty.crooks(at)comcast.net (marty.crooks(at)comcast.net)>
Rob Kochman
RV-10 Flying since March 2011
Woodinville, WA
http://kochman.net/N819K
kdb.rv10(at)gmail.com
PostPosted: Fri Jun 19, 2015 2:21 pm    Post subject: More on the red cube... Reply with quote
I did that with a Floscan sensor. Put a 45 degree fitting in the fuel servo and wrapped the sensor and fuel line with fire sleeve. Works great. It should stay cooler than if mounted to the engine.
Kevin Belue
Kelly McMullen
PostPosted: Fri Jun 19, 2015 3:34 pm    Post subject: More on the red cube... Reply with quote
Remaining cool is not an issue with fuel flow sending units. The negative to mounting in the tunnel is that you are between fuel pumps, and with the boost pump off, the fuel is being sucked under negative pressure to the mechanical pump. The sending units are designed to operate under positive pressure. Best locations are either between mechanical pump and servo or between servo and spider. The former is required by the STC for type certificated aircraft, the latter most common on experimental. The unit is best suspended on a bracket attached to the engine, so that vibrations are in sync with the engine. If you are concerned about heat, mount it under the intake manifold, and cover it with fireshield.
On Fri, Jun 19, 2015 at 3:12 PM, Kevin Belue <kdb.rv10(at)gmail.com (kdb.rv10(at)gmail.com)> wrote:
[quote]--> RV10-List message posted by: Kevin Belue <kdb.rv10(at)gmail.com (kdb.rv10(at)gmail.com)>
Kevin Belue
On Jun 19, 2015, at 2:00 PM, "bob88" <marty.crooks(at)comcast.net (marty.crooks(at)comcast.net)> wrote:
Kelly McMullen
A&P/IA, EAA Tech Counselor
KCHD
rv10flyer
PostPosted: Fri Jun 19, 2015 6:18 pm    Post subject: Re: More on the red cube... Reply with quote
Same here Rob, have not been off more than .5 gallon.
[quote="rv10rob(at)gmail.com"]The simplest way to go is to mount it in the tunnel, per plans.  Perfectly accurate there (at least with my IO-540 w/ a standard FI system).
-Rob
On Fri, Jun 19, 2015 at 12:00 PM, bob88 <marty> wrote:
--> RV10-List message posted by: "bob88" <marty>
Rob Kochman
Woodinville, WA
Wayne G.
Albert Gardner
PostPosted: Sat Jun 20, 2015 5:48 am    Post subject: More on the red cube... Reply with quote
I have the unit mounted in the tunnel as per Vans. No problems with accuracy
although variations in filling the tanks
can cause variations between calculated and actual amounts. In any case I'm
well satisfied with that location. I have a bottom cover into the tunnel
so I can quickly inspect the tunnel for leaks as well as clean the filter.
980 hours.
Albert Gardner
RV-10 N991RV
Yuma, AZ
(Little warm here but it's a dry heat)
RV-9A N872RV
RV-10 N991RV
larkrv10(at)gmail.com
PostPosted: Sat Jun 20, 2015 5:50 pm    Post subject: More on the red cube... Reply with quote
Bob88, I mounted mine on a piece of .050" thick SS plate just above the fuel servo.  I copied Ivan Kristensen's example.
Rick
#40956
Southampton, Ont
On Fri, Jun 19, 2015 at 3:00 PM, bob88 <marty.crooks(at)comcast.net (marty.crooks(at)comcast.net)> wrote:
[quote]--> RV10-List message posted by: "bob88" <marty.crooks(at)comcast.net (marty.crooks(at)comcast.net)>
-List" target="_blank" rel="noreferrer">http://www.matronics.com/Navigator?RV10-List
_blank" rel="noreferrer">http://forums.matronics.com
target="_blank" rel="noreferrer">http://www.matronics.com/contribution
chazking
PostPosted: Sun Jun 28, 2015 5:48 am    Post subject: Red Cube - Floscan Reply with quote
Initially, the floscan was in the tunnel & I was experiencing FF flucuations of 0.5 GPH, which made injector tuning "impossible!" After removing the floscan and replacing it with a red cube between the servo & distributor those fluctuations stopped & a good nozzle tune ensued!
 Filesize:  1.86 MB
 Viewed:  22507 Time(s)
 Filesize:  1.86 MB
Lenny Iszak
PostPosted: Mon Jun 29, 2015 2:18 pm    Post subject: Re: More on the red cube... Reply with quote
Does anyone have the lengths of the two hoses required to move the redcube between the servo and spider?
Lenny
Kelly McMullen
PostPosted: Mon Jun 29, 2015 5:00 pm    Post subject: More on the red cube... Reply with quote
I used about 4.5 inches and maybe 24", with the cube mounted to a fab'd bracket under the #1 intake tube.
On Mon, Jun 29, 2015 at 3:18 PM, Lenny Iszak <lenard(at)rapiddecision.com (lenard(at)rapiddecision.com)> wrote:
[quote]--> RV10-List message posted by: "Lenny Iszak" <lenard(at)rapiddecision.com (lenard(at)rapiddecision.com)>
Lenny
http://forums.matronics.com/viewtopic.php?p=444195#444195
Kelly McMullen
KCHD
PostPosted: Mon Jun 29, 2015 7:41 pm    Post subject: More on the red cube... Reply with quote
Lenny, Steve from Aircraft Specialty made all my oil and fuel hoses (great to deal with btw), my servo to red cube hose is 12", the red cube to spider is 21".  Of course it kind of depends on the location of the flow transducer.  Mine is on a SS bracket just under the case, almost identical to what Ivan Kristensen did.
Rick
On Mon, Jun 29, 2015 at 6:18 PM, Lenny Iszak <lenard(at)rapiddecision.com (lenard(at)rapiddecision.com)> wrote:
Lenny
TimRVator(at)comcast.net
PostPosted: Tue Jun 30, 2015 5:03 am    Post subject: More on the red cube... Reply with quote
I recently moved mine to that location to improve fuel flow accuracy and
to try to improve a hot idle issue. AFP recommended the location
(suspended in the fuel line, not attached to engine). EI (the red cube
manufacturer) shows that mounting method (straight fittings, between
servo and spider, not attached directly to engine) on page 20 of the
install manual, buy-ei.com/wp-content/uploads/2013/06/*II*-*FP*-*5*.*pdf
I like the improved flow accuracy at the new location.
Tim Lewis -- HEF (Manassas, VA)
A&P
RV-6A N47TD -- 1104 hrs - sold
RV-10 N31TD -- 650 hrs
bob88 wrote on 6/19/2015 3:00 PM:
EdKranz
PostPosted: Tue Jun 30, 2015 5:46 am    Post subject: More on the red cube... Reply with quote
Lenny,
I just marked where on that fuel line I wanted the RedCube and sent the original line to TSFlightLines. Tom put the fittings I needed on the original line. It fits great, and it was pretty cheap too. The only downside is that you're obviously not going to be flying when he has your fuel line!
Ed
On Mon, Jun 29, 2015 at 10:36 PM, Rick Lark <larkrv10(at)gmail.com (larkrv10(at)gmail.com)> wrote:
[quote]Lenny, Steve from Aircraft Specialty made all my oil and fuel hoses (great to deal with btw), my servo to red cube hose is 12", the red cube to spider is 21".  Of course it kind of depends on the location of the flow transducer.  Mine is on a SS bracket just under the case, almost identical to what Ivan Kristensen did.
Rick
Lenny
Ed Kranz
RV10
Finishing
www.edandcolleen.com
kearney
PostPosted: Tue Jun 30, 2015 6:48 am    Post subject: More on the red cube... Reply with quote
Hi
It is very easy to make your own fuel lines (braided steel) and put on fire sleeve. You can get all the kit you need at a local speed shop.
Cheers
Les
On Jun 30, 2015, at 07:43, Ed Kranz <ed.kranz(at)gmail.com (ed.kranz(at)gmail.com)> wrote:
[quote]Lenny,
Ed
Rick
Lenny
List"">http://www.matronics.com/Navigator?RV10-List
Lenny Iszak
PostPosted: Thu Jul 02, 2015 12:25 pm    Post subject: Re: More on the red cube... Reply with quote
Thanks for the lengths. Saves me from pulling my fancy plenum to take measurements...
I have the floscan in the tunnel and it's pretty accurate for calculating the fuel used, but it's bouncing around a lot for precise LOP adjustments.
Lenny
Lenny Iszak
Palm City, FL
2014 RV-10, N311LZ - 500 hrs
