bakerocb
Posted: Thu Jun 18, 2015 4:59 am Post subject: iPad in the Cockpit |
6/18/2015
Hello Marvin Haught, You wrote: “.... I am going with an iPad with
ForeFlight set into a panel mount......”
On a normally warm yesterday my iPad mini 2 with WingX Pro 7, held in
cockpit space by a Ram mount, gave up and said words to the effect: "I am
suffering from heat exhaustion and will have to rest for a while."
Maybe one should rethink making a panel mounted iPad a critical piece of
flight instrumentation.
OC
'O C' Baker says "The best investment you can make is the effort to gather
and understand information."
<_handainc(at)madisoncounty.net_ (mailto:handainc(at)madisoncounty.net) >
Good analysis - this is exactly why I am going with an iPad with
ForeFlight set into a panel mount, and likely staying with steam gauges,
as my instrument flying days are over. When I get to my "keeper"
project, I might chuck the steam gauges if there are programs affordable
programs available using an iPad as base for EFIS , but for now, steam
gauges and ForeFlight on a panel mount iPad.
M. Haught
deej(at)deej.net Guest
Posted: Thu Jun 18, 2015 6:30 am Post subject: iPad in the Cockpit |
On 06/18/2015 08:57 AM, Owen Baker wrote:
am suffering from heat exhaustion and will have to rest for a while."
On the flip side of that, I have an iPad 2 running WingX mounted on the
panel of my Glastar using a RAM mount, and have had no issues in using
it, going on 4 years now.
Likely my high wing helps to block some of the sun from hitting the iPad
directly. It would also be easy enough to add a cooling fan much like
we do with other panel mounted avionics.
For a VFR aircraft, do you really need more than an airspeed indicator
to make a safe landing? I would not consider the iPad a critical piece
of flight instrumentation even if it were the only thing on the panel
other than an airspeed indicator and maybe an RPM gauge.
My half cents, fwiw,
-Dj
Dj Merrill - N1JOV - EAA Chapter 87
Sportsman 2+2 Builder #7118 N421DJ - http://deej.net/sportsman/
Glastar Flyer N866RH - http://deej.net/glastar/
Tim Olson
Posted: Thu Jun 18, 2015 7:18 am Post subject: iPad in the Cockpit |
Heck, I'll take it one step further....
For a VFR aircraft, I personally think you should be able to make a safe
landing with NO instruments, including an airspeed indicator.
I've been teaching one of the kids to land lately and I often only
give them engine gauges to go off of, and she does fine. It's
funny how close you can be to the right speed once you've
practiced, without any instrumentation. As far as I'm concerned,
the instruments are there just as guidance. A practiced pilot should
have enough feel to safely land a single engine plane.
Tim
On 6/18/2015 9:28 AM, Dj Merrill wrote:
-Dj
handainc(at)madisoncounty Guest
Posted: Thu Jun 18, 2015 7:55 am Post subject: iPad in the Cockpit |
That is the way I was trained by an old navy instructor. Had sticky
pads in his pocket and would start covering instruments until I could
set engine rpm's by sound, air speed by feel and sound, and recognize
change in attitude by both sounds and feel. But that really has little
to do with using an iPad as a navigation aid.....I say aid, as I always
have a chart as backup, and constantly check what the electronics say as
compared to my compass and DG, although DG's can precess and be off a
lot if they are starting to fail or well worn. The other thing is,
compared to a panel mount Garmin unit that would give you a moving map
display, with the subscription costs on top of the installation costs, I
can easily buy a second iPad and 2nd ForeFlight subscription for backup
if I were too lazy to finish a trip with chart and dead reckoning. It
is hard enough to afford flying for many of us in the best of
conditions, and more power to those that can afford the higher dollar
solutions.....I certainly don't begrudge anyone a higher financial
standard in any endeavor. But for my uses, the iPad is a good solution
that I can reasonably afford. Everything is a trade off, and any
electronic device can fail. Knowing your limits, the limits of your
equipment, and planning for the failure is the key to being safe in
flying, or in any form of transportation.
M. Haught
On 6/18/2015 10:17 AM, Tim Olson wrote:
Tim
>> piece of
> -Dj
fedico94(at)mchsi.com Guest
Posted: Thu Jun 18, 2015 7:17 pm Post subject: iPad in the Cockpit |
My intention is to show the rapid progress in digital avionics. You can buy an HP laptop for 449 dollars and one for 1800 dollars. Same specs but the 1800 dollar is built to police and military specification for temperature extremes and vibration. Samsung had the Galaxy S and Apple had one of the iPads tested to meet FAA EFB requirements. My G3X has operated in extremes of Iowa weather and has had no problems. Lighter Smarter and lower cost in the future. Think about the DME you had in 1960 compared to today in terms of cost, weight and size.
BobsV35B(at)aol.com Guest
Posted: Fri Jun 19, 2015 4:04 am Post subject: iPad in the Cockpit |
Good Morning M. Haught,
Very well put.
Happy Skies,
Old Bob
glastar(at)gmx.net Guest
Posted: Fri Jun 19, 2015 6:27 am Post subject: iPad in the Cockpit |
The iPad 2 is generating much less heat then the mini iPad or iPad3.
That will influence usability
Cheers Werner
On 18.06.2015 16:28, Dj Merrill wrote:
ceengland7(at)gmail.com Guest
Posted: Fri Jun 19, 2015 6:46 am Post subject: iPad in the Cockpit |
I don't think internal heat generation is the issue; it's heat gain
(absorption) due to exposure to sunlight on the black screen.
Having said that, losing basic flight instruments on a VFR day in bright
sunlight shouldn't be too much of a problem. Losing nav info might be a
bit bigger deal if on a cross country, but should be recoverable by just
moving the device out of the sun until it cools down. Besides, a backup
nav device is as simple as a smart phone.
Charlie
On 6/19/2015 9:26 AM, Werner Schneider wrote:
<glastar(at)gmx.net>
Cheers Werner
Posted: Fri Jun 19, 2015 7:50 am Post subject: iPad in the Cockpit |
I could not be more pleased with my iPad 2, for general use or in the cockpit. Bought it used from a guy trading up when the iP3 came out, and it has been flawless. Good battery life, everything works well and will hook up with my piece of crap iMac, and interfaces on various apps with my iPhone perfectly. It will be a sad day when I have to “trade up” because I suspect that anything that replaces it will not be nearly as good as it has been. My iPhone had it’s trepidations, and had to be replaced twice when new because the battery would not hold a charge and got really hot, but the last one has been good. So I read reviews about the newer iterations in anticipation of having to replace either of them and hope I can put off the change as long as possible. Still, I think the cooling issues can be mitigated. Like any other piece of equipment, you just have to deal with the particular operating characteristics of each to maximize the usability. Due to my “old eyes” I favor the larger of the display screens available, which can create space and layout issues.
M. Haught
| Quote: | On Jun 19, 2015, at 9:26 AM, Werner Schneider <glastar(at)gmx.net> wrote:
Cheers Werner
JOHN TIPTON
Joined: 17 Sep 2006 Posts: 239 Location: Torquay - England
Posted: Fri Jun 19, 2015 10:18 am Post subject: iPad in the Cockpit |
Here's how I use my iPad: oh yes: that's my four year old grandson co-pilot
John
----x--O--x----
| Quote: | On 19 Jun 2015, at 04:49 pm, "H. Marvin Haught" <handainc(at)madisoncounty.net> wrote:
I could not be more pleased with my iPad 2, for general use or in the cockpit. Bought it used from a guy trading up when the iP3 came out, and it has been flawless. Good battery life, everything works well and will hook up with my piece of crap iMac, and interfaces on various apps with my iPhone perfectly. It will be a sad day when I have to “trade up” because I suspect that anything that replaces it will not be nearly as good as it has been. My iPhone had it’s trepidations, and had to be replaced twice when new because the battery would not hold a charge and got really hot, but the last one has been good. So I read reviews about the newer iterations in anticipation of having to replace either of them and hope I can put off the change as long as possible. Still, I think the cooling issues can be mitigated. Like any other piece of equipment, you just have to deal with the particular operating characteristics of each to maximize the usability. Due to my “old eye!
M. Haught
> Cheers Werner
264 KB |
9652 Time(s) |
Posted: Fri Jun 19, 2015 10:44 am Post subject: iPad in the Cockpit |
Great photo! That’s the way to get them started!
Marv
| Quote: | On Jun 19, 2015, at 1:16 PM, John Tipton <jmtipton(at)btopenworld.com> wrote:
<image.jpeg>
John
----x--O--x----
> M. Haught
>> Cheers Werner
</b></font></pre>
Tim Olson
Posted: Fri Jun 19, 2015 10:56 am Post subject: iPad in the Cockpit |
If you like the 2 you'll really like the air/air2 also some day.
Tim
| Quote: | On Jun 19, 2015, at 9:49 AM, H. Marvin Haught <handainc(at)madisoncounty.net> wrote:
M. Haught
> Cheers Werner
stuart(at)stuarthutchison Guest
Posted: Fri Jun 19, 2015 11:18 am Post subject: iPad in the Cockpit |
Like anything electronic, the iPad generates its own heat and requires cooling airflow. Vertical mount lends itself to effective cooling as the heat rises away from the device, but carrying it on your lap or in a knee mount in direct sunlight in thin air makes cooling even harder. I’ve seen a horizontally mounted iPad overheat and shut down in under 20 min in a Lancair IV at 18000.
Food for thought. If you can, point the punkah louver at it.
Cheers, Stu
| Quote: | On 19 Jun 2015, at 22:42, H. Marvin Haught <handainc(at)madisoncounty.net (handainc(at)madisoncounty.net)> wrote:
--> AeroElectric-List message posted by: "H. Marvin Haught" <handainc(at)madisoncounty.net (handainc(at)madisoncounty.net)>Great photo! That’s the way to get them started! Marv | Quote: | On Jun 19, 2015, at 1:16 PM, John Tipton <jmtipton(at)btopenworld.com (jmtipton(at)btopenworld.com)> wrote:<image.jpeg>Here's how I use my iPad: oh yes: that's my four year old grandson co-pilotJohnSent from my iPad ----x--O--x---- | Quote: | | On 19 Jun 2015, at 04:49 pm, "H. Marvin Haught" <handainc(at)madisoncounty.net (handainc(at)madisoncounty.net)> wrote:--> AeroElectric-List message posted by: "H. Marvin Haught" <handainc(at)madisoncounty.net (handainc(at)madisoncounty.net)>I could not be more pleased with my iPad 2, for general use or in the cockpit. Bought it used from a guy trading up when the iP3 came out, and it has been flawless. Good battery life, everything works well and will hook up with my piece of crap iMac, and interfaces on various apps with my iPhone perfectly. It will be a sad day when I have to “trade up” because I suspect that anything that replaces it will not be nearly as good as it has been. My iPhone had it’s trepidations, and had to be replaced twice when new because the battery would not hold a charge and got really hot, but the last one has been good. So I read reviews about the newer iterations in anticipation of having to replace either of them and hope I can put off the change as long as possible. Still, I think the cooling issues can be mitigated. Like any other piece of equipment, you just have to deal with the particular operating characteristics of each to maximize the usability. Due to my “old ! |
| eye! | Quote: | | Quote: | s” I favor the larger of the display screens available, which can create space and layout issues. M. Haught | Quote: | On Jun 19, 2015, at 9:26 AM, Werner Schneider <glastar(at)gmx.net (glastar(at)gmx.net)> wrote:--> AeroElectric-List message posted by: Werner Schneider <glastar(at)gmx.net (glastar(at)gmx.net)>The iPad 2 is generating much less heat then the mini iPad or iPad3.That will influence usability ;)Cheers Werner | Quote: | On 18.06.2015 16:28, Dj Merrill wrote:--> AeroElectric-List message posted by: Dj Merrill <deej(at)deej.net (deej(at)deej.net)> | Quote: | | On 06/18/2015 08:57 AM, Owen Baker wrote:On a normally warm yesterday my iPad mini 2 with WingX Pro 7, held incockpit space by a Ram mount, gave up and said words to the effect: "Iam suffering from heat exhaustion and will have to rest for a while." | On the flip side of that, I have an iPad 2 running WingX mounted on thepanel of my Glastar using a RAM mount, and have had no issues in usingit, going on 4 years now. |
| ================================================================================================================================================<pre><b><font size=2 color="#000000" face="courier new,courier"></b></font></pre> | http://www.matronics.com/Navigator?AeroElectric-Listhttp://forums.matronics.comhttp://www.matronics.com/contribution
