rvdave
Posted: Sun Jun 14, 2015 3:13 pm Post subject: Comm antenna on top |
I've noticed some have straight/angled antenna on top near vert stab, is this off centered or drilled through top stringer? Not sure how to go about that?
If directly centered and 1/2" hole for bnc does that compromise strength of stringer ( maybe not)? Also how to install a doubler in that area?
_________________ Dave Ford
Cadillac, MI |
Kellym
Posted: Sun Jun 14, 2015 3:56 pm Post subject: Comm antenna on top |
Recommend that you not try to center it, but use the stiffener already
present with a doubler or add stiffener to doubler. No one will notice
that you are a 1/4" off center.
On the other hand I have had good performance from belly antennas, even
when on the ground.
On 6/14/2015 4:13 PM, rvdave wrote:
Dave Ford
RV6 for sale
RV10 building
Cadillac, MI
http://forums.matronics.com/viewtopic.php?p=443532#443532
KCHD |
Posted: Sun Jun 14, 2015 3:57 pm Post subject: Comm antenna on top |
Why would you want to do this?
Two bent whip comm antennas on the bottom is much less of an eyesore.
Carl
rvdave
Posted: Sun Jun 14, 2015 4:21 pm Post subject: Re: Comm antenna on top |
I know from my 6 with two belly antennae I get marginal coverage on the ground but great air coverage; also I'm considering future belly pod.
Cadillac, MI |
philperry9
Posted: Sun Jun 14, 2015 11:17 pm Post subject: Comm antenna on top |
As Kelly said, they can be offset to miss the stringer and still installed parallel with the airflow for minimal drag.
I built mine that way using a doubler on the inside of the skin and picking up the rivets on the stringer to strengthen the doubler.
I had to put a joggle in the doubler to do it, but there are other ways to pickup those rivets too. Just have to get a bit creative.
Phil
| Quote: | On Jun 14, 2015, at 7:21 PM, rvdave <rv610dave(at)gmail.com> wrote:
Dave Ford
RV6 for sale
RV10 building
Cadillac, MI
http://forums.matronics.com/viewtopic.php?p=443538#443538
bill.peyton
Joined: 19 Sep 2010 Posts: 198 Location: St. Louis, MO
Posted: Mon Jun 15, 2015 5:08 am Post subject: Re: Comm antenna on top |
At my airport the tower is far enough away that a bottom mounted antenna just would not cut it. I have a top mount and bottom mount.
Here is a photo of the doubler I constructed spanning the two stringers. What is missing in this photo is the tapered wedge that goes between the skin and the doubler. The antenna mounting bolts go through the skin, the tapered wedge, and the doubler.
The skin is not flat at this point and if you attach a doubler directly to the skin it will flatten the curved area of the skin.
77.23 KB |
10725 Time(s) |
_________________ Bill
WA0SYV
Aviation Partners, LLC |
john(at)trollingers.com Guest
Posted: Mon Jun 15, 2015 5:28 am Post subject: Comm antenna on top |
I have both my antennas on the belly of my 10 and have never had a problem reaching anyone on the ground. They do stick out a little on each side as I have them back behind the steps.
John
On Mon, Jun 15, 2015 at 9:08 AM, bill.peyton <peyton.b(at)sbcglobal.net (peyton.b(at)sbcglobal.net)> wrote:
[quote]--> RV10-List message posted by: "bill.peyton" <peyton.b(at)sbcglobal.net (peyton.b(at)sbcglobal.net)>
Bill
WA0SYV
http://forums.matronics.com/viewtopic.php?p=443558#443558
http://forums.matronics.com//files/img_1263_169.jpg
Posted: Mon Jun 15, 2015 7:41 am Post subject: Comm antenna on top |
Not to argue the point as one can build as they wish. For the others reading this thread and perhaps now worry about bottom mounted antenna performance, my experience is the same as John’s. I’ve never had an issue with the bottom mounted bent whip communication antennas. A specific data point was picking up my IFR clearance on the ground at KSET from St. Louis Approach located well off field.
Carl
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of John Trollinger
Sent: Monday, June 15, 2015 9:25 AM
Subject: Re: Re: Comm antenna on top
John
Bill
WA0SYV
| Quote: | | http://www.matronics.com/Navigator?RV10-List | 01234567
rene(at)felker.com Guest
Posted: Mon Jun 15, 2015 7:52 am Post subject: Comm antenna on top |
I had problems at KSLC on 118.3. I ended up moving one of my comm antennas to the top.
Rene'
801-721-6080
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Carl Froehlich
Sent: Monday, June 15, 2015 9:38 AM
Subject: RE: Re: Comm antenna on top
Carl
From: owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com) [mailto:owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com)] On Behalf Of John Trollinger
John
Bill
WA0SYV
012345678901234567
bcondrey
Posted: Mon Jun 15, 2015 8:06 am Post subject: Comm antenna on top |
This is a recurring theme that pops its head up every few months. Most have no issues at all with a pair of bent whips on the bottom, however most is not all. It is usually also pointed in somewhere in the recurring thread that in those rare instances where there's an issue you can just use a cell phone. That said, I have personally experienced the issue and one of the things I'm doing different on this plane (2nd RV-10) is putting one on top and one on bottom. To each their own.
Bob
On Mon, Jun 15, 2015 at 10:38 AM, Carl Froehlich <carl.froehlich(at)verizon.net (carl.froehlich(at)verizon.net)> wrote:
Carl
John
Bill
WA0SYV
01234567
8
rv10flyer
Posted: Fri Jun 19, 2015 6:17 pm Post subject: Re: Comm antenna on top |
One on top of our fiberglass cabin cover and one under the tunnel. When I have reception issues with one, I switch to the other. I'd do it all the same again.
_________________ Wayne G. |
