Essential Bus feed
JOHN TIPTON
PostPosted: Thu Jun 04, 2015 12:44 am    Post subject: Essential Bus feed Reply with quote
Hi Guys
Am I missing something: Why can't the feed to the Essential Bus be a simple changeover switch (1-3) to select which source you require the power to come from, thus eliminating the diode
Regards: John
PostPosted: Thu Jun 04, 2015 5:24 am    Post subject: Re: Essential Bus feed Reply with quote
That switch would be a single point of failure. When it fails, essential equipment is lost. Having both a diode and a switch provides two current paths.
Joe
Joe Gores
Tim Olson
PostPosted: Thu Jun 04, 2015 6:07 am    Post subject: Essential Bus feed Reply with quote
Also, if it's on a switch, unless it's a progressive switch,
you will drop power to the bus when it is in between positions,
so everything will reboot that it powers. YOu CAN use a switch
or relay depending on the load, but you would still want the
diode. That way it gets power whenever there is source
power. The difference would be that when the switch is
in the proper position you wouldn't have any diode drop.
But it adds more complexity.
Tim
Joe
Joe Gores
kjashton(at)vnet.net
PostPosted: Thu Jun 04, 2015 7:30 am    Post subject: Essential Bus feed Reply with quote
In my setup, I took a multi-fuse Bussman fuse block (pic) and cut the interior center conductor to create a main bus and essential bus. I silver-soldered a copper tab on the smaller essential bus side of the center conductor (left side in the pic) to wire battery power to the essential bus through an “essential bus” switch which is normally off. The main bus provides power to the essential side through a diode and all is powered. In an emergency, I can turn off the master switch and power the essential bus via the essential bus switch. Sorry, don’t have a better pic but you get the idea, I hope-Kent
On Jun 4, 2015, at 9:24 AM, user9253 <fransew(at)gmail.com (fransew(at)gmail.com)> wrote:--> AeroElectric-List message posted by: "user9253" <fransew(at)gmail.com (fransew(at)gmail.com)>
[img]cid:C8973942-4409-4FC8-BF2F-7CB6BA4EA7E9[/img]
 Filesize:  103.15 KB
 Viewed:  3221 Time(s)
