Active VOR antenna
berkut13(at)berkut13.com
PostPosted: Mon Jun 01, 2015 6:39 am    Post subject: Active VOR antenna Reply with quote
Hi Bob,
I hate to be a nag, but our DAR inspection is tomorrow and I'll be starting
ground/flight tests after that. How's the antenna coming?
Thanks!
-James
PostPosted: Thu Jun 04, 2015 2:31 pm    Post subject: Active VOR antenna Reply with quote
Jim, finished one of these and was disappointed in performance.
The thing is so tiny that it's hard to troubleshoot,
assembled a second just in case.
I think the best plan-b for now is to install
a quasi-sleeve dipole . . . except that the 'sleeve'
is just a piece of wire. I forget how long you said
your antenna conduit was, hopefully considerably
more than 26".
Make the antenna from wire stiff enough to push
into the tube on the end of the coax. Wouldn't
put a connector in the counterpoise. Just thread
it to the ship's interior on installation and tape
it sort out of the way.
[img]cid:7.1.0.9.0.20150604171916.071ec8a0(at)aeroelectric.com.1[/img]
I've got a couple other antenna projects on the bench
but some buys waving credit cards have purchased some
keyboard/hammer-n-tongs time . . . and I've got a couple
of pots boiling for B&C. I'd like to pursue the
active antenna experiment. It would be useful to field
test the idea in close proximity to transponder and
vhf/comm transmitters!
In the mean time, let's get your airplane flying.
 Filesize:  117.41 KB
 Viewed:  2437 Time(s)
PostPosted: Thu Jun 04, 2015 6:16 pm    Post subject: Active VOR antenna Reply with quote
Thanks for the reply and progress report. I was really hoping for a successful test, but yes...the immediate goal is getting the bird through Phase I.
The conduit is sufficient to install what you have described below. Maybe that will be enough?..I guess we’re going to find out one way or another.
I’ll report back with what we find in the coming weeks.
Thanks again.
-James
From: Robert L. Nuckolls, III (nuckolls.bob(at)aeroelectric.com)
Sent: Thursday, June 04, 2015 5:26 PM
Subject: Re: Active VOR antenna
more than 26".
[img]cid:28BD7EC4E50C43F8B64CADBD67A51D6F(at)DEFIANT2600[/img]
