ccoulter(at)wavecable.com Guest
Posted: Wed May 21, 2014 5:36 pm Post subject: [Pulsar-Aviators] Nose gear failure |
Interested but am not a member of the yahoo net.
Clarke
On Mon, 5 May 2014 15:20:39 -0500
"Tim Engel" <TSEngel(at)comcast.net> wrote:
I've created a folder in the Pulsar-Aviators Files
section titled:
Pulsar XP - Nose Gear Modifications
http://tinyurl.com/lmf5zxh
There are three files in it:
1) Pulsar III - SkyStar Nose Wheel Exploded Parts
.... SkyStar's Pulsar III Nose Gear Design for
Comparison
2) Pulsar XP - Nose Gear Modification - Drawing, Bob
3) Pulsar XP - Nose Gear Modification - Smith-Hartunian,
Koval.doc
The first is just an exploded parts diagram of the
SkyStar Pulsar III nose gear design for comparison.
Something supporting a similar weight FWF package
without breaking.
I believe the second file is the modification drawing
done by Bob Hartunian and Greg Smith that Herbert
inquired about.
The third is a Word.doc I threw together from clippings
of posts on Pulsar-Aviators about the Greg Smith/ Bob
Hartunian modification, and the similar but different mod
done by Ron Koval. It's a rough 1st Draft. I've not
designed anything, and don't claim to have any answers,
but I'm hoping Greg, Bob and Ron, and anyone else who
has done a similar modification will proof read it and
offer additional content. With enough input, perhaps we
can come up with a go-to document that owners can
reference when, or hopefully before the need arises.
I'll do the keyboard work to put together the Word.doc,
if that's what it takes. But I need some input...
like, "All" the input.
If you suggest a change or addition, then flesh it out.
Don't suggest a vague idea like you think I'm going to
design it. Won't happen. I'll try to collate the
document to include the good design work and execution of
others, "IF" they're okay with that; but I'm in no
position to design an aircraft landing gear. If I did,
you wouldn't want it on your plane!
In that Word.doc, I included a few questions that came
to mind before I even started writing. Let's start
there, plus anything else you think of.
1) Are all new 4130 steel parts to be used without
additional heat treating/ stress relieving? Bob?
2) The Pulsar XP nose gear design used a alternating
stack of 6 Belleville Spring Washers, sandwiched between
two thrust washers. I don’t see the Belleville washers
documented in the Smith/ Hartunian design, but Ron Koval
at least mentions them (ie, says he has extras for sale).
Are the Belleville washers still used in either or both
of those designs? For now, I’ve included them in the
"Materials" lists.
2) Skystar’s Pulsar III nose gear design appears to use
two “top hat” bushings in the vertical “Sleeve” (boss/
trunnion), one top and
one bottom. Do your designs do anything about friction
other than a little lubrication?
3) Any thoughts on a recommended torque value to use
when assembling the new pivot?
Tim Engel
To: pulsar-list(at)matronics.com;
Pulsar-Aviators(at)yahoogroups.com
Sent: Saturday, May 3, 2014 8:42 AM
Subj: [Pulsar-Aviators] Nose gear failure
Clarke Coulter just reported his nose gear failed on
take off. His landing was uneventful but the plane did
sustain damage. His nose gear is the Aerodesigns gear
with the spindle shaft welded inside a collar. Since the
failure is occurring inside the collar, there is no way
to inspect.
If you have one of these nose gears you should look on
the forum to see what modifications others have done to
make this area stronger and easy to inspect. It could
save you from having to rebuild your aircraft.
Un/Subscription,
Forums!
Admin.
docyukon(at)ptcnet.net Guest
Posted: Wed May 21, 2014 6:09 pm Post subject: [Pulsar-Aviators] Nose gear failure |
Clark Was thair a prop strike on landing, also was thair any fuselodge
structual damage other than the firewall and lower cawel. Bill S.
TomisFlyingby(at)comcast. Guest
Posted: Wed May 21, 2014 7:26 pm Post subject: [Pulsar-Aviators] Nose gear failure |
Ron,
I know this is really late but do you still have any of the nose gear modification parts left? Where did you have yours done?
Tom
Sent: Monday, May 05, 2014 10:00 AM
To: Pulsar-Aviators(at)yahoogroups.com (Pulsar-Aviators(at)yahoogroups.com) ; Pulsar Builders (Pulsar-List(at)matronics.com)
Subject: Re: [Pulsar-Aviators] Nose gear failure
Having done modification last year, I still have about 7 inches left over (you only need about 3-1/2") from the Aircraft Spruce purchase of 4130 STEEL TUBE 1X.188 1FT
Part #: 03-06800-1 to make this modification (along with your own 5/8" bolt, etc.). $5 plus shipping cost, its yours. Add another $5 and I'll include 2 brand new belleville washers.
Ronko
To: pulsar-list(at)matronics.com; Pulsar-Aviators(at)yahoogroups.com
Subject: [Pulsar-Aviators] Nose gear failure
Clarke Coulter just reported his nose gear failed on take off. His landing was uneventful but the plane did sustain damage. His nose gear is the Aerodesigns gear with the spindle shaft welded inside a collar. Since the failure is occurring inside the collar, there is no way to inspect.
If you have one of these nose gears you should look on the forum to see what modifications others have done to make this area stronger and easy to inspect. It could save you from having to rebuild your aircraft.
__._,_.___
Reply to sender ([email]GREGSMI(at)aol.com?subject=Re%3A%20Nose%20gear%20failure[/email]) • Reply to group ([email]Pulsar-Aviators(at)yahoogroups.com?subject=Re%3A%20Nose%20gear%20failure[/email]) • Start a New Topic • Messages in this topic (1)
Visit Your Group
Unsubscribe ([email]Pulsar-Aviators-unsubscribe(at)yahoogroups.com?subject=Unsubscribe[/email]) • Terms of Use
[img]http://geo.yahoo.com/serv?s=97359714/grpId=13031253/grpspId=1705786083/msgId=6113/stime=1399124546[/img] [img]http://y.analytics.yahoo.com/fpc.pl?ywarid=515FB27823A7407E&a=10001310322279&js=no&resp=img[/img] __,_._,___
#yiv9035144893 #yiv9035144893 -- #yiv9035144893ygrp-mkp { border:1px solid #d8d8d8;font-family:arial;margin:10px 0;padding:0 10px;} #yiv9035144893 #yiv9035144893ygrp-mkp hr { border:1px solid #d8d8d8;} #yiv9035144893 #yiv9035144893ygrp-mkp #yiv9035144893hd { color:#628c2a;font-size:85%;font-weight:700;line-height:122%;margin:10px 0;} #yiv9035144893 #yiv9035144893ygrp-mkp #yiv9035144893ads { margin-bottom:10px;} #yiv9035144893 #yiv9035144893ygrp-mkp .yiv9035144893ad { padding:0 0;} #yiv9035144893 #yiv9035144893ygrp-mkp .yiv9035144893ad p { margin:0;} #yiv9035144893 #yiv9035144893ygrp-mkp .yiv9035144893ad a { color:#0000ff;text-decoration:none;} #yiv9035144893 #yiv9035144893ygrp-sponsor #yiv9035144893ygrp-lc { font-family:arial;} #yiv9035144893 #yiv9035144893ygrp-sponsor #yiv9035144893ygrp-lc #yiv9035144893hd { margin:10px 0px;font-weight:700;font-size:78%;line-height:122%;} #yiv9035144893 #yiv9035144893ygrp-sponsor #yiv9035144893ygrp-lc .yiv9035144893ad { margin-bottom:10px;padding:0 0;} #yiv9035144893 #yiv9035144893actions { font-family:verdana;font-size:11px;padding:10px 0;} #yiv9035144893 #yiv9035144893activity { background-color:#e0ecee;float:left;font-family:verdana;font-size:10px;padding:10px;} #yiv9035144893 #yiv9035144893activity span { font-weight:700;} #yiv9035144893 #yiv9035144893activity span:first-child { text-transform:uppercase;} #yiv9035144893 #yiv9035144893activity span a { color:#5085b6;text-decoration:none;} #yiv9035144893 #yiv9035144893activity span span { color:#ff7900;} #yiv9035144893 #yiv9035144893activity span .yiv9035144893underline { text-decoration:underline;} #yiv9035144893 .yiv9035144893attach { clear:both;display:table;font-family:arial;font-size:12px;padding:10px 0;width:400px;} #yiv9035144893 .yiv9035144893attach div a { text-decoration:none;} #yiv9035144893 .yiv9035144893attach img { border:none;padding-right:5px;} #yiv9035144893 .yiv9035144893attach label { display:block;margin-bottom:5px;} #yiv9035144893 .yiv9035144893attach label a { text-decoration:none;} #yiv9035144893 blockquote { margin:0 0 0 4px;} #yiv9035144893 .yiv9035144893bold { font-family:arial;font-size:13px;font-weight:700;} #yiv9035144893 .yiv9035144893bold a { text-decoration:none;} #yiv9035144893 dd.yiv9035144893last p a { font-family:verdana;font-weight:700;} #yiv9035144893 dd.yiv9035144893last p span { margin-right:10px;font-family:verdana;font-weight:700;} #yiv9035144893 dd.yiv9035144893last p span.yiv9035144893yshortcuts { margin-right:0;} #yiv9035144893 div.yiv9035144893attach-table div div a { text-decoration:none;} #yiv9035144893 div.yiv9035144893attach-table { width:400px;} #yiv9035144893 div.yiv9035144893file-title a, #yiv9035144893 div.yiv9035144893file-title a:active, #yiv9035144893 div.yiv9035144893file-title a:hover, #yiv9035144893 div.yiv9035144893file-title a:visited { text-decoration:none;} #yiv9035144893 div.yiv9035144893photo-title a, #yiv9035144893 div.yiv9035144893photo-title a:active, #yiv9035144893 div.yiv9035144893photo-title a:hover, #yiv9035144893 div.yiv9035144893photo-title a:visited { text-decoration:none;} #yiv9035144893 div#yiv9035144893ygrp-mlmsg #yiv9035144893ygrp-msg p a span.yiv9035144893yshortcuts { font-family:verdana;font-size:10px;font-weight:normal;} #yiv9035144893 .yiv9035144893green { color:#628c2a;} #yiv9035144893 .yiv9035144893msonormal { margin:0 0 0 0;} #yiv9035144893 o { font-size:0;} #yiv9035144893 #yiv9035144893photos div { float:left;width:72px;} #yiv9035144893 #yiv9035144893photos div div { border:1px solid #666666;height:62px;overflow:hidden;width:62px;} #yiv9035144893 #yiv9035144893photos div label { color:#666666;font-size:10px;overflow:hidden;text-align:center;white-space:nowrap;width:64px;} #yiv9035144893 #yiv9035144893reco-category { font-size:77%;} #yiv9035144893 #yiv9035144893reco-desc { font-size:77%;} #yiv9035144893 .yiv9035144893replbq { margin:4px;} #yiv9035144893 #yiv9035144893ygrp-actbar div a:first-child { margin-right:2px;padding-right:5px;} #yiv9035144893 #yiv9035144893ygrp-mlmsg { font-size:13px;font-family:arial, helvetica, clean, sans-serif;} #yiv9035144893 #yiv9035144893ygrp-mlmsg table { font-size:inherit;font:100%;} #yiv9035144893 #yiv9035144893ygrp-mlmsg select, #yiv9035144893 input, #yiv9035144893 textarea { font:99% arial, helvetica, clean, sans-serif;} #yiv9035144893 #yiv9035144893ygrp-mlmsg pre, #yiv9035144893 code { font:115% monospace;} #yiv9035144893 #yiv9035144893ygrp-mlmsg * { line-height:1.22em;} #yiv9035144893 #yiv9035144893ygrp-mlmsg #yiv9035144893logo { padding-bottom:10px;} #yiv9035144893 #yiv9035144893ygrp-msg p a { font-family:verdana;} #yiv9035144893 #yiv9035144893ygrp-msg p#yiv9035144893attach-count span { color:#1e66ae;font-weight:700;} #yiv9035144893 #yiv9035144893ygrp-reco #yiv9035144893reco-head { color:#ff7900;font-weight:700;} #yiv9035144893 #yiv9035144893ygrp-reco { margin-bottom:20px;padding:0px;} #yiv9035144893 #yiv9035144893ygrp-sponsor #yiv9035144893ov li a { font-size:130%;text-decoration:none;} #yiv9035144893 #yiv9035144893ygrp-sponsor #yiv9035144893ov li { font-size:77%;list-style-type:square;padding:6px 0;} #yiv9035144893 #yiv9035144893ygrp-sponsor #yiv9035144893ov ul { margin:0;padding:0 0 0 8px;} #yiv9035144893 #yiv9035144893ygrp-text { font-family:georgia;} #yiv9035144893 #yiv9035144893ygrp-text p { margin:0 0 1em 0;} #yiv9035144893 #yiv9035144893ygrp-text tt { font-size:120%;} #yiv9035144893 #yiv9035144893ygrp-vital ul li:last-child { border-right:none !important; } #yiv9035144893
href="http://www.matronics.com/Navigator?Pulsar-List">http://www.matronhref="http://forums.matronics.com">http://forums.matronics.com
Posted: Thu May 22, 2014 7:12 am Post subject: [Pulsar-Aviators] Nose gear failure |
Bill
Yes there was a prop strike. I don't think it damaged the
engine tho. There was a small area of damage to the left
side.
Clarke
On Wed, 21 May 2014 21:08:45 -0500
"Bill S" <docyukon(at)ptcnet.net> wrote:
thair any fuselodge structual damage other than the
Un/Subscription,
Forums!
Admin.
PreCompTech
Joined: 29 Jun 2013 Posts: 16 Location: Scappoose, OR
Posted: Mon Jun 15, 2015 4:09 pm Post subject: Re: [Pulsar-Aviators] Nose gear failure |
What is the required thickness of the Belleville spring washers that are used in the fork assembly?
_________________ Kris Anderson, Owner
Precision Composites Technologies, LLC
509-521-7564
www.precomptech.com |
