PRESSURIZING THE FUEL SYSTEM QUESTION
Bill1200
PostPosted: Sun May 31, 2015 8:18 am    Post subject: PRESSURIZING THE FUEL SYSTEM QUESTION Reply with quote
Prior to engine start, YAK 52, when I prime the system with primer handle turned to left, nothing shows on the fuel pressure gauge except some very minor fluctuation of the needle. Is this normal? Or, should it hold pressure. Engine starts fine, and once running, pressure is in the green.
cerveirapinto(at)gmail.co
PostPosted: Sun May 31, 2015 1:03 pm    Post subject: PRESSURIZING THE FUEL SYSTEM QUESTION Reply with quote
Did you check the right top fuel filter?
2015-05-31 17:18 GMT+01:00 Bill1200 <billdykes52(at)hotmail.com (billdykes52(at)hotmail.com)>:
--> Yak-List message posted by: "Bill1200" <billdykes52(at)hotmail.com (billdykes52(at)hotmail.com)>
http://forums.matronics.com/viewtopic.php?p=442840#442840
List" target="_blank">http://www.matronics.com/Navigator?Yak-List
Pedro Cerveira Pinto
Bill1200
PostPosted: Mon Jun 08, 2015 7:34 am    Post subject: Re: PRESSURIZING THE FUEL SYSTEM QUESTION Reply with quote
where is it located?
PostPosted: Mon Jun 08, 2015 8:56 am    Post subject: PRESSURIZING THE FUEL SYSTEM QUESTION Reply with quote
Just above of the big yellow ball(fuel/water separator) on the right side of the firewallSee images attached
2015-06-08 16:34 GMT+01:00 Bill1200 <billdykes52(at)hotmail.com (billdykes52(at)hotmail.com)>:
http://forums.matronics.com/viewtopic.php?p=443227#443227
 Filesize:  23.24 KB
 Viewed:  7629 Time(s)
 Filesize:  23.57 KB
Bill1200
PostPosted: Wed Jun 10, 2015 5:28 am    Post subject: Re: PRESSURIZING THE FUEL SYSTEM QUESTION Reply with quote
oK, thanks, I'll check it out
