Posted: Sat May 30, 2015 12:26 pm Post subject: Wheel balancer |
The RV-10 is down for inspection, right wing replacement and to fix an
annoying nose gear shimmy. Reading the achieves it was clear that wheel
balancing is a major step to solving nose gear shimmy. I already have the
solid nose gear axle mod.
Finding a wheel balancer proved hard outside of dropping $400 for one from
Aircraft Tool Supply. Tom Doran made this one with some very nice bearings
he had laying around and milled Delrin spacers (he is magic with a mill
machine). It is amazingly sensitive. I tried balancing the nose wheel in
the past with just a horizontal rod to find the heavy spot. Using this rig
I found my previous attempt to be way off. I ended up using six ¼ oz stick
on weights to get the nose wheel to balance. The mains used about three
weights each.
Carl
winmail.dat |
4.22 KB |
629 Time(s) |
bruceflys
davidsoutpost(at)comcast. Guest
Posted: Sun May 31, 2015 5:00 am Post subject: Wheel balancer |
Tim Olson
Posted: Sun May 31, 2015 5:13 am Post subject: Wheel balancer |
I have that same one. It works very well. I'm really surprised how friction free their bearings are. It's real hard to get the balance perfect almost because if you're a perfectionist you can spend a lot of time getting it real precise. But once you get it real close its easy to know you did a good job. The price is right too. Highly recommended. Been using mine now for almost 9 years I think. Glad they're still making them because it looks like it's a one man business.
Tim
kearney
Posted: Sun May 31, 2015 5:21 am Post subject: Wheel balancer |
Hi Bruce
Which kit did you get? Was it the UNIV kit?
Cheers
Les
jchang10
Posted: Sun May 31, 2015 12:23 pm Post subject: Wheel balancer |
http://www.harborfreight.com/motorcycle-wheel-balancing-stand-98488.html
Here is what ive used in the past. The axle sizes are slightly
different. I remember it taking me a while to finally get the nose wheel
balanced correctly. If the plane sits for too long, i will notice it
bounce now and then.
_________________ #40533 RV-10
First flight 10/19/2011
Phase 1 Done 11/26/2011 |
bruceflys
Posted: Mon Jun 01, 2015 4:14 am Post subject: Re: Wheel balancer |
Sorry, Les, but I can't answer. When I bought mine a few years ago, it was offered specifically as an aircraft wheel balancer on a different website. I am unable to relocate it.
_________________ RV-10 UC |
kearney
Posted: Thu Jun 04, 2015 2:54 pm Post subject: Re: Wheel balancer |
Hi Tim
Which model of wheel balancer did you get. I am interested in getting one but am unsure as to which model is appropriate for the standard Van's wheels.
Cheers
Les
Tim Olson
Posted: Thu Jun 04, 2015 6:30 pm Post subject: Wheel balancer |
Here's my writeup from 2008 when I bought it.
http://www.myrv10.com/N104CD/maintenance/20080503/index.html
Tim
On 6/4/2015 5:54 PM, kearney wrote:
Hi Tim
Cheers
Les
kearney
Posted: Thu Jun 04, 2015 6:53 pm Post subject: Re: Wheel balancer |
Hi Tim
As always, many thanks for the veritable fount of information on your site.
Cheers
Les
