Dick Maddux
Posted: Sun May 24, 2015 4:01 am Post subject: 912 rough running below 3000 rpm912 rough running below 3 |
Flynn,
I had that problem once and finally narrowed it down to the carb operating cables. One would stick during throttle reduction causing an imbalance. I replaced the cables and problem solved. I tried to lube them first but that didn't work well.
Just another idea.
Dick Maddux
912UL
Roger Lee
Posted: Sun May 24, 2015 5:32 am Post subject: Re: 912 rough running below 3000 rpm912 rough running below |
Hi Dick,
You're right and one thing we never seem to think about very often on the up front side of an issue. Cables on engines that are getting older or live in humid climates can get a little sticky. Just a little bit of friction from rust, corrosion or even just a slightly bent cable will cause carb unbalance.
_________________ Roger Lee
Tucson, Az.
Rotax Instructor & Rotax IRC
Light Sport Repairman
Cell 520-349-7056 |
vernon11
Posted: Sun May 24, 2015 7:13 am Post subject: 912 rough running below 3000 rpm912 rough running below 3 |
Although it did not show up during the balancing, it is worthwhile looking at it again.
Vernon
Sent: Sunday, May 24, 2015 2:00 PM
To: rotaxengines-list(at)matronics.com (rotaxengines-list(at)matronics.com)
Subject: Re: 912 rough running below 3000 rpm912 rough running below 3
Flynn,
Just another idea.
Dick Maddux
912UL
href="http://www.matronics.com/Navigator?RotaxEngines-List">http://www.matronics.com/Navigator?RotaxEngines-List
flynn elliott
Posted: Sun May 24, 2015 10:11 am Post subject: 912 rough running below 3000 rpm912 rough running below 3 |
Hi Roger, we think we have the cable's covered, but as Vernon said we will
for sure double check.
