Balance weights
Phil B
PostPosted: Sun May 24, 2015 6:22 am    Post subject: Balance weights Reply with quote
About to get my mono wheel weighed and balanced. 2 questions - where is the best place to fix the weights. I thought of fixing some flat sheets of lead to the stern post but wondered if it's strong enough or may be each side of the tail wheel spring.
While I appreciate that each build is different can anyone give me a range of ballast weights I will expect to need. At this stage I don't know whether to cater for 3lbs or 30lbs of ballast.
Thanks in advance.
Phil B
Kit no. 032
Mono wheel Classic with XS fwf.
pjeffers(at)talktalk.net
PostPosted: Sun May 24, 2015 7:08 am    Post subject: Balance weights Reply with quote
Hi Phil,
Very few Europas need any ballast weight at all. Do you ask the question
for a particular reason? If, and only if, you require ballast it will only
be in the order of 1 to 5 lbs. If you need more than that then something is
wrong with your build. Once more, if you require weight, it is normally
fitted to the bolt that secures your tail wheel extension spring (XTW 06) at
the rear of the fuselage.
Pete
hagargs(at)earthlink.net
PostPosted: Sun May 24, 2015 7:17 am    Post subject: Balance weights Reply with quote
One point you want to think of is that you don't want to be carrying around useless weight. The preferred method is to move things around that you need to carry. The typical method is to move the battery forward or aft.
Steve Hagar
Mesa, AZ
davidjoyce(at)doctors.org
PostPosted: Sun May 24, 2015 10:22 am    Post subject: Balance weights Reply with quote
Phil, My inspector and the LAA were entirely happy to have a lead block bolted on to the front of my sternpost - 3 lbs in my instance but they would have accepted more. Have you worked out what the ideal position of your C of G is? - that is one where you can accommodate any sensible combination of crew/fuel/luggage without needing to do calculations?
Regards, David Joyce, GXSDJ
On 2015-05-24 15:22, Phil B wrote: [quote]
--> Europa-List message posted by: "Phil B" <daveporthcawl(at)aol.com (daveporthcawl(at)aol.com)>
Thanks in advance.
Phil B
Kit no. 032
http://forums.matronics.com/viewtopic.php?p=442528#442528
ttp://www.matronics.com/Navigator?Europa-List
ics.com
.matronics.com/contribution
rlborger(at)mac.com
PostPosted: Sun May 24, 2015 11:13 am    Post subject: Balance weights Reply with quote
Phil,
I agree with Peter Jeffers. Really shouldn’t require aft ballast unless you have an unusually heavy engine. Try moving the battery first as you don’t want to haul around dead weight unless absolutely necessary.
Blue skies & tailwinds,
Bob Borger
Europa XS Tri, Rotax 914, Airmaster C/S Prop (85 hrs).
3705 Lynchburg Dr.
Corinth, TX 76208-5331
Cel: 817-992-1117
rlborger(at)mac.com
Thanks in advance.
Phil B
Kit no. 032
PostPosted: Sun May 24, 2015 1:50 pm    Post subject: Balance weights Reply with quote
Steve, There is the point that a forward battery saves a fair bit of weight and gives limited resistance = better starting, very easy fixing & easier access. I suspect that I saved the 3 lbs that I attached to my stern post, in shorter heavy duty cable length and not having to construct a rear battery box, so I may well have broken even on the weight calculation. Regards, David Joyce, GXSDJ
On 2015-05-24 16:16, Steve Hagar wrote: [quote] [quote]--> Europa-List message posted by: Steve Hagar <hagargs(at)earthlink.net (hagargs(at)earthlink.net)> One point you want to think of is that you don't want to be carrying around useless weight. The preferred method is to move things around that you need to carry. The typical method is to move the battery forward or aft. Steve Hagar Mesa, AZ --
Duncan McFadyean
PostPosted: Sun May 24, 2015 11:27 pm    Post subject: Balance weights Reply with quote
I had 14 lbs of lead bolted to the old tailwheel mount at one point; the 1" 'railway' bolt that held it weighed >1lb alone.
The LAA didn't blink.
Duncan McF.
PostPosted: Mon May 25, 2015 11:32 am    Post subject: Balance weights Reply with quote
Hi Duncan,
I find it hard to imagine what on earth you had fitted up front to justify 14 lbs at the tail.?
Pete
From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of ami-mcfadyean(at)talktalk.net
Sent: 25 May 2015 08:26
Subject: Re: Balance weights
Duncan McF.
paul.the.aviator(at)gmail
PostPosted: Mon May 25, 2015 7:17 pm    Post subject: Balance weights Reply with quote
My 914 needed 4 lbs in the tail but I never did put it in. Over the years I
slowly moved the C of G by moving the battery back, taking weight out of the
tail and generally putting the airplane on a diet. What I did find though
as the more I moved the C of G back the more difficult the airplane was to
handing in the landing/ground roll .... This makes sense of course, but it
was noticeable.
Fred Klein
PostPosted: Tue May 26, 2015 2:52 pm    Post subject: Balance weights Reply with quote
Paul…would you be willing to lay some numbers on your thoughts expressed below?…Fred
On May 25, 2015, at 8:15 PM, Paul McAllister <paul.the.aviator(at)gmail.com> wrote:
was noticeable.
JonathanMilbank
PostPosted: Wed May 27, 2015 1:52 pm    Post subject: Re: Balance weights Reply with quote
When my Classic beauty was still a mono/tail/wheel, I did move the battery from engine bay to rear fuselage immediately behind the flap cross-tube. This was due to a misunderstanding about the datum point and a year or so later I moved the battery forward again.
As has already been stated, moving the C of G aft makes a very noticeable difference to ground handling in a mono-wheel especially during the landing roll-out. It felt decidedly more inclined to ground-loop and I was relieved to discover my fundamental blunder in calculations, which allowed me to move the battery forward again, a year later.
I believe that you should arrange things to have the C of G at the forward limit with two heavies in the seats, nothing in the baggage bay and almost no fuel. It really does improve the feeling of security, based on about 800 hours as a mono with battery forward and about 50 hours with battery aft.
