Posted: Sat May 23, 2015 11:45 am Post subject: Fwd: TAS Calculator.xlsx |
See below.
Jesse Saint
Saint Aviation, Inc.
352-427-0285
Begin forwarded message:
| Quote: | Not sure if this is the one he is looking for, but it's what we used and seemed about right.
TAS_Calculator.xlsx |
7.64 KB |
527 Time(s) |
flysrv10(at)gmail.com Guest
Posted: Sat May 23, 2015 11:58 am Post subject: Fwd: TAS Calculator.xlsx |
Thanks Jesse. I was looking for indicated airspeed calculation. I have two sources of AS and they are 10+ kt different.
On May 23, 2015, at 3:42 PM, Jesse Saint <jesse(at)saintaviation.com (jesse(at)saintaviation.com)> wrote:
[quote]See below.
Jesse Saint
352-427-0285
<TAS Calculator.xlsx>
Tim Olson
Posted: Sat May 23, 2015 2:42 pm Post subject: Fwd: TAS Calculator.xlsx |
I don't think you can very accurately calculate indicated airspeed. The best way to check that is on the bench. That's the reference for all the others.
If indicated is off, it's time to use the manometer and figure out which one is accurate.
Tim
On May 23, 2015, at 2:55 PM, Flysrv10 <flysrv10(at)gmail.com (flysrv10(at)gmail.com)> wrote:
[quote]Thanks Jesse. I was looking for indicated airspeed calculation. I have two sources of AS and they are 10+ kt different.
| Quote: | See below.
Jesse Saint
352-427-0285
List"">http://www.matronics.com/Navigator?RV10-List
//forums.matronics.com
n801bh(at)netzero.net Guest
Posted: Sat May 23, 2015 3:50 pm Post subject: Fwd: TAS Calculator.xlsx |
Agreed.....
Easy to do,,, Well tested and accepted data to derive an accurate reading...
http://www.rst-engr.com/rst/articles/KP89JUL.pdf
Ben Haas
N801BH
www.haaspowerair.com
Posted: Sat May 23, 2015 6:12 pm Post subject: Fwd: TAS Calculator.xlsx |
Thanks guys. This article will do.
Kit plane mag had an articles in Feb with a spreadsheet that used gps data to come up with errors. It is called a multipoint gps assisted AS calibration. Do not have subscription to access the file.
Seemed like a good lazy alternative to do it with.
Do not archive.
On May 23, 2015, at 4:43 PM, Ben <n801bh(at)netzero.net (n801bh(at)netzero.net)> wrote:
[quote]Agreed.....
Ben Haas
N801BH
Posted: Sat May 23, 2015 6:15 pm Post subject: Fwd: TAS Calculator.xlsx |
Here is a PDF file with a scale that translates inches of water to knots. This simple rig is very accurate. It also serves to find pitot/static leaks before you have the guy on the clock doing your biannual check.
Carl
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Ben
Sent: Saturday, May 23, 2015 7:44 PM
Subject: Re: Fwd: TAS Calculator.xlsx
Agreed.....
Ben Haas
N801BH
87.08 KB |
9617 Time(s) |
Manometer.pdf |
17.53 KB |
501 Time(s) |
Tim Olson
Posted: Sat May 23, 2015 6:37 pm Post subject: Fwd: TAS Calculator.xlsx |
This is just a guess since I don't read kit planes, but GPS is used along with IAS and pressure/temp to calculate your TAS. I don't think GPS would be much good for calculating IAS unless you knew very precisely the winds you are flying in.
Tim
On May 23, 2015, at 9:09 PM, Flysrv10 <flysrv10(at)gmail.com (flysrv10(at)gmail.com)> wrote:
[quote]Thanks guys. This article will do.
Do not archive.
[quote]Agreed.....
Ben Haas
N801BH
Bob Turner
Posted: Sat May 23, 2015 7:25 pm Post subject: Re: Fwd: TAS Calculator.xlsx |
There are several programs available where you fly 3 different courses, note GPS ground speeds, and the program calculates True airspeed, with the assumption that the wind does not change while you make the measurements. Truth be told, you can do just as well by finding the wind direction (max ground speed), then do a 180 (minimum ground speed), and average the 2 numbers to get TAS. Note the pressure altitude and the OAT, pull out your E6B and change TAS into IAS.
Water manometer is a good place to start, but it won't show static errors.
_________________ Bob Turner
RV-10 QB |
Posted: Sat May 23, 2015 8:12 pm Post subject: Fwd: TAS Calculator.xlsx |
I do a pitot /static test on every third transponder check.. ie, every six years.... The guy has the equipment already set up and it only adds 50 bucks to the bill... And his test rig is certified.....
Well worth it to me... YMMV...
Ben Haas
N801BH
Posted: Wed May 27, 2015 7:04 am Post subject: Fwd: TAS Calculator.xlsx |
Thanks guys for all the resources. My Gimini and AFS don't agree by 10kts so need to do something soon.
Do not archive.
On May 23, 2015, at 9:08 PM, Ben <n801bh(at)netzero.net (n801bh(at)netzero.net)> wrote:
[quote]I do a pitot /static test on every third transponder check.. ie, every six years.... The guy has the equipment already set up and it only adds 50 bucks to the bill... And his test rig is certified.....
Ben Haas
N801BH
Kelly McMullen
Posted: Wed May 27, 2015 9:07 pm Post subject: Fwd: TAS Calculator.xlsx |
Are they both connected to the pitot static system or does one just give you GPS speed? If they use the pitot static, and the plumbing is leak free, there is a calibration issue with one of them.
You can check the airspeed on the ground with a water manometer.
http://www.eaa1000.av.org/technicl/instcal/instcal.htm
On Wed, May 27, 2015 at 7:59 AM, Flysrv10 <flysrv10(at)gmail.com (flysrv10(at)gmail.com)> wrote:
[quote]Thanks guys for all the resources. My Gimini and AFS don't agree by 10kts so need to do something soon.Â
Do not archive.Â
Â
Â
Â
Ben Haas
N801BH
A&P/IA, EAA Tech Counselor
KCHD |
