cjhukill(at)cox.net Guest
Posted: Thu May 21, 2015 6:39 am Post subject: rudder lock |
This is my rudder gust lock. I machined a part that bolts to the aft
bulkhead/vertical stab spar assembly. The eye-bolts protrude thru the skin
and there will be pins that lock the rudder in neutral position when
installed.
Chris Hukill
waiting for the FAA to bless me for flight
82.15 KB |
1832 Time(s) |
139.21 KB |
1832 Time(s) |
