Mounting "things"
PostPosted: Thu May 21, 2015 12:51 pm    Post subject: Mounting "things" Reply with quote
At 07:57 PM 5/20/2015, you wrote:
Hi Bob,
Several years ago, you were liquidating your stock of these little
doodads, and I bought a bunch. Wish I'd bought more, because they're very handy.
I assume you don't have any left to sell. I'm down to my last
half-dozen or so, and am jealously guarding those.
Any idea where you originally got them, or even what "they"
actually called the little beasties?
They came from the 'you name it' bins of a local
industrial surplus store called The Yard. After my
initial studies on their utility, I purchased all
they had. Sold out pretty quickly. They said they
didn't have any more. About a year later, another
bin of them showed up on the dusty racks. Bought all
of those too and sold out. Haven't see any more since.
I've considered fabricating some. Even wrote an article
on DIY Bond Studs for Kitplanes Aug 2013, p78.
I'd like to find a source if possible. Don't need thousands,
but I could probably use a few dozen if I can find them.
My neighbor is looking for some as well.
Just thought I'd check, since your phenomenal memory seems
able to retrieve all kinds of stuff that I'd have long ago forgotten.
Ron Cox
McMaster-Carr has these devices. Not sure I could
manufacture and sell for any less. These should do
the job for you.
[img]cid:.0[/img][/b]
 Filesize:  295.95 KB
 Viewed:  6513 Time(s)
ARGOLDMAN(at)aol.com
PostPosted: Thu May 21, 2015 1:21 pm    Post subject: Mounting "things" Reply with quote
Those are devices made by Rotoloc (rotoloc.com).
They used to be carried by Mcmaste carr but I don't see them in the current online catalog-- perhaps they still have them and the omission was an over site. I used lots of them of various lengths and diameters.
the mfgr should give you a dealer, or at least a distributor.
Rich
In a message dated 5/21/2015 3:53:49 P.M. Central Daylight Time, nuckolls.bob(at)aeroelectric.com writes:
Hi Bob,
Ron Cox
the job for you.
[/b]
ronaldcox
PostPosted: Thu May 21, 2015 1:27 pm    Post subject: Mounting "things" Reply with quote
Thanks, McMaster-Carr has them, as Bob said.  Just ordered some.
They're not identical to the one I was asking about, but will serve the purpose just as well as the "originals".  Probably more substantial, too.
http://www.mcmaster.com/#perforated-base-studs/=xa5g0j
As for Rotaloc (the correct spelling) they do apparently make them.
http://www.rotaloc.com/products/bf/bf_m1_main.html
Thanks to all!
Ron
On Thu, May 21, 2015 at 4:20 PM, <ARGOLDMAN(at)aol.com (ARGOLDMAN(at)aol.com)> wrote:
[quote] Those are devices made by Rotoloc  (rotoloc.com).
Rich
In a message dated 5/21/2015 3:53:49 P.M. Central Daylight Time, nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com) writes:
Hi Bob,
Ron Cox
   the job for you.
Ron Cox
Glasair Super II F/T
Under Construction at C77 - Still just about to fly!
Dave Saylor
PostPosted: Thu May 21, 2015 2:24 pm    Post subject: Mounting "things" Reply with quote
I've had pretty good luck using a flathead screw pointed up through a large-area countersunk washer:
http://www.aircraftspruce.com/catalog/hapages/nas549washers2.php?clickkey=14605
I scratch up the washer with some 80G.  Then dab a little adhesive in the countersink and the bit recess after most of the threads are through.
--Dave
--Dave
KWVI
PostPosted: Thu May 21, 2015 8:11 pm    Post subject: Mounting "things" Reply with quote
--Dave
I fiddled with that process a bit. The biggest 'risk' is
to end up with a stud that is not firmly fastened to its
base. If the builder wishes to use metallic lock nuts on the
stud, it can really ruin your day if the stud twists on its
base after it's glued down to the airframe.
I experimented with several techniques for securing the stud
to the washer that included high strength epoxies under the
head of the stud-screw, in the threads just under the head,
in the threads and under the faying surface of a retaining
nut on the away-side of the washer.
Even sliver soldered a few. Strength was great but finish
was ugly.
I was able to achieve attachments that offered a twist out
resistance about 2x the torque needed to drive the metallic
lock nut. But the process was labor intensive. I didn't think
I could compete well with those parts from McMaster.
If I stumble across any more attractive options, I'll bring
them to the list muy pronto.
Bob . . . [quote][b]
Dave Saylor
PostPosted: Fri May 22, 2015 6:13 am    Post subject: Mounting "things" Reply with quote
I agree, the MMC solution is quick and easy.
FWIW, a few more details:  I was able to find some Hysol in cartridges that looked and smelled like the stuff that comes with clickbonds called Hysol/Loctite 8000.
Also, I recall bending the edge of the washer slightly in 3-4 places with some duckbills. Picture attached.
That prevents squeeze-out of the glue under the washer's flange, and allows for a little cavity between the washer and the screw.
Of course the customer is always right, so they must have had some pretty good glue (insulation?) to justify metal locknuts so close to the adhesive Wink
--Dave
 Filesize:  953.28 KB
 Viewed:  6482 Time(s)
--Dave
KWVI
