flyboy(at)gmail.com Guest
Posted: Sun Apr 19, 2015 6:15 pm Post subject: Fuel Return Line Location? |
We're planning on EFII, so we need a full-sized return line for both
sides. Just now starting work on the fuel tank, and I'd like to get
this sorted before we get too far. I've spent awhile searching, and
have only managed to find lots of places not to put the port for the
fuel return line. Apparently it can interfere with both the wing spar
and the aileron return line. Does anyone have a clear diagram of where
I can safely put it? A hint about which flange/fittings to buy would be
greatly appreciated as well. Thanks in advance!
Berck
jmjones2000(at)mindspring Guest
Posted: Sun Apr 19, 2015 7:08 pm Post subject: Fuel Return Line Location? |
Berck,
I am using an EFII system as well. Just a thought, but I put a normal L/R/Both/Off fuel valve on the supply side (AN6) and an AN6 size return line that Splits to each tank. After the "T" I put a simple Parker petroleum 1/4 turn ball valve on each side just before the tank. Now, I can shut one or the other return valves off, turn on the fuel pump, and transfer fuel on the ground. It can also be done in the air (with caution of course) to trim fuel.
Note: I'm building a Bushcaddy not an rv10.
I can send pics if you would like.
Justin
| Quote: | On Apr 19, 2015, at 18:10, Berck E. Nash <flyboy(at)gmail.com> wrote:
Berck
Dave Saylor
Posted: Sun Apr 19, 2015 7:36 pm Post subject: Fuel Return Line Location? |
Hi Justin,
You are of course free to build whatever fuel system you like, but the one you described has some issues.
I think you'd be better off with a L-R-OFF duplex fuel valve that routes return fuel to the same tank you're burning from. You're headed towards a scenario that makes it pretty easy to mismanage the fuel:
You could return to a full tank and waste fuel overboard;
You could unport an empty tank in "BOTH" and starve the engine;
You could turn off both return valves and...I don't know what, but it seems bad.
Please consider a simpler system. Caution never goes as far as we think it will.
--Dave
On Sun, Apr 19, 2015 at 8:00 PM, Justin Jones <jmjones2000(at)mindspring.com (jmjones2000(at)mindspring.com)> wrote:
[quote]--> RV10-List message posted by: Justin Jones <jmjones2000(at)mindspring.com (jmjones2000(at)mindspring.com)>
Berck,
Justin
> On Apr 19, 2015, at 18:10, Berck E. Nash <flyboy(at)gmail.com (flyboy(at)gmail.com)> wrote:
> --> RV10-List message posted by: "Berck E. Nash" <flyboy(at)gmail.com (flyboy(at)gmail.com)>
> Berck
-List" target="_blank">http://www.matronics.com/Navigator?RV10-List
_________________ --Dave
KWVI |
Bob Turner
Posted: Sun Apr 19, 2015 8:36 pm Post subject: Re: Fuel Return Line Location? |
Since he's building a high wing I don't think unporting on both is an issue.
But I agree with your other comments.
_________________ Bob Turner
RV-10 QB |
Posted: Sun Apr 19, 2015 8:48 pm Post subject: Fuel Return Line Location? |
I'm leaning toward a duplex valve, but I'm also considering two fuel
valves, one for the source and one for the return. This isn't that
different than jets I've flown, and I think I can handle the
"complexity". It's cheaper and it gives the advantage of being able to
transfer fuel, which might come in handy. Regardless, none of the
answers so far tell me where to tap the return line:)
Posted: Sun Apr 19, 2015 8:55 pm Post subject: Fuel Return Line Location? |
Dave,
I understand your concern and welcome any ideas and thoughts that may be cause for issues. The issues you brought up have been considered and here is what I have come up with. Note that I have spoken with many others about this as well, but it doesn’t mean that we aren’t missing something.
The normal configuration (covered on the before take-off checklist) would be both return valves open and the fuel valve on both. The transfer of fuel during refueling operations (while the aircraft is on floats) is one reason for this setup, and the other is the ability to draw fuel from both tanks simultaneously.
“You could return to a full tank and waste fuel overboard” - This scenario could present itself, but would cause an over-pressure situation due to the vent size. The digital engine monitor senses fuel pressure and sounds an audio and visual alarm when it is either too high or too low.
“You could unport an empty tank into “BOTH” and starve the engine” - This scenario has also been tested. With one tank empty, one tank full, and the selector to “BOTH”, there was still full fuel pressure. This may be due to the high-wing design and the fuel system plumbing called for by Robert Paisley of EFII.
“You could turn off both return valves and… I don’t know what, but it seems bad” - It would cause the fuel to back up at the valves, and the fuel pressure would increase to the maximum that the GL393 fuel pump would put out. This would be 105 PSI at 10 Gallons per hour. Not sustainable, but not harmful to the injectors or fuel lines for short periods of time. Again, the Engine Monitor will alarm when the fuel pressure begins to increase. The fuel system has been tested to the fuel pump stall pressure of 115 PSI and found to have no leaks.
I fly C-130s and King Air 200s and they both have fuel systems that are far more complicated. Flying aircraft will always require thought. With the duplex fuel valve, the pilot must remember to switch the fuel valves when it is necessary. I like the idea of being able to operate in a normal scenario with the fuel valve on both, and have the fuel is return to both tanks. If the situation arises, I can put the fuel where it is needed and I have a good monitoring system that will alert me if I make a mistake in the positioning of fuel valves. The return valves do not have a position that will cause the engine to quit turning.
Thoughts?
Thanks for your input.
Respectfully,
Justin
| Quote: | On Apr 19, 2015, at 7:30 PM, David Saylor <saylor.dave(at)gmail.com (saylor.dave(at)gmail.com)> wrote:
Hi Justin,
--Dave
On Sun, Apr 19, 2015 at 8:00 PM, Justin Jones <jmjones2000(at)mindspring.com (jmjones2000(at)mindspring.com)> wrote: | Quote: | | --> RV10-List message posted by: Justin Jones <jmjones2000(at)mindspring.com (jmjones2000(at)mindspring.com)> Berck, I am using an EFII system as well. Just a thought, but I put a normal L/R/Both/Off fuel valve on the supply side (AN6) and an AN6 size return line that Splits to each tank. After the "T" I put a simple Parker petroleum 1/4 turn ball valve on each side just before the tank. Now, I can shut one or the other return valves off, turn on the fuel pump, and transfer fuel on the ground. It can also be done in the air (with caution of course) to trim fuel. Note: I'm building a Bushcaddy not an rv10. I can send pics if you would like. Justin > On Apr 19, 2015, at 18:10, Berck E. Nash <flyboy(at)gmail.com (flyboy(at)gmail.com)> wrote: > > --> RV10-List message posted by: "Berck E. Nash" <flyboy(at)gmail.com (flyboy(at)gmail.com)> > > We're planning on EFII, so we need a full-sized return line for both > sides. Just now starting work on the fuel tank, and I'd like to get > this sorted before we get too far. I've spent awhile searching, and > have only managed to find lots of places not to put the port for the > fuel return line. Apparently it can interfere with both the wing spar > and the aileron return line. Does anyone have a clear diagram of where > I can safely put it? A hint about which flange/fittings to buy would be > greatly appreciated as well. Thanks in advance! > > Berck > > > > =========== -List" target="_blank">http://www.matronics.com/Navigator?RV10-List =========== FORUMS - _blank">http://forums.matronics.com =========== b Site - -Matt Dralle, List Admin. target="_blank">http://www.matronics.com/contribution =========== |
class="">http://www.matronics.com/Navigator?RV10-List
class="">http://forums.matronics.com
class="">http://www.matronics.com/contribution
kearney
Posted: Mon Apr 20, 2015 5:35 am Post subject: Re: Fuel Return Line Location? |
Bereck
I had a similar setup to what your plans. Until a few months had a different engine (Subie) which I replaced with a IO540. I still use the return line for my purge valvle.
I used an Andair duplex valve that returns fuel to the originating tank. With full tanks, you will pump a lot of gas overboard if the tanks / return line is mismatched. Running dual lines to the tanks is not a problem.
I used an AN832 bulkhead union, mounted similar to that shown in the tank plans, to make the connection. I also a flange riveted to the inside of the tank to keep the union from turning when the nut is applied to the outside. Again see the tank plans. Lots of proseal made sure nothing leaked.
You probably want to mount the fitting high and to the aft of the tank so that you do not interfere with the sender. If possible, you should run a tube from the fitting through the first tank baffle so that the returned fuel is dumped into the second tank cell. This allows it to cool and mix with other fuel before being reused. All of this is best done before the tanks are sealed. If the aren't, you can do everything (except perhaps for the fuel line to the second cell) through the fuel sender hole, it is just a bit tricky. This is what I did - I wasn't able to get the fuel back to the second cell but only to outboard side of the first.
All my fuel lines in the tunnel were braided steel. Under the seats I had to go back to aluminum because of how the lines were run. My fuel filters are mounted in the wing roots - one for each tank.
I completely agree with Dave's recommendation -keep it simple! You don't want to put yourself in a position where a simple error can lead to heartache and a bent air frame.
Cheers
Les
Posted: Mon Apr 20, 2015 5:53 am Post subject: Fuel Return Line Location? |
Berck,
I added a 1/4" purge line return to the left tank when building in case I
ended up with an AFP injection system (photo attached). This is the same
location I used the RV-8A which had AFP injection.
Adding a return line is straight forward and if you get the fitting in about
the same area as the vent line connection you should not have an issue. I'd
keep it high (like my photo) so that it is away from the fuel pick up -
should help with pulling cooler fuel into the engine as compared to the
hotter return fuel.
Just curious - how much did this EFII system cost?
Carl
223.9 KB |
16289 Time(s) |
Kellym
Posted: Mon Apr 20, 2015 6:00 am Post subject: Fuel Return Line Location? |
Just keep in mind that what may be appropriate and work fine in a high
wing aircraft is not suitable for a low wing aircraft. IMHO there is
little to no need to transfer fuel between wings on a single engine
aircraft. Managing fuel burn can easily keep the wings balanced, given
that each wing only holds about 2.5 hours of fuel. The RV-10 wing
arrangement is no place for a selector with a "both" position. It is too
easy for someone scanning the archives of this list to get the wrong
idea by a discussion of what works on a totally different airframe.
On 4/19/2015 9:50 PM, Justin Jones wrote:
| Quote: | Dave,
missing something.
quit turning.
Thoughts?
Respectfully,
Justin
> <mailto:saylor.dave(at)gmail.com>> wrote:
> Hi Justin,
> fuel:
> seems bad.
> think it will.
> --Dave
> <jmjones2000(at)mindspring.com <mailto:jmjones2000(at)mindspring.com>> wrote:
> Berck,
> to trim fuel.
> Justin
> <mailto:flyboy(at)gmail.com>> wrote:
> <flyboy(at)gmail.com <mailto:flyboy(at)gmail.com>>
> both
> to get
> searching, and
> for the
> wing spar
> of where
> would be
> > Berck
> FORUMS -
> b Site -
KCHD |
Posted: Mon Apr 20, 2015 7:16 am Post subject: Fuel Return Line Location? |
I think I'm flying Phase 1 in the first RV-10 with the full EFII system. I'm not sure how much fuel gets returned to the tank, but it is significant. We have a double stack Andair selector so it returns to the same tank that it is pulling from. I wouldn't have it any other way. It is so easy to do it this way that returning to one tank all the time, or having to process which tank you are pulling from and returning to would, IMHO, way over complicate things.
As for the fuel return location, we put it forward in the bay and up fairly high. It's just a bulkhead fitting with a nut and ProSeal to seal it. If the tanks were open, we might have put in an NPT female bung instead, but this works just fine.
There has been no problem at all with fuel vapor lock. I don't think it is necessary to return the fuel to the second bay. My fear if doing that would be the possibility of getting low on fuel and starting to suck air because you are dumping the fuel too far outboard. I don't know the exact effect, but it would expect that would effectively reduce your useable fuel level even more than it does by returning it to the first bay.
Btw, the EFII system does add a lot of necessary complexity, dual bus, dual alternators, dual electric fuel pumps, dual ECU's, etc. It took a while to get up the nerve to be the test pilot on it. New airframe, new engine, new style ignition and injection system, etc. I will say, however, that it has been absolutely rock solid stable for all 10 hours so far. I need to put 15-20 more hours on it the week after Sun-N-Fun, but that shouldn't be a problem. In my mind, the jury is still out on the system, but they are starting to trickle in with a not-a-bad-system verdict.
Jesse Saint
Saint Aviation, Inc.
352-427-0285
jesse(at)saintaviation.com
[quote] On Apr 20, 2015, at 9:49 AM, Carl Froehlich <carl.froehlich(at)verizon.net> wrote:
Berck,
hotter return fuel.
Carl
Posted: Mon Apr 20, 2015 8:04 am Post subject: Fuel Return Line Location? |
Carl- thanks so much for the picture. I'll plan on the same location. As for the cost: We haven't purchased anything yet, and probably won't until we source an engine. Hoping available systems will only get cheaper, but cursory research indicates it'll cost not much more than more conventional FI and ignition setups.
Jesse- Thanks for the heads up. Glad to hear that one is flying already, and I hope you'll keep us updated of any gotchas. After seeing that an EFII system is available, I can't imagine not using it. I'm aware of the need for a fully redundant electrical system and dual ECU's. I was already planning on dual electronic ignition and the dual alternators that necessitates, so electronic fuel injection only makes sense to me. This is, I think, the beauty of building an experimental-- the ability to use "modern" (30-year-old tried-and-tested) technology in an airplane, instead of being forced to rely on a fuel delivery system from the 1950's.
Any RV-10 specific EFII links, information, vendor tips, etc, would be greatly appreciated.
As for the "complexity" of a fuel return tank selection, it seems a bit silly to me that choosing a return tank is considered "overly complex." It's the difference of switching two valves instead of one when you switch tanks in normal operations. Sure, it's more complex than a single knob, but I'm used to much more complicated fuel systems many of which require deliberate knowledge of the fuel return tank. I'm not really concerned about it either way. The only reason to want to transfer fuel would be a leak, and in most situations, getting on the ground quickly makes a lot more sense than moving fuel around. Since I won't have to worry about the insane complexity of a mixture control, I can use those saved neurons to handle the fuel return tank if I wind up with two valves.
On Mon, Apr 20, 2015 at 7:49 AM, Carl Froehlich <carl.froehlich(at)verizon.net (carl.froehlich(at)verizon.net)> wrote:
[quote]Berck,
hotter return fuel.
Carl
Posted: Mon Apr 20, 2015 8:41 am Post subject: Fuel Return Line Location? |
I think you're kidding yourself if you think there is no mixture to worry about. I spend more time on the mixture knob so far than I do on the mixture control with a standard system. It's possible that once you get things all tuned up the way you want them you may not use it as much, but I really don't use it that much on a standard system either. I lean a little as I climb, then I set power, rpm and fuel flow for cruise.
I would imagine if you are burnin 12gph, you are probably returning at least that much to the tank, if not more. I wouldn't want to have to mess with picking a return tank separate from a feed tank. There are warnings when your fuel in a tank gets low, but I don't know of a warning saying your tank is getting too full. If you get busy or get bored and aren't managing fuel with a normal system, you will get something yelling at you saying you're getting into the red on the draw tank, but it won't happen if you start to pump it overboard through the return tank vent.
I agree that electric ignition is tried and true in cars, but so far there are a total of 10 fleet hours in the RV-10 with a full EFII system and thousands and thousands with mags and standard fuel injection. Far from a no-brainier in my book unless you are talking the other way around.
Jesse Saint
352-427-0285
On Apr 20, 2015, at 11:58 AM, Berck E. Nash <flyboy(at)gmail.com (flyboy(at)gmail.com)> wrote:
[quote]Carl- thanks so much for the picture. I'll plan on the same location. As for the cost: We haven't purchased anything yet, and probably won't until we source an engine. Hoping available systems will only get cheaper, but cursory research indicates it'll cost not much more than more conventional FI and ignition setups.
[quote]Berck,
hotter return fuel.
Carl
Posted: Mon Apr 20, 2015 9:17 am Post subject: Fuel Return Line Location? |
Oh, I just realized you meant the EFII-supplied mixture knob... Which means that programming a solid fuel hands-off fuel map takes some time?
On Mon, Apr 20, 2015 at 10:55 AM, Berck E. Nash <flyboy(at)gmail.com (flyboy(at)gmail.com)> wrote:
[quote]Since the fuel is metered directly at the injectors by the ECU, why do you have to mess with the mixture knob? The EFII website says, "Automatic mixture control (no mixture knob to fool with)", but you're saying that's not entirely true? Is the issue that you're compensating for a lack of initial ECU programming by altering the fuel pressure until the you get the programming dialed in? Since the system has a MAP and IAT sensor, it seems like it should be able to meter correctly without any input from the pilot. It doesn't look like the EFII includes an oxygen sensor, though?
Any idea if there are plans to fly this plane on automotive gasoline?
On Mon, Apr 20, 2015 at 10:38 AM, Jesse Saint <jesse(at)saintaviation.com (jesse(at)saintaviation.com)> wrote:
[quote]I think you're kidding yourself if you think there is no mixture to worry about. I spend more time on the mixture knob so far than I do on the mixture control with a standard system. It's possible that once you get things all tuned up the way you want them you may not use it as much, but I really don't use it that much on a standard system either. I lean a little as I climb, then I set power, rpm and fuel flow for cruise.
Jesse Saint
[url=tel:352-427-0285]352-427-0285[/url]
[quote]Berck,
hotter return fuel.
Carl
Posted: Mon Apr 20, 2015 9:40 am Post subject: Fuel Return Line Location? |
WRT auto fuel, while the injection system may be ok with it the rest of the system is problematic if you are unable to get ethanol free premium unleaded. If you can get this fuel the IO-540 D4A5 is already approved for its use.
Years ago a “EFII like” company wanted to use my RV-8A as a beta for their single lever electronic fuel injection system. After a lot of research it became obvious that how I wanted to run the plane (LOP to my set point) was not possible – I would have only whatever the software wanted me to have for mixture. That and they wanted a boat load of cash for the system and my testing/fixing time for free killed any interest I had.
Perhaps this EFII product has advanced from that of my experience. On the ignition side, I’ll be bolting on the new 200 series P-mags in June (I hope). I have a lot of hours with P-mags on the RV-8A and they have performed flawlessly.
Any ballpark number on what this system will cost?
Carl
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Berck E. Nash
Sent: Monday, April 20, 2015 12:55 PM
Subject: Re: Fuel Return Line Location?
Jesse Saint
Berck,
hotter return fuel.
Carl
Posted: Mon Apr 20, 2015 10:04 am Post subject: Fuel Return Line Location? |
Right, but there are still mixture settings that differ for different cruise powers and economy versus high speed cruise, just like any engine.
Jesse SaintSaint Aviation, Inc.
C: 352-427-0285
F: 815-377-3694
On Apr 20, 2015, at 1:14 PM, Berck E. Nash <flyboy(at)gmail.com (flyboy(at)gmail.com)> wrote:
[quote]Oh, I just realized you meant the EFII-supplied mixture knob... Which means that programming a solid fuel hands-off fuel map takes some time?
Jesse Saint
[quote]Berck,
hotter return fuel.
Carl
Kellym
Posted: Mon Apr 20, 2015 11:47 am Post subject: Fuel Return Line Location? |
I assume you are aware that leaded fuel such as 100LL will destroy an
oxygen sensor in less than one tank of fuel?
I seriously doubt that the EFII system and the dual everything required
to ensure it has power to work will save enough fuel to have a payback
in any reasonable time frame. Mixture management on conventional fuel
injection with magnetos is childs play once you get the system
delivering equal fuel mixture to each cylinder. While autos are using
less gas and producing more power, they are doing it with higher
compression ratios, knock sensors and thousands of hours of dyno time.
Most of the incremental benefit comes from electronic ignition, not
electronic timed fuel injection. Feel free to experiment, but don't
expect to get equal power on half the gas, or half the workload, for
equal investment.
On 4/20/2015 9:55 AM, Berck E. Nash wrote:
[quote] Since the fuel is metered directly at the injectors by the ECU, why do
Jesse Saint
352-427-0285 <tel:352-427-0285>
jesse(at)saintaviation.com <mailto:jesse(at)saintaviation.com>
> setups.
> <carl.froehlich(at)verizon.net <mailto:carl.froehlich(at)verizon.net>>
> wrote:
> Berck,
> building in case I
> is the same
> fitting in about
> an issue. I'd
> pick up -
> compared to the
> hotter return fuel.
> Carl
KCHD |
Posted: Mon Apr 20, 2015 1:18 pm Post subject: Fuel Return Line Location? |
I purchased the dual ecu 4cyl system for $5970 with shipping.
On Apr 20, 2015, at 09:37, Carl Froehlich <carl.froehlich(at)verizon.net (carl.froehlich(at)verizon.net)> wrote:
[quote] <![endif]--> <![endif]-->
Carl
From: owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com) [mailto:owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com)] On Behalf Of Berck E. Nash
Subject: Re: RV10-List: Fuel Return Line Location?
Jesse Saint
Berck,
hotter return fuel.
Carl
Posted: Mon Apr 20, 2015 5:26 pm Post subject: Fuel Return Line Location? |
Carl, your return line seems to be in the same general vicinity as
these, and they say they have spar interference?
http://www.vansairforce.com/community/showthread.php?t=122839
How were you able to be sure that yours cleared the spar? Am I just
looking at this wrong?
Berck
Posted: Mon Apr 20, 2015 6:27 pm Post subject: Fuel Return Line Location? |
Don't know. I never used the purge return. The fitting is capped off with
an AN cap in the event I ever want to use it. As the plane is flying this
must not have been a problem. Taking the plane down for conditional
inspection next month so I'll look. I do note that the photos from the
Van's Air Force link have the return line further aft than I do. That said,
there is no reason not to place the return line fitting more forward on the
rib to make sure - like just forward of the fuel sender and about center on
the rib. Just make sure you mind the aileron connecting arm.
Carl
Posted: Mon Apr 20, 2015 11:08 pm Post subject: Fuel Return Line Location? |
The wide band O2 sensors will eventually burn out due to lead fowling. They are pricey, and it does not happen in less than one tank of 100LL. There are many guys that have used them for tuning and removed them when they are done with them. Not a good idea to keep them in as they will eventually burn out completely. If you plan on changing your fuel map, I would HIGHLY suggest using a wide band sensor and a display to ensure your AFR (air fuel ratio) is not getting to lean. The stoichiometric ratio for a natural aspirated engine is 14.7:1 It is safer in our aircraft engines to run them at 13.7:1 and thats what the EFII system’s stock fuel map is programed to provide. Another indicator of the AFR is EGT, but other things can affect EGT, so the safe bet while tuning is to use a wide band O2 sensor and an AFR gauge to display the correct number to ensure you don’t get too lean.
The EFII system for me, was a cost benefit to overhauling what I currently had. An RSA5 fuel injection overhaul, new fuel pump, new mags, wires, plugs etc… would have been at or above the cost of acquisition of the EFiI system. I have heard nothing but good from this system and Robert Paisley from ProTec Performance has been nothing short of a rockstar with his customer service. I would agree that more benefit comes from the EI than the fuel injection, but by modulating the injectors, they are seeing gains on the dyno with the Electronic Fuel Injection over the mechanical injection. Also of note, the Lycoming hot start issue disappears with the EFII fuel injection. Mixture management is simple with the EFII system due to the programed fuel map they have in the ECUs. It reads the Manifold pressure, RPM, Throttle position sensor, and comes up with the fuel demand for the engine regardless of altitude. There is NO MAF sensor in this system. It uses a similar sensor in the throttle body. If you wish to trim fuel to change the EGTs, you can do so with the mixture rheostat, or you can do it by reprograming the ECUs’ fuel mapping. Takes some programing knowledge and the software, but it’s not hard to do. Robert Paisley and or SDS can help with this as well. There is significant fuel savings with this system, but as Kelly stated, it is not half the fuel.
Robert has his EFII system on numerous aircraft that race in the Reno air races, as well as many many happy customers flying the complete system. The ECUs are SDS ECUs and have hundreds of thousands of hours tested on them. The fuel pumps are automotive type, and there are 2 of them. Tons of proving time on the fuel pumps as well. The Coils are similar (if not the same) as the one from a Subaru Impreza. Again, hundreds of thousands of hours on the coils as well. The spark plugs are iridium automotive plugs and are a fraction of the price as an aircraft plug and out perform them as well. I feel perfectly safe with the EFII system in my aircraft, and would recommend them to anyone who wants a traditional aircraft engine with a modern fuel and ignition system.
Hope this helps!
Justin
On Apr 20, 2015, at 11:43 AM, Kelly McMullen <kellym(at)aviating.com> wrote:
I assume you are aware that leaded fuel such as 100LL will destroy an oxygen sensor in less than one tank of fuel?
I seriously doubt that the EFII system and the dual everything required to ensure it has power to work will save enough fuel to have a payback in any reasonable time frame. Mixture management on conventional fuel injection with magnetos is childs play once you get the system delivering equal fuel mixture to each cylinder. While autos are using less gas and producing more power, they are doing it with higher compression ratios, knock sensors and thousands of hours of dyno time. Most of the incremental benefit comes from electronic ignition, not electronic timed fuel injection. Feel free to experiment, but don't expect to get equal power on half the gas, or half the workload, for equal investment.
> On Mon, Apr 20, 2015 at 10:38 AM, Jesse Saint <jesse(at)saintaviation.com <mailto:jesse(at)saintaviation.com>> wrote:
> Jesse Saint
> Sent from my iPad
>> setups.
>> wrote:
>> Berck,
>> building in case I
>> is the same
>> fitting in about
>> an issue. I'd
>> pick up -
>> compared to the
>> hotter return fuel.
>> Carl
