ACS Door Locks
civengpe
PostPosted: Thu Apr 09, 2015 4:51 am    Post subject: ACS Door Locks Reply with quote
I tried to install my new, custom ordered door lock yesterday in the baggage door and found that the included cam was too short.  When I attempted to use the one I had, I realized that these door locks are "clocked" 45 degrees off of what they would need to be for the cam to be level in the closed position.
The included cam has an 8 point mounting hole that allows it to be clocked to the desired position, but the one I have is square.  I called the manufacturer and they do not make a longer cam.  Does anyone have a source for longer cams that have an 8 point mounting hole?  If not, what has everyone else been doing?
Shannon
rvdave
PostPosted: Thu Apr 09, 2015 5:08 am    Post subject: Re: ACS Door Locks Reply with quote
I took the square holed cam, cut and welded it to the octagonal cam and bent it to make it work.
Dave Ford
Cadillac, MI
wgreenley
PostPosted: Thu Apr 09, 2015 5:08 am    Post subject: ACS Door Locks Reply with quote
I believe my kit from Vans came with a long cam for this purpose.
On Thu, Apr 9, 2015 at 8:48 AM, Shannon Hicks <civeng123(at)gmail.com (civeng123(at)gmail.com)> wrote:
[quote]I tried to install my new, custom ordered door lock yesterday in the baggage door and found that the included cam was too short.  When I attempted to use the one I had, I realized that these door locks are "clocked" 45 degrees off of what they would need to be for the cam to be level in the closed position.
Shannon
get="_blank">http://www.matronics.com/Navigator?RV10-List
tp://forums.matronics.com
bruce.hoppe(at)yahoo.com
PostPosted: Thu Apr 09, 2015 6:17 am    Post subject: ACS Door Locks Reply with quote
civengpe
PostPosted: Thu Apr 09, 2015 7:25 am    Post subject: ACS Door Locks Reply with quote
Because the cutout is square in the Vans supplied cam, It will not rotate properly.  When the lock is installed in the door, it is off by 45 degrees.  The only way I can see making it work is to modify the square opening to an 8 point opening.  Attached is a crude drawing of what is happening.
Shannon
On Thu, Apr 9, 2015 at 8:08 AM, rvdave <rv610dave(at)gmail.com (rv610dave(at)gmail.com)> wrote:
--> RV10-List message posted by: "rvdave" <rv610dave(at)gmail.com (rv610dave(at)gmail.com)>
Dave Ford
RV6 for sale
RV10 building
Cadillac, MI
http://forums.matronics.com/viewtopic.php?p=440489#440489
-List" target="_blank">http://www.matronics.com/Navigator?RV10-List
 Filesize:  79.76 KB
 Viewed:  10516 Time(s)
Jim Berry
PostPosted: Thu Apr 09, 2015 9:13 am    Post subject: Re: ACS Door Locks Reply with quote
A locksmith or HD can fix you up with the correct latch.
bhoppe2
PostPosted: Thu Apr 09, 2015 4:41 pm    Post subject: Re: ACS Door Locks Reply with quote
I agree with William. Vans included a longer cam that replaces the one that comes with the lock. I ended up making one so that I could embed a disk magnet in it and then installed a reed switch in the door jamb. That switch is hooked in series with the passenger door switches. All 5 switches are hooked in series, 2 per passenger and one on the luggage door. Therefore, if any door is not latched, I get an indicator on my panel telling me, just not which one. i bought both the magnet and switch from Amazon.
Bruce Hoppe
 Filesize:  266.81 KB
 Viewed:  10476 Time(s)
Bruce Hoppe
