Foreign registered Europa
wdaniell.longport(at)gmai
PostPosted: Thu Mar 26, 2015 12:34 pm    Post subject: Foreign registered Europa Reply with quote
It is possible that I may be transferred to the US.  Does anyone know how to register a foreign built Europa in the US?
thanks Will
William Daniell
LONGPORT
+57 310 295 0744
budyerly(at)msn.com
PostPosted: Sun Apr 05, 2015 12:52 pm    Post subject: Foreign registered Europa Reply with quote
William,
It isn’t that bad.
The best thing to do is go to www.faa.gov and hit the tab for license and certificates then aircraft registration. Not a big deal. Quite a bit of reading to get educated so some goombah doesn’t lead you down a bad path. Contact your US FAA Flight Standards District Office (FSDO) for what they want specifically from you. Normally a letter from the export country, your bill of sale (sale history) and an application $5 fee, then a DAR will do an inspection and you get a US airworthiness inspection provided it is airworthy. Kits are essentially the same, except it is just the bill of sale and if the kit was registered, the appropriate paperwork.
Look at the attached pamphlet for a start.
Best Regards,
Bud Yerly
From: William Daniell (wdaniell.longport(at)gmail.com)
Sent: Thursday, March 26, 2015 4:32 PM
Subject: Foreign registered Europa
thanks Will
William Daniell
LONGPORT
+57 310 295 0744
href="http://www.matronics.com/Navigator?Europa-List">http://www.matronhref="http://forums.matronics.com">http://forums.matronics.com
AFS-750-124I_Import_Registration_Info.pdf
 Filename:  AFS-750-124I_Import_Registration_Info.pdf
 Filesize:  13.4 KB
 Downloaded:  6022 Time(s)
PostPosted: Mon Apr 06, 2015 7:53 am    Post subject: Foreign registered Europa Reply with quote
Bud
thanks excellent advice.  I am trying hard to finish and register but might not make it by the time they transfer me (18 months more or less) ...do you have any experience of part built kits arriving in the US?
Will
William Daniell
LONGPORT
+57 310 295 0744
On Sun, Apr 5, 2015 at 3:50 PM, Bud Yerly <budyerly(at)msn.com (budyerly(at)msn.com)> wrote:
[quote] William,
It isn’t that bad.
Best Regards,
Bud Yerly
thanks Will
William Daniell
LONGPORT
+57 310 295 0744
