fuel filters
flying-nut(at)cfl.rr.com
PostPosted: Wed Mar 25, 2015 5:53 am    Post subject: fuel filters Reply with quote
Do you have a part number handy??? I looked, and the choices are huge!!!
Anybody else go this route??
My fellow RV-10 builder added a second Vans filter and mounted them
under the front seats in place of the one in the tunnel.
I plan on adding filters in the wing root like Les did, and for the same
reasons.
Linn
On 3/25/2015 9:10 AM, kearney wrote:
Hi
Agree with David's comment on the fuel filters. One of the "legacy" items from my earlier filters install was placement of fuel filters in the wing roots. I was able to install two Earl's Performance filters - one in each wing root. They are user serviceable and easily accessed simply by removing the wing root cover panel. Now I don't have to contort myself to get at them as I would if they were in the tunnel.
Regular cleaning, especially when first flying, is a must. There can be a lot of accumulated crud when building.
I also installed an access panel on the pilot's side wall of the tunnel for easy access to the aux fuel pump.
Cheer
Les
easily(at)me.com wrote:
> AirMike wrote:
>> I just followed the standard plans and crushed the large scat tube to fit the space. After 5 years no problems with chafe or perforation. It is ugly, but it works. Deems' installation is obviously 1st class, but a bit of extra work.
>> I would say two far more important issues are : 1) the cheap aluminum air distribution boxes on the firewall supplied by Vans. I suggest using only the excellent (after market) fire resistant stainless steel steel boxes. Could save your life. 2) Also, if I were building again, I would improvise easier access to the fuel system (in the tunnel) - pump and filter - for easy servicing. Servicing the fuel filter is a real pain. Top and side access portals would facilitate servicing.
> I did the same thing with the large scat and it works fine. Coming up on 7 years with no issues, but as Mike says, it is ugly. However, I am the only one that looks at it! ^_^
> I agree with Mike's comments about the aluminum heat distribution box and tunnel access. I even thought about making a belly access panel, ala Piper, but that would introduce some other engineering issues I imagine. You will thank yourself later on if you make access to the fuel filter as easy as possible.
http://forums.matronics.com/viewtopic.php?p=439860#439860
kearney
PostPosted: Wed Mar 25, 2015 5:53 pm    Post subject: Re: fuel filters Reply with quote
Linn
These are what I used : http://www.summitracing.com/oh/parts/ear-230206erl
I flow tested them at something north of 50 GPH so they are well suited to our application (IMHO). The screens are easily removed and cleaned. I have done so several times.
When I first was flying, I had to install gascolators to meet inspection requirements. These I had in the wig roots and the filters were under the seat. Accessing them was a real pain. I wanted easy access. I certainly didn't want them in the tunnel.
When I received permission to remove gascolators, I moved the filters to the wing roots. Much easier access (5 minutes and they are both out).
Also, rather than ruin a solid line from the tunnel to the fuel tank, I ran the line to a bulkhead minutes on the fues sidewall. It was easy to mount the filter between this and the tank outlet.
Cheers
Les
[quote="flying-nut(at)cfl.rr.com"]Do you have a part number handy??? I looked, and the choices are huge!!!
reasons.
Linn
kearney
PostPosted: Wed Mar 25, 2015 7:12 pm    Post subject: Re: fuel filters Reply with quote
Hi
As requested by Patrick, here is a pix of of my wing root fuel filter. I misspoke in my earlier post when I said I used a bulkhead union for the line. I didn't as I had a connection at the filter I could break. It is hard to see but I used a 90 degree AN fitting to attach the top of the line to the filter.
Lest anyone ask, the other line to the tank is a return line, another Subie legacy item that proved useful.
Cheers
Les
 Filesize:  53.95 KB
 Viewed:  28101 Time(s)
johngoodman
PostPosted: Thu Mar 26, 2015 6:34 am    Post subject: Re: fuel filters Reply with quote
I used the Summit brand filter, but they are all good.
John
maryAidan
PostPosted: Sun Feb 04, 2024 8:41 pm    Post subject: Re: fuel filters Reply with quote
All are OK mapquest
timothyferriss
PostPosted: Tue Feb 06, 2024 7:14 pm    Post subject: Re: fuel filters Reply with quote
Consulting with experienced builders or forums dedicated to RV-10 construction might provide valuable insights immaculate grid and recommendations regarding specific parts and their compatibility with your aircraft.
