Kelly McMullen
Posted: Wed Mar 25, 2015 6:40 pm Post subject: Wing root fairings |
I don't find mention of any weatherstrip for the wing root fairings. Am I missing something? What have others done to make a nice joint between fuselage skin and wing root fairing?
On Wed, Mar 25, 2015 at 1:11 PM, Patrick Pulis <rv10free2fly(at)yahoo.com.au (rv10free2fly(at)yahoo.com.au)> wrote:
[quote]--> RV10-List message posted by: Patrick Pulis <rv10free2fly(at)yahoo.com.au (rv10free2fly(at)yahoo.com.au)>
Any pictures of the wing root filter installations please Les?
Warm regards
Patrick
A&P/IA, EAA Tech Counselor
KCHD |
kearney
Posted: Wed Mar 25, 2015 6:50 pm Post subject: Re: Wing root fairings |
Hi Kelly
I went to a local auto supply shop and got some edge trim and put that on the inboard edge of the wing root faring. I think it looks quite nice. I can in a 50' foot roll and cost perhaps $40. I don't have the name, but can get it when I am at the hanger next.
Cheers
Les
[quote="Kelly McMullen"]I don't find mention of any weatherstrip for the wing root fairings. Am I missing something? What have others done to make a nice joint between fuselage skin and wing root fairing?
Lenny Iszak
Posted: Wed Mar 25, 2015 7:00 pm Post subject: Re: Wing root fairings |
I used part# 05-11201 from Aircraft Spruce.
I tried the Y shaped one too, but it didn't work.
Lenny
Posted: Wed Mar 25, 2015 7:18 pm Post subject: Wing root fairings |
Some have used rubber channel around the leading edge, but along the fuse skin where there is an angle to screw the fairing on there is nothing.
Jesse SaintI-TEC, Inc.
www.itecusa.org
www.mavericklsa.com
C: 352-427-0285
O: 352-465-4545
F: 815-377-3694
On Mar 25, 2015, at 10:37 PM, Kelly McMullen <apilot2(at)gmail.com (apilot2(at)gmail.com)> wrote:
[quote]I don't find mention of any weatherstrip for the wing root fairings. Am I missing something? What have others done to make a nice joint between fuselage skin and wing root fairing?
| Quote: | --> RV10-List message posted by: Patrick Pulis <rv10free2fly(at)yahoo.com.au (rv10free2fly(at)yahoo.com.au)>
Warm regards
Patrick
List"">http://www.matronics.com/Navigator?RV10-List
//forums.matronics.com
Kelly McMullen
Posted: Wed Mar 25, 2015 7:44 pm Post subject: Wing root fairings |
Thanks Jesse,
That is the way I have been reading the plans. Just seemed like it would look nicer to have something there.
On Wed, Mar 25, 2015 at 8:01 PM, Jesse Saint <jesse(at)saintaviation.com (jesse(at)saintaviation.com)> wrote:
[quote]Some have used rubber channel around the leading edge, but along the fuse skin where there is an angle to screw the fairing on there is nothing.
www.itecusa.org
www.mavericklsa.com
C: [url=tel:352-427-0285]352-427-0285[/url]
O: [url=tel:352-465-4545]352-465-4545[/url]
F: [url=tel:815-377-3694]815-377-3694[/url]
| Quote: | I don't find mention of any weatherstrip for the wing root fairings. Am I missing something? What have others done to make a nice joint between fuselage skin and wing root fairing?
Warm regards
Patrick
tp://forums.matronics.com
KCHD |
Posted: Thu Mar 26, 2015 5:42 am Post subject: Wing root fairings |
I used the same rubber channel that is used on the wing root for RV-8s and such (same material as used on the bottom of the Horizontal Stabilizer, just longer) I purchased the material from Van’s. Like Jesse says, no need for this along the fuselage skin where there is a bracket to screw down the root fairing. Not installing this trim made the leading edge to fuselage transition look unfinished.
When you do this you’ll need open the leading edge to fuselage gap perhaps 1/8” to ¼” to provide room for the channel. Also use a little black RTV in the channel that slides over the root fairing to make sure it does not work itself out and start flapping on the side of the fuselage (this was a rude awaking during my third flight in the RV-8A). Put the RTV in the channel then install on the leading edge fairing such that the RTV sets up with the channel in place.
Carl
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Kelly McMullen
Sent: Wednesday, March 25, 2015 11:42 PM
Subject: Re: Wing root fairings
Thanks Jesse,
Jesse Saint
I-TEC, Inc.
www.itecusa.org
www.mavericklsa.com
Warm regards
Patrick
| Quote: | | D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3DList"">http://www.matronics.com/Navigator?RV10-ListD=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D//forums.matronics.comD=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3Dot;">http://www.matronics.com/contributionD=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D |
| 012345
6789 | Quote: | | D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D | 0 | Quote: | | D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D | 1 | Quote: | | D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D | 2 | Quote: | | D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D | 3 | Quote: | | D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D | 4 | Quote: | | D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D | 5 | Quote: | | D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D | 6 | Quote: | | D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D | 7 | Quote: | | D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D | 8 | Quote: | | D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D | 90123
Lenny Iszak
Posted: Thu Mar 26, 2015 6:07 am Post subject: Re: Wing root fairings |
Yep, you need to create room for it between the cover and the fuselage skin. I don't have any RTV on it, and it stays on fine even where there no support angle underneath, just need to make sure the gap is not too big. With the J shaped rubber I used there's not a lot of rubber sticking out, maybe only 3/16.
Lenny
dmaib@me.com
Joined: 25 Apr 2006 Posts: 455 Location: New Smyrna Beach, Florida
Posted: Thu Mar 26, 2015 11:24 am Post subject: Re: Wing root fairings |
I used some edge guard that looks like this.
http://www.trimlok.com/prod/Edge-Guard/Edge-Trims/All-Product-Categories_120/Edge-Guard_119.aspx
I got it at a local automotive store up in Minnesota. It fits snugly on the edge with no adhesive required. No need to trim the metal to make it fit, either. I also put it on the edge of my glareshield, which I painted flat black rather than covering it. The material was very inexpensive, and seven years and counting it still looks great. Sounds like the same type of material that Les used. Will try to get a pic to post in the next day or two.
Easy to find as "door edge guard" in ebay automotive. Inexpensive and easy.
Here is a photo of my edge guard on the wing root. As I mentioned, no trimming of the edge material was required. Fits very nicely. Sorry about the dirty airplane!
_________________ David Maib
RV-10 #40559
New Smyrna Beach, FL
Last edited by dmaib@me.com on Tue Mar 31, 2015 7:19 pm; edited 2 times in total |
flying-nut(at)cfl.rr.com Guest
Posted: Thu Mar 26, 2015 12:11 pm Post subject: Wing root fairings |
I've been wondering what to do with the glareshield ..... and you nailed
it. I went the McMaster-Carr route for the door seals ...... and that
ought to work just dandy for the edge of the glareshield. I'll have to
buy some for a thinner edge though. Thanks for the mental trigger!
Linn
On 3/26/2015 3:24 PM, dmaib(at)me.com wrote:
dmaib@me.com
rv10flyer
Posted: Sat Apr 04, 2015 5:56 am Post subject: Re: Wing root fairings |
Provided 1/16" clearance between fuse and fairing. Sanded/cleaned/alodined, fillet of proseal and painted with the rest of the plane. Still looks fine.
_________________ Wayne G. |
