Knowing the actual fuel level?
Rick Moss
PostPosted: Wed Mar 18, 2015 12:15 pm    Post subject: Knowing the actual fuel level? Reply with quote
Hi all,
My XS TG has an Avelec electronic fuel gauge, which is useful as a vague indication, but little else. When it reads 54 litres (the highest it ever reads), I can still put another 18 litres into the tank. It then reads 54 litres for around an hour of flight, before dropping in 2 litre increments in a plausible manner.
Bottom line: I only know accurately how much fuel I have when it's overflowing or empty (excl reserve). Given that the tank can't be dipped, what are you chaps using for fuel measurement?
Thanks in advance,
Rick
rlborger(at)mac.com
PostPosted: Wed Mar 18, 2015 12:50 pm    Post subject: Knowing the actual fuel level? Reply with quote
Rick,
I had the original sight gage installed per Europa instructions. It only tells you when the fuel “may” be getting low. For a better idea of the fuel usage, I installed the dual fuel flow option on my Grand Rapids EIS4000. When calibrated, it seems to be accurate to much better than a half pint (about 250 cc) in a tank of gas.
When I replaced my leaking tank last year I removed the original, pretty much useless, sight gage and replaced it with a sight gage that runs from the bottom of the tank, main side, up between the seats, near the pilot:
[img]cid:22EDE013-1F72-427F-95FD-AC2F99B6C059[/img]
It is also back lit with a string of 12v lEDs. The remainder of the 15 ft (5 meter) string is run around the inside of the tunnel for inside work illumination. It’s not shown in the picture but there is a switch/dimmer for the lighting. I used the ties to mark calibration points: 06 gal (at) bottom of lower P-clip; 07 gal, top of lower P-clip; 08 gal (at) first white tie; 09 gal (at) 2nd white tie, 10 gal (at) 1st black tie; 11 gal (at) white tie; 12 gal (at) white tie; 13 gal (at) white tie; 14 gal (at) white tie; 15 gal (at) 2nd black tie; 19 gal (at) top of upper P-clip; 20 gal (at) top of gage. You can see that in this picture the tank is holding 15 gal.
In the 25 hrs or so I have flown since replacing the tank, this gage has proven to be almost as accurate as the totalizer down to where the gage disappears. When the fuel disappears in the gage you are close to a mandatory switch to reserve and time to find a place to land if you are not already there.
Blue skies & tailwinds,Bob BorgerEuropa XS Tri, Rotax 914, Airmaster C/S Prop (75 hrs).Little Toot Sport Biplane, Lycoming Thunderbolt AEIO-320 EXP3705 Lynchburg Dr.Corinth, TX 76208-5331Cel: 817-992-1117rlborger(at)mac.com (rlborger(at)mac.com)
On Mar 18, 2015, at 3:16 PM, Rick Moss <Rkwmoss(at)gmail.com (Rkwmoss(at)gmail.com)> wrote:--> Europa-List message posted by: "Rick Moss" <Rkwmoss(at)gmail.com (Rkwmoss(at)gmail.com)>Hi all,My XS TG has an Avelec electronic fuel gauge, which is useful as a vague indication, but little else. When it reads 54 litres (the highest it ever reads), I can still put another 18 litres into the tank. It then reads 54 litres for around an hour of flight, before dropping in 2 litre increments in a plausible manner.Bottom line: I only know accurately how much fuel I have when it's overflowing or empty (excl reserve). Given that the tank can't be dipped, what are you chaps using for fuel measurement?Thanks in advance,Rick
 Filesize:  130.65 KB
 Viewed:  12737 Time(s)
kheindl(at)msn.com
PostPosted: Wed Mar 18, 2015 1:10 pm    Post subject: Knowing the actual fuel level? Reply with quote
Hi Rick,
The Avelec should work better than you described. Perhaps you should re-calibrate it. There are also expensive fuel flow indicators like my JPI 450 and others. The most reliable and cheapest solution is the sight tube. I use all 3 . My complaint about the Avelec is that it is difficult to read in sunlight, like all LCD displays. I guess it's my failing eyesight.
Karl
Subject: Knowing the actual fuel level?
Date: Wed, 18 Mar 2015 13:16:01 -0700
--> Europa-List message posted by: "Rick Moss" <Rkwmoss(at)gmail.com>
Hi all,
Thanks in advance,
Rick
http://forums.matronics.com/viewtopic.php?p=439515#439515
&g=========
dpark748(at)icloud.com
PostPosted: Wed Mar 18, 2015 3:16 pm    Post subject: Knowing the actual fuel level? Reply with quote
Rick,
I use the following fuel computer. Very accurate once you calibrate it. I use two senders for flow and return. Easy to set up in the system.
Dave G-LDVO
FC10 + 2 FT60s from support(at)fdatasystems.com
On 18 Mar 2015, at 8:16 pm, Rick Moss <Rkwmoss(at)gmail.com> wrote:
Hi all,
Thanks in advance,
Rick
PostPosted: Wed Mar 18, 2015 3:19 pm    Post subject: Knowing the actual fuel level? Reply with quote
Rick,
I have two capacitance senders for the original Europa fuel gauge, but never been reliable.
I submitted a mod to fit a dip stick in one of the holes but came unstuck when LAA wanted a method of ensuring the cap could not be removed when tank full?
Dave
Hi all,
Thanks in advance,
Rick
Rick Moss
PostPosted: Thu Mar 19, 2015 1:37 am    Post subject: Re: Knowing the actual fuel level? Reply with quote
Thanks all.
Does anyone know the calibration procedure for the Avelec? May be worth a try in the first instance.
Remi Guerner
PostPosted: Thu Mar 19, 2015 4:21 am    Post subject: Re: Knowing the actual fuel level? Reply with quote
Rick,
My Avelec fuel gauge has always been very unreliable. I scrap it and installed a resistive unit long ago.
Remi Guerner
F-PGKL
rampil
PostPosted: Thu Mar 19, 2015 5:05 am    Post subject: Re: Knowing the actual fuel level? Reply with quote
The Europa fuel measurement options are all problematic.
The original sight gauge was difficult to read and inaccurate. The sight
gauge I installed between the seats still has two very significant problems.
One: the vent for the sight tube of necessity must have some bends in the
tubing, allowing fuel to become trapped and preventing the gauge from
free venting. This occurs when line boys are over exuberant about
filling up the filler neck and flooding the vent line (which I have opening
into the top of the filler neck). Trapped fuel then causes the sight tube to
read inches low.
Two: The curious saddle bag design of the tank allows easy, yet
undetectable shifting of what fuel you may believe to be in the reserve
side into the main, potentially leaving nothing for reserve. This has happened
after some gentleman macro and even after some steep turns in the
presence of bumpy air.
The capacitive measurement systems are all non-starters where we are
fortunate to have choices in fuel (av vs. mo-gas).
The remediation I have been playing with involves two honeywell pressure
transducers at the bottom of each fuel bung feeding an Arduino with a
touch sensitive LCD screen. Not quite finished for publication, but the
thought is that it should provide legible, filtered, reliable fuel weight on
each side, calibrated to the funky shape of the tank.
Two design decisions I made in the prototype may come back to force a
revision: I did not use differential transducers because 1) the limited
altitude range I normally fly at would lead to a trivial error by neglecting
head space pressure (also very difficult to find gasoline-tolerant differential
transducers), and 2) by installing the transducers at a tee in the
bungs, there will be a small artifactual pressure drop which varies with
fuel flow.
When I finish testing, I will let you know.
Arduino based fuel gauge.
 Filesize:  94.71 KB
 Viewed:  12697 Time(s)
Ira N224XS
grahamsingleton(at)btinte
PostPosted: Thu Mar 19, 2015 5:21 am    Post subject: Knowing the actual fuel level? Reply with quote
Ira
that has the potential to be a brilliant solution.
Graham
Sent: Thursday, 19 March 2015, 13:05
Subject: Europa-List: Re: Knowing the actual fuel level?
--> Europa-List message posted by: "rampil" <ira.rampil(at)gmail.com (ira.rampil(at)gmail.com)>
read inches low.
fuel flow.
Ira N224XS
http://forums.matronics.com/viewtopic.php?p=439585#439585
http://forums.matronics.com="http://www.matronics.com/Navigator?Europa-List" target="_blank">http: &nbs//www.matronics.com/contribution" target="_blank">http://www.matronics.co==================
PostPosted: Thu Mar 19, 2015 7:36 am    Post subject: Knowing the actual fuel level? Reply with quote
Sounds good news waiting for further progress.
Dave G-LDVO
On 19 Mar 2015, at 13:18, GRAHAM SINGLETON <grahamsingleton(at)btinternet.com (grahamsingleton(at)btinternet.com)> wrote:
[quote]Ira
Graham
From: rampil <ira.rampil(at)gmail.com (ira.rampil(at)gmail.com)>
Subject: Re: Knowing the actual fuel level?
read inches low.
fuel flow.
Ira N224XS
"3D"courier" new,courier"="">[url=3D"http://www.matronics.com/Navigator?Europa-List"]http://www.matronics.com/Navigator?Europa-List[/url]
kheindl(at)msn.com
PostPosted: Thu Mar 19, 2015 7:46 am    Post subject: Knowing the actual fuel level? Reply with quote
I would contact avelec.co.uk and ask them to email the calibration instructions. I have found the readings quite accurate, but then I use mostly the same fuel, and I make sure I never fly with a tank that is almost empty
paul.the.aviator(at)gmail
PostPosted: Thu Mar 19, 2015 9:57 am    Post subject: Knowing the actual fuel level? Reply with quote
I have a similar system as Ira describes based off Tony K's design using a
PIC micro that drives a 10 segment LED display. Its calibrated to take care
of the shape of the tank and each segment is a linear progression, aka ~ 1.8
gallons per segment.
It has been trouble free for 10 years and the only issue is that is reads
high for a little while when climbing and low when descending until it
settles out. The sensor is differential with one side in the lowest point of
the fuel system and the other in the tank vent. I never did get to the
bottom of the climbing / descending issue.
I like Ira's approach using more modern technology such as the Arduino with
a touch sensitive LCD screen. Mine is older technology and finicky thing to
get working
h&jeuropa
PostPosted: Sat Mar 21, 2015 7:48 am    Post subject: Re: Knowing the actual fuel level? Reply with quote
We have a mono which means fuel quantity measuring devices will indicate differently depending on whether the aircraft is in level flight attitude or ground attitude. Adds a bit of complexity to the problem!
We rely most on the fuel computer built into our GRT EIS and EFIS. This has two separate FlowScan transducers, one for in and one for return. It has proven to be accurate, probably within 1/2 gallon. It's hard to know how accurate it is, since it is difficult to measure fuel quantity accurately with a sight gauge.
We have a sight gauge positioned on the rear wall of the cockpit module and connected to the port side tank water drain. This is calibrated for ground attitude and we use it when refueling. We compare it to the fuel computer. Due to it's location, it is not visible in flight.
Andrew Sarangan suggested an alternative to a sight gauge. We don't know what the current status of this novel idea is. Here is the thread:
http://forums.matronics.com/viewtopic.php?t=103987&highlight=fuel+level
In flight we use two differential pressure sensors, one on each tank drain. The transducers are Freescale MPXV4006DP. They output 0-5 volts which our EIS accepts as aux inputs. Our GRT EFIS has a tank calibration table so we account for the shape of the tank there and we did that calibration in level flight attitude. We have each sensor calibrated from 0 - 3 gal. So each will show the amount of fuel in its 3 gal side. When both are at 3 gal, we then display both sensors as having 6 gal and they change together. When we have less than 6 gal on board, we just add the amount each shows. We ignore the fuel quantity indications from these sensors when on the ground!
This system works pretty well. We are confident enough to use fuel out of the port tank until no more than 1 gallon remains. We then switch to the stbd tank and complete the flight. Of course when low on fuel, we monitor the fuel computer and the differential fuel pressure closely.
Ira, we found that with a forward facing tank vent on the belly of the aircraft, there is enough ram air pressure that we had to use differential transducers connected to the tank vent. We tried differential sensors vented to ambient pressure and found large errors.
Jim & Heather
N241BW
