rickofudall
Posted: Sat Mar 14, 2015 8:22 am Post subject: 3.5 mm 4 pole socket |
I'm looking for a 3.5mm 4 pole socket so I can make an adapter for earphone and microphone headset to my handheld. I've tried every way of describing this to Google and the electronic parts suppliers and can't come up with one. This is the socket that's on my smart phone but either the search engine or I are too dumb to get there. In my travels I've seen the plug described as a 3.5mm TRRS plug, but no sockets for them. Anyone found these or can show me how to find them?Thanks guys.
Rick Girard
Believe those who are seeking the truth, doubt those who find it.
-Andre Gide
email(at)jaredyates.com Guest
Posted: Sat Mar 14, 2015 8:39 am Post subject: 3.5 mm 4 pole socket |
Something like this?http://www.ebay.com/itm/DIY-3-5mm-TRRS-Stereo-1-8-Input-Female-Jack-Plug-with-Solder-On-Terminal-End-/351327473502
On Sat, Mar 14, 2015 at 12:21 PM, Richard Girard <aslsa.rng(at)gmail.com (aslsa.rng(at)gmail.com)> wrote:
[quote]I'm looking for a 3.5mm 4 pole socket so I can make an adapter for earphone and microphone headset to my handheld. I've tried every way of describing this to Google and the electronic parts suppliers and can't come up with one. This is the socket that's on my smart phone but either the search engine or I are too dumb to get there. In my travels I've seen the plug described as a 3.5mm TRRS plug, but no sockets for them. Anyone found these or can show me how to find them?Thanks guys.
Rick Girard
-Andre Gide
ist" target="_blank">http://www.matronics.com/Navigator?AeroElectric-List
tp://forums.matronics.com
| [b]
edpav8r(at)yahoo.com Guest
Posted: Sat Mar 14, 2015 8:43 am Post subject: 3.5 mm 4 pole socket |
Parametric search on Digikey shows three options, the first containing a switch. There may be more; I didn't have time to check at length...
http://www.digikey.com/product-detail/en/SJ-435107/CP-435107-ND/3064634
http://www.digikey.com/product-detail/en/SJ-43514/CP-43514-ND/368146
http://www.digikey.com/product-detail/en/SJ5-43502PM/CP5-43502PM-ND/1956558
FWIW, they're generally called "TRRS" jacks.
Eric
On Mar 14, 2015, at 9:21 AM, Richard Girard <aslsa.rng(at)gmail.com (aslsa.rng(at)gmail.com)> wrote:
Rick Girard
-Andre Gide
lectric-List"">http://www.matronics.com/Navigator?AeroElectric-List
Posted: Sat Mar 14, 2015 8:44 am Post subject: 3.5 mm 4 pole socket |
Sorry, I see you already knew the "TRRS" part...
Eric
On Mar 14, 2015, at 9:42 AM, Eric Page <edpav8r(at)yahoo.com (edpav8r(at)yahoo.com)> wrote:
[quote]Parametric search on Digikey shows three options, the first containing a switch. There may be more; I didn't have time to check at length...
Eric
| Quote: | I'm looking for a 3.5mm 4 pole socket so I can make an adapter for earphone and microphone headset to my handheld. I've tried every way of describing this to Google and the electronic parts suppliers and can't come up with one. This is the socket that's on my smart phone but either the search engine or I are too dumb to get there. In my travels I've seen the plug described as a 3.5mm TRRS plug, but no sockets for them. Anyone found these or can show me how to find them?Thanks guys.
Rick Girard
-Andre Gide
enginerdy(at)gmail.com Guest
Posted: Sat Mar 14, 2015 8:48 am Post subject: 3.5 mm 4 pole socket |
They're out there, but I'm only seeing surface mount versions.
Try "3.5mm 4p" in mouser and digikey
Daniel Hooper
On Mar 14, 2015, at 11:21 AM, Richard Girard <aslsa.rng(at)gmail.com (aslsa.rng(at)gmail.com)> wrote:
Rick Girard
-Andre Gide
billp(at)wwpc.com Guest
These are called T-R-R-S (tip-ring-ring-sleve) connectors Digikey has them.
Bill
On 3/14/15 9:21, Richard Girard wrote:
[quote] I'm looking for a 3.5mm 4 pole socket so I can make an adapter for earphone and microphone headset to my handheld. I've tried every way of describing this to Google and the electronic parts suppliers and can't come up with one. This is the socket that's on my smart phone but either the search engine or I are too dumb to get there. In my travels I've seen the plug described as a 3.5mm TRRS plug, but no sockets for them. Anyone found these or can show me how to find them? Thanks guys.
Rick Girard
-Andre Gide
jwrjrjwrjr(at)gmail.com Guest
Posted: Sat Mar 14, 2015 9:33 am Post subject: 3.5 mm 4 pole socket |
This?
http://www.showmecables.com/product/3-5mm-Jack-TRRS-Connector-Plastic.aspx?utm_source=google&utm_medium=cse&utm_campaign=947&zmam=49733141&zmac=5&zmas=1&zmap=947&gclid=CKiA0_GvqMQCFdccgQoda5EAxw
Rick Girard
-Andre Gide
| [b]
etienne.phillips(at)gmail Guest
Posted: Tue Mar 17, 2015 4:27 am Post subject: 3.5 mm 4 pole socket |
Hi Richard
Having been down a similar path recently (however looking for the plug and not the socket) I came across two different standards of 3.5mm TRRS plugs. If you do find something that looks like what you need online, make sure the dimensions are suitable! The longer version (red) is manufactured by Cliff in the UK, and they do sell to the public. This seems to be used on many set-top-box media players. The shorter version (black) is more commonly used in handheld devices, and relatively easy to come by. They are not mechanically or electrically compatible, with a different order of the connectors. Even Ground is Sleeve on one and Second Ring on the other!
See attached pictures for comparison.
Etienne
[img]cid:ii_14c27b0346e6b4e3[/img][img]cid:ii_14c27b0352cdde19[/img]
On 14 March 2015 at 18:21, Richard Girard <aslsa.rng(at)gmail.com (aslsa.rng(at)gmail.com)> wrote:
Rick Girard
-Andre Gide
87.78 KB |
6525 Time(s) |
174.56 KB |
6525 Time(s) |
Posted: Tue Mar 17, 2015 6:59 am Post subject: 3.5 mm 4 pole socket |
The difference in contact assignments on this plug type is vast, as it has been used for many purposes, from audio with microphone, to audio with battery charging, to serial data interface. It's not even consistent among cell phone models with respect to ground and microphone assignment.
If you're sourcing a patch cable with the same plug at both ends, it makes no difference, but plug adapter cables with something other than TRRS on one end require care to ensure compatibility.
See http://bit.ly/1FvOcuj for a long list of TRRS plug applications.
Eric
On Mar 17, 2015, at 5:26 AM, Etienne Phillips <etienne.phillips(at)gmail.com> wrote:
| Quote: | Hi Richard
Etienne
