scott(at)s-f-x.com Guest
Posted: Wed Mar 11, 2015 12:20 am Post subject: Tank construction details - XP |
Hi All
Does anyone have the spec of the construction of the wing tanks on an XP ? I’m replacing the little filler caps and drain plugs and the composite people need to know what layers are in there in order to draw up the plans to get it past the LAA (UK home-builder’s governing body). I have the manuals but they seem to be for the fuselage tank version.
Scott MacIntyre
mjb777
Posted: Wed Mar 11, 2015 12:40 am Post subject: Re: Tank construction details - XP |
What's your email address scott?
I have the original AD wing tank supplement in PDF I can email to you.
Matt.
_________________ Pulsar 1 TD Kit.
Captain B777.
Licenced Aircraft Maintenance Engineer. |
briana(at)xtra.co.nz Guest
Posted: Wed Mar 11, 2015 10:38 am Post subject: Tank construction details - XP |
My XP kit came with the filler neck already bonded into the wing tank moulding and there are no layup details in the manual. There is however a cross section diagram illustrating how it is done.
Basically the top skin seems to be removed to allow the filler neck sit down flush with the outer skin. There is no evidence of a lamination being applied over that, but that might be wise. Then there is the normal micro fillet around the neck, inside the tank, and glass over that. The whole inside is sealed of course [by the builder] with Jeffco 9700.
Brian
XP #456
| Quote: | On 11/03/2015, at 9:19 pm, Scott MacIntyre <scott(at)s-f-x.com (scott(at)s-f-x.com)> wrote:
Hi All
Scott MacIntyre
class="">http://www.matronics.com/Navigator?Pulsar-List
class="">http://forums.matronics.com
class="">http://www.matronics.com/contribution
