bertrv6(at)gmail.com Guest
Posted: Thu Mar 05, 2015 12:30 pm Post subject: RV6-List Digest: 1 Msgs - 11/16/14 |
If I remember, one point that can leak would be at the pressure nut,
at either end.or
the tube has to be properly flange?
It has been so long, I was lucky never had a leak, wing or valve
Had to bend the tubing , that is made at least three different tubes
to get the right turns etc.
robert
On Mon, Nov 17, 2014 at 3:03 AM, RV6-List Digest Server
<rv6-list(at)matronics.com> wrote:
Quote: | *
Today's complete RV6-List Digest can also be found in either of the
of the RV6-List Digest and can be viewed with a generic text editor
HTML Version:
http://www.matronics.com/digest/digestview.php?Style=82701&View=html&Chapter 14-11-16&Archive=RV6
Text Version:
http://www.matronics.com/digest/digestview.php?Style=82701&View=txt&Chapter 14-11-16&Archive=RV6
RV6-List Digest Archive
Total Messages Posted Sun 11/16/14: 1
Today's Message Index:
1. 03:47 AM - Re: Andair Fuel Selector Connections (Smcm75(at)aol.com)
________________________________ Message 1 _____________________________________
Time: 03:47:42 AM PST US
Subject: Re: Andair Fuel Selector Connections
Try checking your wing tanks for weaping leaks around the inspection
plates or near the aft lower tank skin and rib intersection. the fuel will
puddle on the bottom of the wing root fairing and the smell will get into the
cockpit.
Scott Morrow
RV-6A N548SM
Myrtle Beach, SC
In a message dated 11/16/2014 2:28:07 A.M. Eastern Standard Time,
genie(at)swissmail.org writes:
Due to an odour of fuel in the cockpit I suspect that the tubes or pipes
to the fuel selector are not sufficiently tight. I have unscrewed them
and cleaned them and reattached. This has not fully solved the problem.
Is there any way I can clean the tubes or pipes thoroughly and then seal
them tight to avoid a leak? could the problem be with the fuel selector?
I cannot see any other source of fuel leak.
If I am not mistaken I have an FS20 Type 3 valve.
Thanks.
George Nielsen
RV-6 PH-XGN
The Hague, the Netherlands
| - The Matronics RV6-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?RV6-List |
