Handheld transceiver alternate antenna
jrevens
PostPosted: Mon Feb 23, 2015 8:23 pm    Post subject: Handheld transceiver alternate antenna Reply with quote
Is there an efficient, elegant way to connect an external aircraft comm antenna to a handheld radio in the event of failure of the panel-mounted radio that the antenna is connected to? I know that I could run the cable within reach of the pilot, with connectors inline to break the connection to the panel and connect to the handheld unit. That's what I did on my first homebuilt. However, I envision a panel-mounted male BNC connector that could possibly be used to connect the handheld without physically disconnecting the failed radio, providing that radio is switched off. If this is possible, I'm wondering if some kind of antenna switch or splitter would be necessary. I'm talking about the antenna only serving one radio at a time. This is very possibly a dumb question.
Thanks in advance for any replies!
John Evens
Thorp T-18 N71JE (sold)
Kitfox SS7 N27JE (built & flying)
ChasB(at)satx.rr.com
PostPosted: Tue Feb 24, 2015 7:47 am    Post subject: Handheld transceiver alternate antenna Reply with quote
I installed a second external antenna that matches the one I use for my main radio. The antenna cable terminates at a BNC connection on my panel. I can quickly connect my handheld to the BNC with a patch cord. With the exception of the cost of a second antenna, the installation was quick and simple. Works well.
Charlie Brame
RV-6A N11CB
San Antonio
[quote]Time: 08:23:42 PM PST US
From: John <jrevens(at)comcast.net (jrevens(at)comcast.net)>
Subject: Handheld transceiver alternate antenna
PostPosted: Tue Feb 24, 2015 8:18 am    Post subject: Handheld transceiver alternate antenna Reply with quote
Since the h-h is backup for a failed radio,
only ONE antenna can be made to service both
appliances. One of my favorite 'back up' antenna
arrangements suggests arranging a coiled-up
excess of comm antenna feed-line to be situated
in a handy but out of sight location. A BNC cable
male/female joint on the panel-radio end of the
coil. Of course, this excess cable should not
be retained in a manner requiring more than
your fingers to access, break the joint and
uncoil it.
Should it become necessary to put the h-h
into service, you can string out the coax
and hook it to the radio.
[img]cid:7.1.0.9.0.20150224100526.02004028(at)aeroelectric.com.0[/img]
Unfortunately, this particular arrangement is a
bit un-graceful.
Consider this . . .
[img]cid:7.1.0.9.0.20150224100526.02004028(at)aeroelectric.com.1[/img]
A pair of right angle adapters can be used to
bring the antenna coax down the back of the
radio such that the whole becomes more like
a microphone. If your BNC cable male on the
feed-line is already a right-angle connector,
then you only need one adapter to get the 180
degree, tight bend.
 Filesize:  157.63 KB
 Viewed:  11980 Time(s)
 Filesize:  178.04 KB
jrevens
PostPosted: Tue Feb 24, 2015 12:07 pm    Post subject: Re: Handheld transceiver alternate antenna Reply with quote
To clarify a little, I was thinking of installing a BNC tee in the line between the panel mounted radio and the antenna. Then I would bring a short "branch" from that tee to a panel-mounted male BNC, and possibly close that off with the proper terminating cap until it is used. I would have a short section of antenna cable with connectors already attached to and stored with the handheld. Would this kind of arrangement have shortcomings in the way of signal strength or other losses?
John Evens
Thorp T-18 N71JE (built and flying)
Kitfox SS7 N27JE (building)
John Evens
ceengland7(at)gmail.com
PostPosted: Tue Feb 24, 2015 2:40 pm    Post subject: Handheld transceiver alternate antenna Reply with quote
Don't do it. One radio's transmitter would directly drive the other's receiver; not a good plan for a number of reasons (which might include smoke).
On February 24, 2015 2:07:15 PM CST, jrevens <jrevens(at)comcast.net> wrote:
--> AeroElectric-List message posted by: "jrevens" <jrevens(at)comcast.net>To clarify a little, I was thinking of installing a BNC tee in the line between the panel mounted radio and the antenna. Then I would bring a short "branch" from that tee to a panel-mounted male BNC, and possibly close that off with the proper terminating cap until it is used. I would have a short section of antenna cable with connectors already attached to and stored with the handheld. Would this kind of arrangement have shortcomings in the way of signal strength or other losses?John EvensThorp T-18 N71JE (built and flying)Kitfox SS7 N27JE (building)--------John EvensRead this topic online here:http://forums.matronics.com/viewtopic.php?p=438670#438670_
Sent from my Android device with K-9 Mail. Please excuse my brevity. [quote][b]
john.maccallum(at)bigpond
PostPosted: Tue Feb 24, 2015 10:43 pm    Post subject: Handheld transceiver alternate antenna Reply with quote
You could install a Coaxial Switch. The output to the Antenna and one port to the Ships Radio and one port to a Socket mounted somewhere convenient that you can plug a Handheld into.
Just remember not transmit into an open port. I.e. don’t leave the ships Radio on if you plan to use the Handheld.
Cheers
John MacCallum
VH-DUU
RV 10 # 41016
From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of John
Sent: Tuesday, 24 February 2015 3:19 PM
         - List Contribution Web generous                          -Matt http://www.matronics.com/c=[/b]
wrmaxwell(at)bigpond.com
PostPosted: Tue Feb 24, 2015 11:05 pm    Post subject: Handheld transceiver alternate antenna Reply with quote
That is the only way I would contemplate sharing a single antenna with two radios.
 Apart from avoiding the likelihood of transmitting into an open port or delivering your transmitter's full output power into the other radios receiver, potentially with dire consequences, we should not forget that these radios have a design antenna impedance of 50 ohms, as does the antenna, giving the sought after perfect match.
Hook up two radios simultaneously and the apparent radio end impedance becomes 50/2, or 25 ohms. Immediate mismatch.
Bill
19-4446
Jodel D18, also in Oz.
On 25/02/2015 5:41 PM, John MacCallum wrote:
[quote] <![endif]--> <![endif]-->
Cheers
John MacCallum
VH-DUU
RV 10 # 41016
From: owner-aeroelectric-list-server(at)matronics.com (owner-aeroelectric-list-server(at)matronics.com) [mailto:owner-aeroelectric-list-server(at)matronics.com (owner-aeroelectric-list-server(at)matronics.com)] On Behalf Of John
 http://www.matronics.com/Navigator?AeroElectric-Listhttp://forums.matronics.com         - List Contribution Web generous �                        -Matt http://www.matronics.com/c=
dlj04(at)josephson.com
PostPosted: Wed Feb 25, 2015 12:38 am    Post subject: Handheld transceiver alternate antenna Reply with quote
or other losses?
Yes, many. It won't work. RF is not like water pipe. Besides damaging whichever radio was not transmitting, the impedance mismatch would badly compromise receive and transmit range.
PostPosted: Wed Feb 25, 2015 3:47 am    Post subject: Handheld transceiver alternate antenna Reply with quote
Yes RF is not like water. It's far more fickle and you can't use a
terminating cap because of the power involved during transmit. You would fry
a terminating resistor that was plugged into the free port plus the
impedance would be halved. Hence an SWR of 2:1 before it even gets to the
antenna.
A tee in the feedline is not a good idea. It will work but there are a lot
of things that can go wrong with that setup. Up to and including
accidently transmitting into your HH with the ships radio or visa versa.
It is best to use a Coaxial switch or have a patch panel.
To make a Patch panel you will need one BNC socket (female) and one
Connector (male) mounted on a small bracket and a Jumper Lead with one
Connector and one socket. The Jumper plugs into the Ships Radio via a socket
and a socket on the other end goes to the Antenna via the from the
connector. You disconnect the Ships Radio end of the jumper and plug into
the hand held. The reason for making the jumper male and female is so you
don't accidently plug into the Ships radio with the
Hand Held. Don't laugh it is easy done! I still vote for a coaxial switch
it's a lot easier. They can be bought for not much money from a Ham Radio
supplier.
Cheers
John MacCallum
VH-DUU
RV 10 # 41016
BobsV35B(at)aol.com
PostPosted: Wed Feb 25, 2015 6:01 am    Post subject: Handheld transceiver alternate antenna Reply with quote
Good Morning All,
Just to jump in on a message already well answered, I would like to add my thoughts.
We have a Piper Pacer equipped with just one radio. A Garmin 430W.  The aircraft is flown IFR regularly.
In order to add a bit of reliable back up, we do carry a handheld and have installed a separate external antenna just for that radio. It is a bit of extra drag and a bit more weight, but when a back up is actually needed, it is nice to know that the unit has an antenna all of it's own. Just my idea of a full backup totally separated from the primary radio system.
Decisions, decisions. All the time decisions! <G>
Happy Skies,
Old Bob
AKA
Bob Siegfried
Ancient Aviator
PA-20
Brookeridge Air Park LL22
Downers Grove, IL
PostPosted: Wed Feb 25, 2015 2:02 pm    Post subject: Handheld transceiver alternate antenna Reply with quote
Probably a little bit of overkill for what you want it for. That particular one has a relay so that you can remote switch it. You can get good
quality manual ones for a lot less than what that will cost although of course not quite as neat and tidy as a remote mounted switch such as that.
A quick search around I can find some N type connector switches for around $50. You would need to terminate the Antenna Feedline with and N connector
for the one in the link below but that’s actually a better specification than BNC. If you look around a bit you could probably find a BNC terminated type.
http://www.hamradio.com/detail.cfm?pid=H0-003421
Cheers
John MacCallum
VH-DUU
RV 10 # 41016
From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Ken Ryan
Sent: Thursday, 26 February 2015 3:58 AM
Subject: Re: Re: Handheld transceiver alternate antenna
Attached is a pdf data sheet for a coaxial switch. Question: would this switch be a good choice?
On Wed, Feb 25, 2015 at 2:46 AM, John MacCallum <john.maccallum(at)bigpond.com (john.maccallum(at)bigpond.com)> wrote:
--> AeroElectric-List message posted by: John MacCallum <john.maccallum(at)bigpond.com (john.maccallum(at)bigpond.com)>
antenna.
supplier.
Cheers
John MacCallum
VH-DUU
RV 10 # 41016
PostPosted: Wed Feb 25, 2015 2:14 pm    Post subject: Handheld transceiver alternate antenna Reply with quote
Yes Bob that was something else I thought about to suggest. If the extra drag is not an issue a dedicated antenna is a good solution.
Cheers
John MacCallum
VH-DUU
RV 10 # 41016
From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of BobsV35B(at)aol.com
Sent: Thursday, 26 February 2015 1:00 AM
Good Morning All,
Happy Skies,
Old Bob
AKA
Bob Siegfried
Ancient Aviator
PA-20
Downers Grove, IL
kenryan
PostPosted: Wed Feb 25, 2015 2:22 pm    Post subject: Handheld transceiver alternate antenna Reply with quote
Not considering price, are the specs what they should be? And to those
suggesting the switch is the best solution, wouldn't there exist the danger
of the switch being in the wrong position, and then trying to transmit with
the equivalent of "no antenna" attached? I've heard that's not a smart
thing to do.
On Wed, Feb 25, 2015 at 12:59 PM, John MacCallum <john.maccallum(at)bigpond.com
wrote:
[quote] Probably a little bit of overkill for what you want it for. That
good
PostPosted: Wed Feb 25, 2015 2:34 pm    Post subject: Handheld transceiver alternate antenna Reply with quote
It could be made to work Ken but it is more complicated than necessary. It also needs a 12 volt supply and utilises SMA connectors. I suggest you look for a much simpler mechanical switch type. They are commonly available from ham radio suppliers and usually are fitted with SO-239 connectors. Connection is selected by simply turning a knob or flicking a switch. Better reliability.
Bill
On 26/02/2015 3:58 AM, Ken Ryan wrote:
[quote] Attached is a pdf data sheet for a coaxial switch. Question: would this switch be a good choice?
[quote]--> AeroElectric-List message posted by: John MacCallum <john.maccallum(at)bigpond.com (john.maccallum(at)bigpond.com)>
antenna.
supplier.
Cheers
John MacCallum
VH-DUU
RV 10 # 41016
rv7a.builder(at)yahoo.com
PostPosted: Wed Feb 25, 2015 3:04 pm    Post subject: Handheld transceiver alternate antenna Reply with quote
deej(at)deej.net
PostPosted: Wed Feb 25, 2015 6:28 pm    Post subject: Handheld transceiver alternate antenna Reply with quote
I have a Narco VP-16 antenna switch that I will sell for $25 including
shipping in the continental US. It uses BNC connectors, and switches
one antenna between two radios. It is essentially an electrical relay
that switches with 12v. Wiring connector included.
Pic on my website
http://deej.net/forsale/
-Dj
Dj Merrill - N1JOV - EAA Chapter 87
Sportsman 2+2 Builder #7118 N421DJ - http://deej.net/sportsman/
Glastar Flyer N866RH - http://deej.net/glastar/
