Intercom question
jrevens
PostPosted: Tue Feb 03, 2015 11:27 am    Post subject: Intercom question Reply with quote
My EAA chapter has spawned a group of young people known as the "Young Aviators". They are constructing a mockup of a B-25 that they are planning to transport to Oshkosh this year. A question has come up... is there a simple way to hook up 7 individual headsets w/ microphones so that the entire "crew" can talk back & forth, without having to somehow patch together off the shelf 4 or 2 place intercoms? Some kind of simple circuitry that could be easily built? Thanks in advance for any ideas or suggestions.
John Evens
John Evens
Thorp T-18 N71JE (sold)
Kitfox SS7 N27JE (built & flying)
PostPosted: Wed Feb 04, 2015 12:36 pm    Post subject: Intercom question Reply with quote
What kind of microphones/headsets? Aviation
style? Over what distances are the wires
routed? The task is 'easy' . . . just
need some details on the hardware you
plan to use.
jrevens
PostPosted: Fri Feb 06, 2015 9:14 pm    Post subject: Re: Intercom question Reply with quote
Thanks, Bob. It looks like they are going to use aviation headsets... probably donated units of various brands. Not everyone has to necessarily be able to "transmit" (push-to-talk) to the other headsets - perhaps only 1 or 2 ("pilot" & "co-pilot"), & everyone else able to hear at least. The mock-up is basically of the nose section, so maximum distances of wire runs would be approximately 10 or 15 feet. The leaders of this project feel that it will add to the experience if the kids can connect in this way. BTW, this project is written about in the latest "Sport Aviation" magazine on p.110.
John Evens
dbrown2(at)nycap.rr.com
PostPosted: Sat Feb 07, 2015 4:13 am    Post subject: Intercom question Reply with quote
Just read the article ...very cool!
PostPosted: Sat Feb 07, 2015 6:41 am    Post subject: Intercom question Reply with quote
At 23:14 2015-02-06, you wrote:
--> AeroElectric-List message posted by: "jrevens" <jrevens(at)comcast.net>
John Evens
Understand. My recommendation is to start with
any sort of pre-packaged audio amplifier. One
like this would work nicely.
[img]cid:.0[/img]
There are dozens of similar devices on eBay. I've
used a bunch in various applications with good
results and value. You can power them up with a
12v 'wall wart'. In fact, if you'll shoot me an
address, I donate an amplifier and power supply
to the project.
The next thing you need to do is cobble up the
interface that makes an aircraft microphone 'look'
like something found in the rest of the world . . .
[img]cid:.1[/img]
A circuit like that shown above will allow
you to bias-up and mix as many microphones
together as needed. PTT for any particular
mic can be a simple n.c. push button in parallel
with the microphone. The button shorts out the
mic unless being used. This is preferable to
putting a n.o. button in series . . . the
parallel configuration reduces the DC level
shift and resulting 'pop' you hear in the system
as any one microphone is keyed.
Headphones can simply be paralleled assuming
they're all about the same efficiency where volume
can be managed by the single control on the amplifier.
Recommended circuitry not shown is a 220 ohm, 1/2
watt resistor in series with each line out to
a headset. At worst, you may have to balance
relative audio levels in the headsets which
can be accomplished by adjusting the value of that
220 ohm resistor.
Got somebody in your group that's handy
slinging solder?
 Filesize:  72.75 KB
 Viewed:  7700 Time(s)
 Filesize:  91.3 KB
jrevens
PostPosted: Sun Feb 08, 2015 11:55 am    Post subject: Re: Intercom question Reply with quote
--> AeroElectric-List message posted by: "jrevens" <jrevens>
John Evens
[img]cid:.0[/img]
to the project.
[img]cid:.1[/img]
220 ohm resistor.
slinging solder?
Thank you so much, Bob! That's exactly what I was hoping for.
I'm sure I can handle building the mic mixing circuit. If I used an
adjustable 1/2 watt potentiometer to each headset, what value
would you recommend - 220 ohm, or higher? Probably a stupid
question, but what type capacitors should I use - electrolytic, or?
I would gratefully accept your offer of an amp & power supply...
I will send you an email. Again, from myself, our chapter, and
the Young Aviators - thank you!!
John Evens
PostPosted: Sun Feb 08, 2015 2:09 pm    Post subject: Intercom question Reply with quote
Got the mailing address. I dug out an amplifier
and power supply. Need to find my MP3 player to
test it for functionality.
What you might consider is a volume control
at each station where a headset is plugged in.
Set the master volume on the amplifier on
the 'generous' side and let each station
set their own volume to suit.
There's some other options to consider. If
some of the stations are listen-only, you
could use contemporary headsets (10-50
ohm) for a lot less money than aviation
headsets (100+ ohms). Each station's
volume control would be a 50-ohm,
wire wound potentiometer.
http://tinyurl.com/nqruvxd
The capacitors shown are all electrolytic.
Any time you see a "+" sign associated with
the symbol, that tells you that it's some
form of electrolytic. I've got all those
parts in my sand-box-bins. I'll include
a kit of loose parts with the amplifier.
PostPosted: Fri Mar 13, 2015 3:02 am    Post subject: Re: Intercom question Reply with quote
Here is a link to the B-25 Project for KidVenture:
http://tinyurl.com/B-25-Project
Joe Gores
