Removing and Attaching Wings Single Handed
genie(at)swissmail.org
PostPosted: Sun Jan 11, 2015 7:05 am    Post subject: Removing and Attaching Wings Single Handed Reply with quote
Hello,
As I am considering the Europa I would be grateful if you could inform
me about the possibilities of removing and attaching the wings single
handed. I have seen in the manual that this can be done by two people.
However, my requirement is for this to be done single handed, as hangar
space is expensive.
My idea is to go to the airfield, attach the wings on the aircraft, fly
and prior to inserting in the hangar to remove the wings. Is there any
equipment available which enables this to be done single handed with an
Europa? In that case I reckon that the equipment will be bound at the
home base so removing and reattaching wings will not be possible at
other airfields.
Thank you for your reply.
George Nielsen
alan.twigg775(at)gmail.co
PostPosted: Sun Jan 11, 2015 7:21 am    Post subject: Removing and Attaching Wings Single Handed Reply with quote
Many gliders and some Europas have a 'one man (woman)' rigging aid. It consists of a wing dolly that can be rotated between vertical and horizontal, while you handle the wing root. I digest you look initially on glider web sites.
Alan Twigg
MotorGlider
Kit463
On 11 Jan 2015, at 15:04, George Nielsen <genie(at)swissmail.org> wrote:
Hello,
As I am considering the Europa I would be grateful if you could inform me about the possibilities of removing and attaching the wings single handed. I have seen in the manual that this can be done by two people. However, my requirement is for this to be done single handed, as hangar space is expensive.
My idea is to go to the airfield, attach the wings on the aircraft, fly and prior to inserting in the hangar to remove the wings. Is there any equipment available which enables this to be done single handed with an Europa? In that case I reckon that the equipment will be bound at the home base so removing and reattaching wings will not be possible at other airfields.
George Nielsen
rowlandcarson(at)gmail.co
PostPosted: Sun Jan 11, 2015 7:43 am    Post subject: Removing and Attaching Wings Single Handed Reply with quote
George - yes, one-man (or one-woman) rigging is possible. I’ve been doing quite a bit of that recently while setting up the wing pin sockets; see my photo pages:
http://www.rowlandcarson.org.uk/aviation/europa_435/dolly_transfer.php
http://www.rowlandcarson.org.uk/aviation/europa_435/first_wing_rig.php
http://www.rowlandcarson.org.uk/aviation/europa_435/try_wing_incidence.php
for pictures of the fuselage and wing dollies.
Yes, the rigging kit definitely stays at the departure airfield!
My dollies came with the covered trailer I bought from Roger Huttlestone who operates from an industrial unit near Moreton-in-Marsh. However, I believe that he is no longer making the trailers. It's possible he might consider making the rigging kit if he still has the templates and fixtures.
Please let me know if you would like contact details for Roger (he does seem to be well-known to Google . . . ).
in friendship
Rowland
| <rowlandcarson(at)gmail.com> http://www.rowlandcarson.org.uk/aviation/europa_435/index.php
| LAA #016532
PostPosted: Sun Jan 11, 2015 8:02 am    Post subject: Removing and Attaching Wings Single Handed Reply with quote
Row land, I see you have two dollys, have you found a cheap source, I am being quoted over £500 for one.
Alan Twigg
Kit 463
Getting ready for cockpit trim.
in friendship
Rowland
| LAA #016532
Philipgeorge347(at)hotmai
PostPosted: Sun Jan 11, 2015 8:33 am    Post subject: Removing and Attaching Wings Single Handed Reply with quote
Hi  George
Yes it is straight forward single person rigging as Alan  said. You will need a dolly constructed  that swivels thru 90 degrees  with golf cart wheels etc.  I constructed one ,as I use to rig and de- rig my europa every flight up until  3 or 4  years ago.
             Philip George.
Sent from Samsung Mobile
-------- Original message --------
Date:11/01/2015 15:08 (GMT+00:00)
Subject: Removing and Attaching Wings Single Handed
--> Europa-List message posted by: George Nielsen <genie(at)swissmail.org>
Hello,
space is expensive.
other airfields.
George Nielsen
r Lists This Month --
;  (And Get Some AWESOME FREE Gifts!)
k on
> > aeroelectric.com">www.aeroelectric.com
http://www.buildersbooks.com">www.buildersbooks.com
.homebuilthelp.com">www.homebuilthelp.com
w.mypilotstore.com">www.mypilotstore.com
ww.mrrace.com">www.mrrace.com
tion">http://www.matronics.com/contribution
;                     -Matt Dralle, List Admin.
; - The Europa-List Email Forum -
r?Europa-List">http://www.matronics.com/Navigator?Europa-List
;      - MATRONICS WEB FORUMS -
://forums.matronics.com
ptag.dev(at)talktalk.net
PostPosted: Sun Jan 11, 2015 10:42 am    Post subject: Removing and Attaching Wings Single Handed Reply with quote
Hi! George,
You don't specify Mono Wheel or trike.
However my submissions shown at:-
http://www.users.waitrose.com/~jcliff/BobH/BobH.htm
PostPosted: Sun Jan 11, 2015 10:49 am    Post subject: Removing and Attaching Wings Single Handed Reply with quote
Alan - I don’t know what proportion of the trailer cost was allocated by Roger Huttlestone to the dollies etc. He gave me a discount on the standard trailer and rigging set price because I fitted the ramp, floored, undersealed and wired the trailer myself, and also provided some manual labour for fitting the roof at his workshop. His bill in November 1999 came to £3850.
If Roger’s not prepared to make the rigging kit any more (I see he’s into car restorations now), I’m sure he wouldn’t mind you taking measurements from mine to prepare a spec for construction by A N Other.
in friendship
Rowland
| pictures: http://picasaweb.google.com/rowlandcarson
wdaniell.longport(at)gmai
PostPosted: Sun Jan 11, 2015 10:55 am    Post subject: Removing and Attaching Wings Single Handed Reply with quote
My rather unsighly but effective set up.  There are two pretty much the same per wing...I copied them from a much neater version but I dont remember who.
Will On Jan 11, 2015 10:23 AM, <alan.twigg775(at)gmail.com (alan.twigg775(at)gmail.com)> wrote:
--> Europa-List message posted by: alan.twigg775(at)gmail.com (alan.twigg775(at)gmail.com)
Alan Twigg
MotorGlider
Kit463
> On 11 Jan 2015, at 15:04, George Nielsen <genie(at)swissmail.org (genie(at)swissmail.org)> wrote:
> --> Europa-List message posted by: George Nielsen <genie(at)swissmail.org (genie(at)swissmail.org)>
> Hello,
> George Nielsen
br> fts!)
r> > com" target="_blank">www.aeroelectric.com
w.buildersbooks.com" target="_blank">www.buildersbooks.com
p.com" target="_blank">www.homebuilthelp.com
e.com" target="_blank">www.mypilotstore.com
" target="_blank">www.mrrace.com
pa-List" target="_blank">http://www.matronics.com/Navigator?Europa-List
 Filesize:  1.91 MB
 Viewed:  12293 Time(s)
hagargs(at)earthlink.net
PostPosted: Sun Jan 11, 2015 3:00 pm    Post subject: Removing and Attaching Wings Single Handed Reply with quote
With the wings off you will need a dolly that quickly attaches and removes. The unit I ginned up has been very robust. I have done full throttle run ups many times with the wings off. With the plane tied to the back of the car of course. See short video
https://www.youtube.com/watch?v=BHYtCRwemiA
Steve
grahamsingleton(at)btinte
PostPosted: Mon Jan 12, 2015 2:20 am    Post subject: Removing and Attaching Wings Single Handed Reply with quote
Alan
have a look at Andreas Doblhof's one man rig. Five minutes when I watched him do it
Graham
From: "alan.twigg775(at)gmail.com" <alan.twigg775(at)gmail.com>
To: "europa-list(at)matronics.com" <europa-list(at)matronics.com>
Sent: Sunday, 11 January 2015, 16:02
Subject: Re: Europa-List: Removing and Attaching Wings Single Handed
Alan Twigg
Kit 463
On 11 Jan 2015, at 15:42, Rowland Carson <rowlandcarson(at)gmail.com (rowlandcarson(at)gmail.com)> wrote:
--> Europa-List message posted by: Rowland Carson <rowlandcarson(at)gmail.com (rowlandcarson(at)gmail.com)>
in friendship
Rowland
| <rowlandcarson(at)gmail.com (rowlandcarson(at)gmail.com)> http://www.rowlandcarson.org.uk/aviation/europa_435/index.php
| LAA #016532[b]http://www.matronics.com/Navigator?Europa-List
_ref="http://forums.matronics.com/" target="_blank">http://forums.matron===================
 Filesize:  536.76 KB
 Viewed:  12258 Time(s)
 Filesize:  557.63 KB
 Filesize:  556.72 KB
 Filesize:  540.21 KB
 Filesize:  549.29 KB
Jim Kelly
PostPosted: Mon Jan 12, 2015 4:27 am    Post subject: Removing and Attaching Wings Single Handed Reply with quote
Hi Graham,                   Is there anymore info on this system, I can't figure it out.
Cheers
Jim Kelly G-BWEG
On Monday, January 12, 2015, GRAHAM SINGLETON <grahamsingleton(at)btinternet.com (grahamsingleton(at)btinternet.com)> wrote:
[quote]Alan
Graham
From: "[url=javascript:_e(%7B%7D,'cvml','alan.twigg775(at)gmail.com');]alan.twigg775(at)gmail.com[/url]" <[url=javascript:_e(%7B%7D,'cvml','alan.twigg775(at)gmail.com');]alan.twigg775(at)gmail.com[/url]>
To: "[url=javascript:_e(%7B%7D,'cvml','europa-list(at)matronics.com');]europa-list(at)matronics.com[/url]" <[url=javascript:_e(%7B%7D,'cvml','europa-list(at)matronics.com');]europa-list(at)matronics.com[/url]>
Subject: Re: Removing and Attaching Wings Single Handed
--> Europa-List message posted by: [url=javascript:_e(%7B%7D,'cvml','alan.twigg775(at)gmail.com');]alan.twigg775(at)gmail.com[/url]
Alan Twigg
Kit 463
On 11 Jan 2015, at 15:42, Rowland Carson <[url=javascript:_e(%7B%7D,'cvml','rowlandcarson(at)gmail.com');]rowlandcarson(at)gmail.com[/url]> wrote:
--> Europa-List message posted by: Rowland Carson <[url=javascript:_e(%7B%7D,'cvml','rowlandcarson(at)gmail.com');]rowlandcarson(at)gmail.com[/url]>
> On 11 Jan 2015, at 15:04, George Nielsen <[url=javascript:_e(%7B%7D,'cvml','genie(at)swissmail.org');]genie(at)swissmail.org[/url]> wrote:
in friendship
Rowland
| <[url=javascript:_e(%7B%7D,'cvml','rowlandcarson(at)gmail.com');]rowlandcarson(at)gmail.com[/url]>  http://www.rowlandcarson.org.uk/aviation/europa_435/index.php
| LAA #016532http://www.matronics.com/Navigator?Europa-List
Jim GBWEG
PostPosted: Mon Jan 12, 2015 1:38 pm    Post subject: Removing and Attaching Wings Single Handed Reply with quote
Hi Rob,
You are right: I did not specify monowheel, nosewheel or conventional
tailwheel. That is because I am flexible, as it may be that with one
configuration it is easier to remove and attach the wings. However, I
doubt whether this is the case. The replies I received have indeed given
me the impression that the type of undercarriage does not make much
difference in this respect.
The configuration I am most inclined to get is monowheel, as it is the
most efficient in flight as it is retractable. Thus it makes bes use of
the space between the two seats.
Thanks to all of you who replied.
George Nielsen
On 12/01/2015 09:02, Europa-List Digest Server wrote:
Time: 10:42:17 AM PST US
Subject: RE: Removing and Attaching Wings Single Handed
Hi! George,
PostPosted: Mon Jan 12, 2015 2:03 pm    Post subject: Removing and Attaching Wings Single Handed Reply with quote
Rowland, thank you for your replies and the links to photos.
I have found the following about Roger Huttlestone:
Unit 103b Northwick Busns Cntr
Moreton-In-Marsh, Gloucestershire GL56 9RF
United Kingdom
tel: +44 1386700709
See:
http://transportation.zibb.co.uk/profile/roger+huttlestone/gb/gloucestershire/moreton-in-marsh/gl56+9rf/23710237
Roger has entries in LinedIn, Facebook and Twitter.
Considering the fact that this is a company I am surprised that it does not have any URL. I could not find any e-mail address either. But that is understandable, as putting one would make one vulnerable to Web trawling, spam and what not.
George Nielsen
George - yes, one-man (or one-woman) rigging is possible. Ive been doing quite
in friendship
Rowland
'w' ...
| <rowlandcarson(at)gmail.com> (rowlandcarson(at)gmail.com) http://www.rowlandcarson.org.uk/aviation/europa_435/index.php
| LAA #016532
brian.davies(at)clara.co.
PostPosted: Tue Jan 13, 2015 12:49 am    Post subject: Removing and Attaching Wings Single Handed Reply with quote
Hi George,
If you remove the wings on a Mono and do nothing else, it falls over. If
you do the same thing on a Trigear or conventional, nothing happens!
I think this makes a significant difference to the ease of the process.
Ex Mono, now Trigear
Brian Davies
PostPosted: Tue Jan 13, 2015 1:54 pm    Post subject: Removing and Attaching Wings Single Handed Reply with quote
Hi Jim,
This is what I found about Andreas Doblhof's system:
http://www.europaowners.org/main.php?g2_itemId=46082
http://sdunsmuir.net/EuropaOwners/public_html/Galley3/Builders-Album/Dolly/Andreas-Doblhof-s-rigging-system/Andreas_Doblhof_home
The Europa sports the Austrian flag on its fin and the vehicle has
similarly an Austrian number plate.
George Nielsen
On 13/01/2015 09:02, Europa-List Digest Server wrote:
Time: 04:27:41 AM PST US
Hi Graham,
out.
Cheers
Jim Kelly G-BWEG
grahamsingleton(at)btinternet.com> wrote:
> Alan
> him do it
> Graham
> *From:* "alan.twigg775(at)gmail.com
> <javascript:_e(%7B%7D,'cvml','alan.twigg775(at)gmail.com');>" <
> <javascript:_e(%7B%7D,'cvml','alan.twigg775(at)gmail.com');>>
> *To:* "europa-list(at)matronics.com
> <javascript:_e(%7B%7D,'cvml','europa-list(at)matronics.com');>" <
> <javascript:_e(%7B%7D,'cvml','europa-list(at)matronics.com');>>
> *Sent:* Sunday, 11 January 2015, 16:02
> *Subject:* Re: Removing and Attaching Wings Single Handed
> being quoted over =C2=A3500 for one.
> Alan Twigg
> Kit 463
> Sent from my iPhone
