Kelly McMullen
Posted: Thu Dec 04, 2014 8:11 pm Post subject: Latest Parking brake victim |
Less than 24 hours after bleeding my brakes I was seeing a drip or two from the infamous Matco parking brake, even though I have only applied foot pressure to the brake pedals for less than 10 seconds total.
Any body got a mechanically competent, slightly malnourished 10 yr old for rent?
A&P/IA, EAA Tech Counselor
KCHD |
philperry9
Posted: Thu Dec 04, 2014 8:26 pm Post subject: Latest Parking brake victim |
Kelly,
Can you wait 6 years? I'll start starving and training him today and he should be perfect by the time he's 10.
Phil
On Dec 4, 2014, at 10:08 PM, Kelly McMullen <apilot2(at)gmail.com (apilot2(at)gmail.com)> wrote:
[quote]Less than 24 hours after bleeding my brakes I was seeing a drip or two from the infamous Matco parking brake, even though I have only applied foot pressure to the brake pedals for less than 10 seconds total.
davidsoutpost(at)comcast. Guest
Posted: Thu Dec 04, 2014 8:34 pm Post subject: Latest Parking brake victim |
Been there and done that. Not a fun job and most definitely painful on the back. I removed both front seats and control sticks. Put down some pillows and and blankets which helped a little After dissection of the valve, I found some machining chips in mine that cut into a O ring which made it leak. The valve shaft left a lot to be desired also. I polished up the rough spots on the shaft, cleaned out the valve and reassembled with a new O ring kit. No leaks since. Good luck.
Dave
Sent: Thursday, December 4, 2014 11:08:38 PM
Subject: RV10-List: Latest Parking brake victim
Quote: |
_blank" data-mce-href="http://www.aeroelectric.com">www.aeroelectric.com
" target="_blank" data-mce-href="http://www.buildersbooks.com">www.buildersbooks.com
="_blank" data-mce-href="http://www.homebuilthelp.com">www.homebuilthelp.com
="_blank" data-mce-href="http://www.mypilotstore.com">www.mypilotstore.com
ank" data-mce-href="http://www.mrrace.com">www.mrrace.com
_blank" data-mce-href="http://www.matronics.com/contribution">http://www.matronics.com/contribution
get="_blank" data-mce-href="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List
ta-mce-href="http://forums.matronics.com">http://forums.matronics.com
Posted: Fri Dec 05, 2014 4:51 am Post subject: Latest Parking brake victim |
My 12-year-old is a good wrench, and he's small for his age. Where do I ship him?
Jesse SaintI-TEC, Inc.
www.itecusa.org
www.mavericklsa.com
C: 352-427-0285
O: 352-465-4545
F: 815-377-3694
On Dec 4, 2014, at 11:23 PM, Phillip Perry <philperry9(at)gmail.com (philperry9(at)gmail.com)> wrote:
[quote]Kelly,
Phil
Quote: | Less than 24 hours after bleeding my brakes I was seeing a drip or two from the infamous Matco parking brake, even though I have only applied foot pressure to the brake pedals for less than 10 seconds total.
ot;">www.aeroelectric.com
books.com"">www.buildersbooks.com
quot;">www.homebuilthelp.com
quot;">www.mypilotstore.com
">www.mrrace.com
List"">http://www.matronics.com/Navigator?RV10-List
Kellym
Posted: Fri Dec 05, 2014 6:51 am Post subject: Latest Parking brake victim |
Thanks Jesse. I'll let you know, unless I get twisted into a pretzel and
can't get out from under the panel.
One would think that Matco would figure out by now what the issue is,
and fix it. I understand that an AN3 bolt used is really a little too
large and causes the pieces to spread apart just enough to allow
leakage. It appears that Matco has been good about fixing the units, but
the hassle of removing and reinstalling isn't improving their marketing
image.
On 12/5/2014 5:49 AM, Jesse Saint wrote:
Quote: | My 12-year-old is a good wrench, and he's small for his age. Where do
I ship him?
Jesse Saint
I-TEC, Inc.
jesse(at)itecusa.org <mailto:jesse(at)itecusa.org>
www.itecusa.org <http://www.itecusa.org>
www.mavericklsa.com <http://www.mavericklsa.com>
C: 352-427-0285
O: 352-465-4545
F: 815-377-3694
<mailto:philperry9(at)gmail.com>> wrote:
> Kelly,
> Phil
> Do Not Archive
> Sent from my iPhone
>> total.
>> old for rent?
> D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D
> ">www.mrrace.com
KCHD |
woxofswa
Posted: Fri Dec 05, 2014 10:06 am Post subject: Re: Latest Parking brake victim |
Here's a recap of my experience from a previous thread.
Getting home was a trick because I could only turn right on the ground, but figured that the home ramp was big enough to do a right 270 if I needed to go left. Thankfully, it worked out.
This morning I did one of the most physically challenging things of the entire build which was worm myself under the panel, around the stick, and prop up on a kidney (braced by a rib) with both arms intertwined into the cables and rudder pedals, (disregarding the sweat and brake fluid seeping into my eyes), to remove the lines from the devil spawned valve and join the line ends together with spare male male through wall fittings I just happened to have . Luckily with both legs extended scorpion tail style out the door opening I was able to move the one that still had bloodflow as a counterbalance to my twisted spine.
Expecting a friend coming by I get a phone call so I manage to flex my man boob enough to push my phone up high enough to pluck the phone out of my shirt pocket with my teeth and drop it on the footwell floor. The caller ID says "Van's", so I contort enough to tap answer with my elbow only to be asked by Van's Chevrolet in Scottsdale if it was a convenient time to discuss my future automotive needs.
_________________ Myron Nelson
Mesa, AZ
Flew May 10 2014 |
Kelly McMullen
Posted: Sun Dec 14, 2014 6:55 pm Post subject: Latest Parking brake victim |
After action report. I was fortunate. I did get to remove and reinstall the parking brake twice to confirm that the only leakage from the parking brake was from the fittings, not the valve body. So I did not have to contact Matco or do anything special with the valve.
By the time I am done, I will have redone every pipe fitting fitting in my brake system with aviation pipe thread sealant, and ensured all flare fittings have proper torque. 3 flare fittings required the DEL seals sold by Spruce. (well, looked like it was needed and I wasn't going to screw around with them with multiple tests, so went with belt and suspenders attack that worked).
Very few fittings had significant leaks, but because they are on interior and I don't want a future mess, I corrected any fitting with even a hint of a seep. I already had control sticks out for other work, so I could get my creaky old bones under the panel okay.
On Thu, Dec 4, 2014 at 9:08 PM, Kelly McMullen <apilot2(at)gmail.com (apilot2(at)gmail.com)> wrote:[quote]Less than 24 hours after bleeding my brakes I was seeing a drip or two from the infamous Matco parking brake, even though I have only applied foot pressure to the brake pedals for less than 10 seconds total.
KCHD |
saylor.dave(at)gmail.com Guest
Posted: Sun Dec 14, 2014 7:24 pm Post subject: Latest Parking brake victim |
I've pretty much given up on teflon paste-type thread sealants. I prefer Permatex Aviation Form-A-Gasket on threads these days.
--Dave
On Sun, Dec 14, 2014 at 6:52 PM, Kelly McMullen <apilot2(at)gmail.com (apilot2(at)gmail.com)> wrote:[quote]After action report. I was fortunate. I did get to remove and reinstall the parking brake twice to confirm that the only leakage from the parking brake was from the fittings, not the valve body. So I did not have to contact Matco or do anything special with the valve.
On Thu, Dec 4, 2014 at 9:08 PM, Kelly McMullen <apilot2(at)gmail.com (apilot2(at)gmail.com)> wrote: Quote: | Less than 24 hours after bleeding my brakes I was seeing a drip or two from the infamous Matco parking brake, even though I have only applied foot pressure to the brake pedals for less than 10 seconds total.
_blank">www.aeroelectric.com
="_blank">www.mypilotstore.com
ank">www.mrrace.com
| [b]
johngoodman
Posted: Mon Dec 15, 2014 5:23 am Post subject: Re: Latest Parking brake victim |
[quote="saylor.dave(at)gmail.com"]I've pretty much given up on teflon paste-type thread sealants. I prefer Permatex Aviation Form-A-Gasket on threads these days.
--Dave
/quote]
Dave, Permatex Aviation Form-A-Gasket Number One, or Number Three? Spruce sells both.
John
_________________ #40572 Phase One complete in 2011 |
Posted: Mon Dec 15, 2014 6:16 am Post subject: Latest Parking brake victim |
I use No. 3.
On Mon, Dec 15, 2014 at 5:23 AM, johngoodman <johngoodman(at)earthlink.net (johngoodman(at)earthlink.net)> wrote:[quote]--> RV10-List message posted by: "johngoodman" <johngoodman(at)earthlink.net (johngoodman(at)earthlink.net)>
--Dave
/quote]
John
http://forums.matronics.com/viewtopic.php?p=435735#435735
br> fts!)
r> > com" target="_blank">www.aeroelectric.com
w.buildersbooks.com" target="_blank">www.buildersbooks.com
p.com" target="_blank">www.homebuilthelp.com
e.com" target="_blank">www.mypilotstore.com
" target="_blank">www.mrrace.com
     -Matt Dralle, List Admin.
-List" target="_blank">http://www.matronics.com/Navigator?RV10-List
FORUMS -
flying-nut(at)cfl.rr.com Guest
Posted: Mon Dec 15, 2014 6:27 am Post subject: Latest Parking brake victim |
On 12/15/2014 8:23 AM, johngoodman wrote:
--Dave
/quote]
John
I really hate to see this thread rear it's ugly head over and over.
Proper use of AN fittings should (read that word again) not require
thread sealants. If you have a leak then there's something wrong and
covering up the problem with thread sealant (to me) isn't the best
course of action.
Nowhere in AC43.12-1B does the term 'thread sealant' appear. Yeah, I
know ..... "it's experimental and I can do what I want."
Almost all of the 'thread sealant' problems I've helped 'fix' are in the
brake system ..... almost all due to sealant debris in the brake master
cylinder. It appears that some folks think "If a little thread sealant
helps, then lots if thread sealant must be better."
In Kelly's email he mentions the DEL seals for flare fittings. They're
available and acceptable to 'fix' leaking flare fittings, although they
aren't in AC43.13-1B either. Properly made and maintained, flare
fittings should not leak. But they do because they were 'over flared'
(my term) or over time the nut had been tightened by a gorilla with a
wrench trying to stop a leak. I've seen thin flares on certified and
experimentals, and even seen JB weld in there as a 'fix'.
Don't misunderstand me. I used to 'fix' stuff using whatever method was
available, but having seen what happens over time I try and correct the
problem instead of covering it up. And yes, I may still go off the deep
end trying to be creative 'fixing' when I couldn't actually fix the
problem correctly.
Linn
Kellym
Posted: Mon Dec 15, 2014 6:53 am Post subject: Latest Parking brake victim |
Many of the flare fittings in the brake system have pipe threads on the
other end(at parking brake, at master cylinders.) It is the pipe threads
that benefit from the sealant, NOT the flare fittings, which as you say
should be nothing but clean and dry. Tubing flares are kind of like
bucked rivets. The first few efforts are really ugly and over time they
improve to acceptable to very nice. With the tubing that is fabricated
for the -10 you would need twice as much to get skilled and making
perfect flares. Fortunately Vans has you do the brake lines before the
fuel lines. Sure, I could remake some of the lines. Unfortunately, Vans
chose to supply the lowest grade tubing, and obviously some builders
chose to substitute higher quality tubing. However a buck or so for the
DEL seal accomplishes the same thing as remaking a tube, in a lot less
time and money. Some of my seeps were hardly noticeable without use of a
clean paper towel to catch the hint of red. I don't want to have to deal
with such seepage later, so I made a major effort to ensure each fitting
was perfectly dry after applying pressure to the system for over an hour
with the parking brake holding enough pressure to keep the calipers
locked. In actual use, such minor seepage would not have been detected
for a long time...just my choice of how to test and perfect the system.
On 12/15/2014 7:23 AM, Linn Walters wrote:
> <johngoodman(at)earthlink.net>
> --Dave
> /quote]
> Spruce sells both.
> John
course of action.
the brake system ..... almost all due to sealant debris in the brake
master cylinder. It appears that some folks think "If a little thread
sealant helps, then lots if thread sealant must be better."
they aren't in AC43.13-1B either. Properly made and maintained, flare
was available, but having seen what happens over time I try and
correct the problem instead of covering it up. And yes, I may still go
off the deep end trying to be creative 'fixing' when I couldn't
actually fix the problem correctly.
Linn
KCHD |
johngoodman
Posted: Mon Dec 15, 2014 7:01 am Post subject: Re: Latest Parking brake victim |
Quote: | Properly made and maintained, flare fittings should not leak. But they do because they were 'over flared' (my term) or over time the nut had been tightened by a gorilla with a wrench trying to stop a leak. |
The key words there are "properly made." I wonder where those fittings are actually made? My experience (very limited to one RV-10) has shown me that about 5 to 10 percent of fittings always leak. Replace them with another and the problem is solved. The hardest one to find was a female pipe thread that turned out to be out of round. I got an exact replacement from the same store, and found the same problem. Changed brands, and the problem was solved.
Never buy a car made on a Monday...
John
Posted: Mon Dec 15, 2014 7:49 am Post subject: Latest Parking brake victim |
Both kelly (pipe thread) and John (chinese? fittings) make good points.
It isn't easy to dodge all the bullets. I've been hit more than once.
It's all a learning experience.
One thing I have done is to draw a vacuum (think "mighty vac") from the
reservoir before filling with fluid. I expect to find really slow leaks
... mostly from dry seals .... but nothing major. You'll find loose
flare nuts that way. Putting 10 - 20 pounds pressure into the reservoir
after filling with fluid should show where the leaks are within an hour
or so. Left overnight though you may find puddles. BTDT.
Another thing I've learned about flaring aluminum tubing (the hard way)
is to go slow, backing off like you do with a tap, and using plenty of
lubricant. I think going slow allows the aluminum to flow rather than
crack. I use 5606 brake fluid for lubricant.
My 2 pennies, IMHO, and all the other disclaimers!!!!
Linn
Never buy a car made on a Monday... [Laughing]
John
http://forums.matronics.com/viewtopic.php?p=435739#435739
Checked by AVG - www.avg.com
Posted: Mon Dec 15, 2014 1:45 pm Post subject: Latest Parking brake victim |
Sure, never use any sealants on a b-nut. Just pipe threads. I figured that's what Kelly was describing.Â
--D
On Monday, December 15, 2014, Linn Walters <flying-nut(at)cfl.rr.com (flying-nut(at)cfl.rr.com)> wrote:
[quote]--> RV10-List message posted by: Linn Walters <flying-nut(at)cfl.rr.com>
Both kelly (pipe thread) and John (chinese? fittings) make good points. It isn't easy to dodge all the bullets. I've been hit more than once. It's all a learning experience.
One thing I have done is to draw a vacuum (think "mighty vac") from the reservoir before filling with fluid. I expect to find really slow leaks .... mostly from dry seals .... but nothing major. You'll find loose flare nuts that way. Putting 10 - 20 pounds pressure into the reservoir after filling with fluid should show where the leaks are within an hour or so. Left overnight though you may find puddles. BTDT.
Another thing I've learned about flaring aluminum tubing (the hard way) is to go slow, backing off like you do with a tap, and using plenty of lubricant. I think going slow allows the aluminum to flow rather than crack. I use 5606 brake fluid for lubricant.
Linn
Quote: | --> RV10-List message posted by: "johngoodman" <johngoodman(at)earthlink.net>
John
br> fts!)
r> > /www.aeroelectric.com" target="_blank">www.aeroelectric.com
FORUMS -
Posted: Tue Dec 16, 2014 9:03 am Post subject: Latest Parking brake victim |
On 12/15/2014 10:45 AM, Linn Walters wrote:
Quote: | Another thing I've learned about flaring aluminum tubing (the hard
Linn
I am someone who didn't have a clue as to how to make proper flares. I
got the proper tool and tried to read everything I could find - would
love to find a definitive Youtube/EAA clip showing how this is done.
Exactly what you described above - backing off 4-6 times for each flare
with plenty of lube - seems to do the trick perfectly for me. Do that,
and don't overflare, and they have been reliable and leak free for me.
Tapered pipe fittings where another story.....
Posted: Tue Dec 16, 2014 9:23 am Post subject: Latest Parking brake victim |
On 12/14/2014 10:20 PM, David Saylor wrote:
Quote: | I've pretty much given up on teflon paste-type thread sealants. I prefer Permatex Aviation Form-A-Gasket on threads these days.
--Dave
| I've used no sealant as well as several teflon past-type sealeants as well and had both brake line and oil line leaks. I've had leaks. The Form-a-Gasket sounds like a solution - wish I found out sooner.
While chasing the equivalent Loctite product, I finally found and used this - Permatex High Performance Thread Sealant #56521. This too is a solution.
They have a half dozen similar products but this works reliably and easily on high pressure tapered fittings. Little is required, it doesn't harden, it seems to cure instantly and simply doesn't leak. It works so well in comparison to the other products, I'm not sure how it does it but does.
On a non-aviation note: I recently had the need to fix several water line breaks (black poly pipe). The landscape guys fixed it with gray PVC push in fittings and a white PVC cap on a tapered fitting. They all leaked very slowly. They thought it was the push in barb fitting and kept putting extra and new hose clamps on it but I could see it was the white threaded cap on the gray threaded fitting. The cap would inevitably break before one could tighten it enough to stop the leak.
One light application of #56521 and no leaks - didn't even have to cinch it down very far. And the fittings were easily removeable with no dried up sealant pieces to get clean up and keep out of sensitive systems. I've done about 6 of these now - same results.  I found the same with a slow leaking oil cooler fitting on the '10.
rv10flyer(at)live.com Guest
Posted: Tue Dec 16, 2014 9:31 am Post subject: Latest Parking brake victim |
Brian carpenter covered a video on flared tubing under the eas videos
Flared Tubing-Fabrication & Assembly - EAA Video Player - Your ...www.eaavideo.org/video.aspx?v=[url=tel:3727487001]3727487001[/url]
Dec 2, 2008 - In this Hint, Brian Carpenter demonstrates how to fabricate and assemble flared tubing for use in many aircraft installaitons. Brian is an A&P ...
Sent from my iPad
On Dec 16, 2014, at 9:09 AM, Bill Watson <Mauledriver(at)nc.rr.com (Mauledriver(at)nc.rr.com)> wrote:
Quote: | --> RV10-List message posted by: Bill Watson <Mauledriver(at)nc.rr.com (Mauledriver(at)nc.rr.com)>
Quote: | Another thing I've learned about flaring aluminum tubing (the hard way) is to go slow, backing off like you do with a tap, and using plenty of lubricant. I think going slow allows the aluminum to flow rather than crack. I use 5606 brake fluid for lubricant.
Linn
| I am someone who didn't have a clue as to how to make proper flares. I got the proper tool and tried to read everything I could find - would love to find a definitive Youtube/EAA clip showing how this is done.
Exactly what you described above - backing off 4-6 times for each flare with plenty of lube - seems to do the trick perfectly for me. Do that, and don't overflare, and they have been reliable and leak free for me.
_-============================================================
_-=
_-= -- Please Support Your Lists This Month --
_-= (And Get Some AWESOME FREE Gifts!)
_-=
_-= November is the Annual List Fund Raiser. Click on
_-= the Contribution link below to find out more about
_-= this year's Terrific Free Incentive Gifts provided
_-= by:
_-= _-= * AeroElectric www.aeroelectric.com
_-= * The Builder's Bookstore www.buildersbooks.com
_-= * HomebuiltHELP www.homebuilthelp.com
_-= * My Pilot Store www.mypilotstore.com
_-= * Race Consulting www.mrrace.com
_-=
_-= List Contribution Web Site:
_-=
_-= --> http://www.matronics.com/contribution
_-=
_-= Thank you for your generous support!
_-=
_-= -Matt Dralle, List Admin.
_-=
_-= - The RV10-List Email Forum -
_-= Use the Matronics List Features Navigator to browse
_-= the many List utilities such as List Un/Subscription,
_-= Archive Search & Download, 7-Day Browse, Chat, FAQ,
_-= Photoshare, and much much more:
_-=
_-= --> http://www.matronics.com/Navigator?RV10-List
_-=
_-= - MATRONICS WEB FORUMS -
_-= Same great content also available via the Web Forums!
_-=
_-= --> http://forums.matronics.com
_-=
Posted: Tue Dec 16, 2014 10:03 am Post subject: Latest Parking brake victim |
Good one! That covers everything it would seem except that I can't/won't do it in one tightening. Multiple ins and outs seems to insure no cracking or whatever. Maybe just 2-3 times.
If I was paid by the hour I might work harder to get that one shot and done technique to work. Might involve the consistent use of the 45deg reamer before starting.
On 12/16/2014 12:28 PM, P Reid wrote:
[quote] Brian carpenter covered a video on flared tubing under the eas videos
Flared Tubing-Fabrication & Assembly - EAA Video Player - Your ... www.eaavideo.org/video.aspx?v=[url=tel:3727487001]3727487001[/url]
Sent from my iPad
Quote: | Another thing I've learned about flaring aluminum tubing (the hard way) is to go slow, backing off like you do with a tap, and using plenty of lubricant. Â I think going slow allows the aluminum to flow rather than crack. Â I use 5606 brake fluid for lubricant.
Linn
| I am someone who didn't have a clue as to how to make proper flares. Â I got the proper tool and tried to read everything I could find - would love to find a definitive Youtube/EAA clip showing how this is done.
| [b]
Bob Turner
Posted: Tue Dec 16, 2014 12:35 pm Post subject: Re: Latest Parking brake victim |
"Another thing I've learned about flaring aluminum tubing (the hard way)
crack."
If you look very carefully at the way the flaring tool works, you'll see that the flare is not at all round (due to the 3 lobes on the tool) as you go in. It is only when you back off (and the threads do not turn for 340 degrees) that you make the flare round. It is important to turn the tool a full turn counter clockwise before releasing the tubing from the clamping mechanism.
_________________ Bob Turner
RV-10 QB |
