N6030X(at)DaveMorris.com Guest
Posted: Thu Oct 19, 2006 10:40 am Post subject: Acceptable to use thin non aircraft wire to coil of relays |
Since it's going to be running right past your nose, what gasses does
its insulation put off if it overheats?
Dave Morris
At 12:22 PM 10/19/2006, you wrote:
We spent quite a bit of time trying to keep the panel of our Europa
Monowheel free of clutter.
There is a convenient piece of real estate between occupants in the
ceiling.
We are thinking pretty hard about making it a control panel and putting
small switches up there that would control coil of relays to run non
critical items, like position lights, strobes, landing light etc.
My partner has access to wire that is bout as thick as a model airplane
servo wire. They come in twisted pairs, from 3 pairs on up. It is probably
like the twisted wires you see inside computers, like the ones running
fans etc.
These wires would be running along side of headphone/mic wiring.
Does this sound acceptable?
Ron Parigoris
nuckollsr(at)cox.net Guest
Posted: Sat Oct 21, 2006 11:44 am Post subject: Acceptable to use thin non aircraft wire to coil of relays |
At 05:22 PM 10/19/2006 +0000, you wrote:
ceiling.
fans etc.
Depends on who you talk to. Wire, or more specifically
the INSULATION on wire has evolved tremendously since
Walter put his first generator and battery on an airplane.
There are folks who will tell you that the only acceptable
wires for replacement/new construction are modern products
embraced by the military/certified aviation communities.
You can still buy Mil-W-76 cotton weave over rubber insulated
wire used on Walter's first electrified aircraft . . . very
popular with folks restoring old cars and want them to be
original. By the same token, one could quite legally replace
a damaged or aged wire in a 1956 C-140 with Mil-W-76 wire
as well . . . it's on the original TC, most of the wires
in the airplane are 60+ years old, and a NEW piece of
Mil-W-76 wire isn't going to be a risk any greater
than the wires already in place. Further, if one wished
to restore an old airplane to original stock, the "ratty
old wires" lasted 50+ years the first time around . . .
no reason to be extra-ordinarily suspicious of them the next
time around.
Obviously, modern insulations are lighter, environmentally
tougher and easier to find. But just because it's "modern"
doesn't make it an attractive choice. It seems that some
materials thought to be an insulation-of-choice turned out to
have passed all the tests we did for wires in the past
but exhibit NEW characteristics that participate in some
spectacular insulation failures.
As a purely practical matter, wires smaller than 22AWG
are a pain in the arse for airframe wiring. We moved a lot
of wire from 22AWG to 24AWG in production and the folks
who have to work with it are less than complimentary
of "those (at)#$(at)#$!^ engineers . . ." The stuff is
just physically too-small/too-flexible/too-fragile
to work well in the hammer-n-tongs environment that is
a production line.
You don't cite the pedigree of the wire's insulation and
the sizes you describe don't sound like 22AWG (or larger).
My recommendation is that you install wires no smaller
than 22AWG (when you have a choice) and use Tefzel (Mil-W-
22759/16 or /32). This stuff is easy to find, easy to
work with and has an EXCELLENT track record in aircraft
and many other applications. I'm not suggesting that
the wire's you described are automatically a poor choice
but I will suggest that Tefzel insulated wire in 22AWG
or larger is exceedingly user friendly both for installation
and cost of ownership.
