Rivets in the 601XL elevator ribs
lwinger
PostPosted: Thu Oct 19, 2006 6:24 pm    Post subject: Rivets in the 601XL elevator ribs Reply with quote
I'm perplexed. Looking at the plans (6T3) we're told to put 9 rivets in the top skin at 40 pitch on the outboard ribs. Then we're to go to 10 rivets at 40 pitch on the other four ribs.
Two problems:
1) On the outboard ribs, this puts the last rivet beyond my elevator rib tip. Do I reduce the pitch or forget the last rivet?
2) On the other ribs, 10 rivets at 40 pitch extends out to 360mm on a skin that is only 345mm wide. Either I need to adjust my pitch to something less than 40mm, or stop at 8 to catch material on my ribs.
Help.
Larry Winger
Tustin, CA
601XL
Stabilizer complete/Working on the elevator
Larry Winger
Tustin, CA
Plans building 601XL/650 with Corvair
Installing fuel system
www.mykitlog.com/lwinger
Ron Lendon
PostPosted: Thu Oct 19, 2006 7:09 pm    Post subject: Re: Rivets in the 601XL elevator ribs Reply with quote
Larry,
I ran in to the same problem and solved it by knowing 40 pitch is the maximum pitch, you can always go for less pitch. Some of my 40 pitch are actually 35mm.
What I did is marked the end rivets at the correct edge distance then set the fan to fill the void with the correct number of rivets. If it came out at 35mm, so be it.
Here is a picture of my rivet fan. I wrote numbers on it so I don't have to count, hows that for lazy8)
Have fun,
Number your rivet fan
 Filesize:  664.61 KB
 Viewed:  446 Time(s)
Ron Lendon
CH 601 XLB
N601LT - Flying
Corvair Engine Prints:
ter_turn(at)yahoo.com
PostPosted: Thu Oct 19, 2006 7:15 pm    Post subject: Rivets in the 601XL elevator ribs Reply with quote
Larry, my plans, 06/03, call for nine rivets across the top each rib, A4 Pitch 40 and eight rivets each rib on bottom skin.
Terry Turnquist
601 XL Plans
St. Peters, MO
Larry Winger <larrywinger(at)gmail.com> wrote:
[quote] I'm perplexed. Looking at the plans (6T3) we're told to put 9 rivets in the top skin at 40 pitch on the outboard ribs. Then we're to go to 10 rivets at 40 pitch on the other four ribs.
Two problems:
2) On the other ribs, 10 rivets at 40 pitch extends out to 360mm on a skin that is only 345mm wide. Either I need [quote][b]
lwinger
PostPosted: Thu Oct 19, 2006 7:56 pm    Post subject: Rivets in the 601XL elevator ribs Reply with quote
Ron,
That sounds like a workable solution. Unless I hear from anyone else on the list who has a convincing argument to the contrary, that will be my plan.
Larry
On 10/19/06, Ron Lendon <rlendon(at)comcast.net (rlendon(at)comcast.net)> wrote: [quote]--> Zenith-List message posted by: "Ron Lendon" <rlendon(at)comcast.net (rlendon(at)comcast.net)>
Larry,
Have fun,
Ron Lendon, Clinton Township, MI
Corvair Zodiac XL, ScrapBuilder Wink
Read this topic online here: [quote][b]
Larry Winger
Tustin, CA
gboothe(at)calply.com
PostPosted: Fri Oct 20, 2006 1:35 am    Post subject: Rivets in the 601XL elevator ribs Reply with quote
Larry,
Ron’s explanation is exactly right.
Gary Boothe
Cool, CA
601 HDSTD, WW Conversion 90% done,
Tail done, wings done, working on c-section
From: owner-zenith-list-server(at)matronics.com [mailto:owner-zenith-list-server(at)matronics.com] On Behalf Of Larry Winger
Sent: Thursday, October 19, 2006 8:56 PM
Subject: Re: Re: Rivets in the 601XL elevator ribs
Ron,
Larry
Larry,
Have fun,
601zv(at)ritternet.com
PostPosted: Fri Oct 20, 2006 3:06 am    Post subject: Rivets in the 601XL elevator ribs Reply with quote
Me too. My plans with 6-T-3 dated 06/03 show 9 rivets in all ribs, and mine,
equally spaced are at about pitch 36. Actual pitch may vary slightly
depending how close you start to the trailing edge. You will find similar
pitch situations occurring througout the rest of the airframe and I have
always considered the stated pitch to be nominal maximum and just equally
space the rivets. You will notice that the designated pitch is always stated
in even numbers, i.e. 40, but in reality rarely works out even.
Gig Giacona
PostPosted: Fri Oct 20, 2006 5:37 am    Post subject: Re: Rivets in the 601XL elevator ribs Reply with quote
Get you one of these.
http://gallery.bcentral.com/GID4351283P5125292-Gauges-Measuring-Inspection/RIVET-FAN-SPACING-TOOL-Made-in-USA.aspx
The rivet spacing fan makes life so much easier. There are many many places that the 40 is the minimum and you will need to come up with a smaller spacing.
For the record I bought mine from ACS but the above link was the first with a picture that came up when I Googled 'Rivet spacing fan'
W.R. "Gig" Giacona
601XL Under Construction
barcusc(at)comcast.net
PostPosted: Fri Oct 20, 2006 7:36 am    Post subject: Rivets in the 601XL elevator ribs Reply with quote
Cheap Rivet Spacer: Buy an aluminum yardstick (About $3.00) use a Stanley
knife and square to scribe lines every 40mm, also scribe a 20mm line in the
first section. The aluminum yardstick bends easily to conform to wings or
works great on flat surfaces as well. If plans call for 20mm spacing scribe
40mm first, then move the yardstick to match the 20mm scribe to a 40mm you
just made and mark the 40mm lines again. Cheap, easy and accurate.
Clyde
601XL
lwinger
PostPosted: Fri Oct 20, 2006 7:55 am    Post subject: Rivets in the 601XL elevator ribs Reply with quote
Thanks to everyone for good insight into this issue which obviously crops up with regularity through the entire build. You guys are a great help.
Larry Winger
Tustin, CA
601XL
Elevator drilled & clecoed
On 10/20/06, Robin Bellach <601zv(at)ritternet.com (601zv(at)ritternet.com)> wrote: [quote]--> Zenith-List message posted by: "Robin Bellach" <601zv(at)ritternet.com (601zv(at)ritternet.com)>
Larry Winger
Tustin, CA
