bbradburry(at)allvantage. Guest
Posted: Thu Oct 19, 2006 7:46 am Post subject: Powering fuel injectors |
I am using Z-19 as a guide for wiring my plane. The primary and
secondary fuel injectors are not powered through the ECU, just
controlled by it. I would like to power the injectors from the battery
buss.
Looking at Z-19, do I need to install a complete switch and diode system
for the injectors like is done for the fuel pump and ECU, or can I tie
on to the fuel pump OR the ECU system after either the switch (add a
separate diode) or after one of the diodes? There will be two DPDT
switches to disable the primary and secondary injectors after this
connection.
My panel is becoming somewhat switch festooned and I would like to keep
more switches to a minimum.
Bill B
