ron.mcgann(at)baesystems. Guest
Posted: Wed Oct 18, 2006 4:07 pm Post subject: Vne and flutter (was engines) |
Assumptions:
Vne is based on IAS, and for the -10 is 200kts (at) 5000'.
Vne is adjusted by 1.5% for each 1000ft of alt.
At 20000ft, Vne is therefore 15(000)*1.5% less than 200kts (ie 155kts Indicated)
Check out the attached photo from a turbocharged -10 operating here in Oz. Yes that is 152 kts at 20120' (Note the TAS in the bottom left corner and yes, they are knots!)
If published Vne is 200kts at sea level, Vne (at) 20000' is close to 140kts (70% of 200kts)
If published Vne is 200kts at 8000', Vne (at) 20000' is close to 164kts (82% of 200kts)
Fast - yes, but a bit too close to the edge for this little black duck! I would be interested if anyone knows what the designed Vne (and associated altitude) actually is.
FLY SAFE
Ron
187 finishing.
[quote] --
43.67 KB |
262 Time(s) |
Dsyvert(at)AOL.COM Guest
Posted: Wed Oct 18, 2006 5:50 pm Post subject: Vne and flutter (was engines) |
Ron,
I believe the following link will answer your question.
http://www.vansaircraft.com/pdf/hp_limts.pdf
Dave Syvertson
jesse(at)itecusa.org Guest
Posted: Thu Oct 19, 2006 4:48 am Post subject: Vne and flutter (was engines) |
I can’t find the fuel burn number on that screen. Any help?
Jesse Saint
I-TEC, Inc.
www.itecusa.org
W: 352-465-4545
C: 352-427-0285
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of McGANN, Ron
Sent: Wednesday, October 18, 2006 8:07 PM
Subject: Vne and flutter (was engines)
Assumptions:
FLY SAFE
Ron
187 finishing.
-----Original Message-----
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com]On Behalf Of James K Hovis
Sent: Thursday, 19 October 2006 2:13 AM
Subject: Re: Re: engines
Flutter and dynamic divergence are REAL issues every airframe designer (and for that matter, pilot) has to deal with especially so for higher-performance aircraft. There are two ways to set Vne in FAR Part 23. One, do ground vibration tests to find resonant frequencies (mainly shake the crap out of it and see if anything falls off) of the airframe, then go out and flight test to find its flutter point, then set the Vne at few per cent below this speed. The other is to use the canned Vne minimum speed formula based on wing loading. The canned formula is based on statistics from certified aircraft that if you set Vne at this speed or below, you won't encounter flutter. I suspect Van's took the conservative approach and set Vne based on the canned formula. Now as Van points out, weight affects flutter. Balance of control surfaces affect flutter (see Steve Whitman's crash several years ago), and horsepower available affects flutter. Most low-power spam-cans don't have the power to ever approach Vne except in steep dives, while adding power means the top speed capable (that point where the power available curve crosses the power required for level flight curve) creeps ever closer to the flutter point. Now, don't get me wrong, if someone want to drop in a 300hp engine into an RV, they are more than welcome to do it. However, they should get a professional test pilot to verify the Vne and flutter point for the configuration or get training on how to react when flutter happens (the time from flutter onset to complete divergence can be REAL small). Understanding the full ramifications of modifications to the original design and testing for it may save someone's life in the end.
JKH
10/17/2006
10/19/2006
bsponcil(at)belinblank.or Guest
Posted: Thu Oct 19, 2006 6:09 am Post subject: Vne and flutter (was engines) |
I was at the Cherokee Pilots Assoc fly-in a few years back and talked to Karl Bergey, one of the lead engineers at Piper during the late 60s early 70s. Anyway, I asked why the Vne was different between the Archer and Warrior because as far as I knew there wasn't any difference between the airframes. Expecting to hear "Well we beefed up this or that, extended the HS by 1 inch, etc" I was surprised instead to hear that Vne was calculated (at least at Piper) solely by the dive test during certification. Whatever the testpilot felt comfortable taking the plane up to in the dive, subtract 20% and you had Vne. The only reason the Warrior and Archer have different Vne is because the testpilot flying the Archer went faster in the dive.
I wouldn't be surprised if this is how Vans calculates theirs as well.
-Brian
#40497
Iowa City, IA
[quote] [quote] --
glastar(at)gmx.net Guest
Posted: Thu Oct 19, 2006 8:40 am Post subject: Vne and flutter (was engines) |
Hello Brian,
I don't think Van's does it this way, they most probably go along with FAR 23.1505 and calculate this speeds, similar to certified airplanes (at least how it is certified today). It's a function of several parameters so you get your flight envelope (see FAR 23.333) and have your limitations set FAR (23.335). Even kit planes are made today with some since background.
br Werner
Brian Douglas wrote: [quote]
-Brian
#40497
Iowa City, IA
[quote] [quote] --
LessDragProd(at)AOL.COM Guest
Posted: Thu Oct 19, 2006 8:48 am Post subject: Vne and flutter (was engines) |
For each RV-3, a flutter test to 10% above Vne was recommended by Van's aircraft. I read a little bit about this before my flight test.
In an attempt to simplify from what I have read:
The Vne is an airspeed based on analysis and design.
This is an indicated airspeed (IAS), or Part 23 calls this an equivalent airspeed (EAS). The EAS being an IAS that uses a calibrated instrument with a corrected pitot/static system.
Flutter speed will vary from one aircraft to another of the same design. Although it is easy to identify when you've reached flutter speed, because major components SUDDENLY separate from the rest of the aircraft.
The flutter speed is a true airspeed (TAS).
Flutter speed is a variable number, because the actual construction and alignment of the aircraft WILL change this number. Especially sensitive are the hinged weight and balance of the flight controls.
Given that Vne is less than the flutter speed at sea level;
IF the IAS of Vne can be maintained with altitude, at some altitude Vne WILL exceed the flutter speed. (This is a bad thing.)
Reading between the lines, here is what I am hearing Van's Aircraft say:
With the Lyc. 540 engine of 260 horsepower, in level flight the IAS will not exceed the flutter speed of the aircraft. (Most flight time will be below 12,500'. Very seldom will a flight occur near 18,000'.)
With a turbo normalized Lyc. 540 engine (or an engine with more than 260 horsepower) in level flight at some higher altitude, the IAS could exceed the flutter speed. And will exceed the flutter speed, if the IAS is allowed to increase at the start of a descent from a high enough cruise altitude.
(Flutter is a high frequency thing, which we humans don't feel very well. Major component separation is a low frequency occurrence, which we would feel. )
Jim Ayers
RV-3 sn 50
In a message dated 10/19/2006 7:11:44 AM Pacific Daylight Time, bsponcil(at)belinblank.org writes:
| Quote: | I was at the Cherokee Pilots Assoc fly-in a few years back and talked to Karl Bergey, one of the lead engineers at Piper during the late 60s early 70s. Anyway, I asked why the Vne was different between the Archer and Warrior because as far as I knew there wasn't any difference between the airframes. Expecting to hear "Well we beefed up this or that, extended the HS by 1 inch, etc" I was surprised instead to hear that Vne was calculated (at least at Piper) solely by the dive test during certification. Whatever the testpilot felt comfortable taking the plane up to in the dive, subtract 20% and you had Vne. The only reason the Warrior and Archer have different Vne is because the testpilot flying the Archer went faster in the dive.
-Brian
#40497
Iowa City, IA
ivowel(at)gmail.com Guest
Posted: Fri Oct 20, 2006 5:39 am Post subject: Vne and flutter (was engines) |
I am not an expert, but Vans seems to be very conservative when it comes
to such issues as specifications, Vne, etc. It would not surprise me if
there is some wiggle room. Alas, I would feel more comfortable with a
ballistic parachute if I were to try to exceed Vne on a semi-regular
basis. An airplane, even an RV-10, is replaceable---you are not.
I have a 325hp engine of in my aircraft, which is really only the 260hp
engine fine-tuned a little bit better. I have not flown the 260hp
engine, but from what I have observed in flight, the difference in
performance seems to be very small. A turbo at high altitude, however,
might make a real difference. of course, you then need oxygen, too. It
becomes a much more complex (and potentially pilot-exhausting)
exercise. with a parachute, this could be a nice thing to do, so.
PS: n325hp is still for sale, now at the reduced price of $209,000.
regards,
/iaw
