n100rh(at)sbcglobal.net Guest
Posted: Mon Oct 16, 2006 6:02 pm Post subject: coolant issues? |
Has anyone hear of issues with the new coolant being used in Rotax 914s?
This is part of a message I received from a fellow Europa pilot.
"...I just heard today that the new waterless fluid is flammable. I saw
it burn today/ Stemme has issued an urgent SB to remove the stuff - I
heard 2 fatalities of coolant leak catching fire. The 50 - 50 solution
will not burn. Oh well! Have you heard anything about this? I also
discovered that the 100% solution of antifreeze burns too..."
Posted: Tue Oct 17, 2006 12:25 am Post subject: coolant issues? |
Ralph,
| Quote: | "...I just heard today that the new waterless fluid is flammable. I
saw it burn today/ Stemme has issued an urgent SB to remove the stuff
- I heard 2 fatalities of coolant leak catching fire. The 50 - 50
solution will not burn. Oh well! Have you heard anything about this? I
also discovered that the 100% solution of antifreeze burns too..."
Yes glycols are flammable. Remember those WWII air combat stories ?
The NPG+ consists of a blend of different glycols (propylene glycol
seems to be the main component, as in the regular NPG coolant).
Propylene glycol (1,2 propanediol) has a 107°C flash point.
Please see SDS here http://www.sargentwelch.com/pdf/msds/sch94661.pdf
In my opinion, the main hazard is with mists and fumes. A pinpoint leak
may well produce some heavier-than-air flammable mist under the cowling.
Do you have additional info on this Stemme SB ?
Nowadays, very few people in Civil Aviation Authorities, if any, have a
clear understanding of what is involved in internal combustion engine
cooling...
From a pure technical point of view, there is little to be gained by
using those water-free coolants.
Gilles Thesee
Grenoble, France
http://contrails.free.fr
Posted: Tue Oct 17, 2006 2:36 am Post subject: coolant issues? |
saw it burn today/ Stemme has issued an urgent SB to remove the stuff -
Found the SB :
http://www.stemme.de/daten/d/service/a3110076_01a_easa_ad.pdf
FWIW,
Gilles Thesee
Grenoble, France
Brian Davies
Posted: Tue Oct 17, 2006 5:20 am Post subject: coolant issues? |
I am surprised they were not aware it was flamable. So is pure glycol. As
long as you don’t let it beyond the firewall it is surely no different to
the oil (flamable) and the fuel (very flamable).
Brian
Posted: Tue Oct 17, 2006 5:29 am Post subject: coolant issues? |
Brian Davies a écrit :
Having a fire in flight, even on the "right" side of the firewall, would
be a real concern for me
Seriously, Rotax are just protecting themselves against lawsuits with
these Evans SBs.
There is technically no point in using the NPG+, so why bother ?
Best regards,
Gilles
ami(at)mcfadyean.freeserv Guest
Posted: Tue Oct 17, 2006 11:44 am Post subject: coolant issues? |
Or that the 912 was originally designed and approved to run on 100% Ethylene
Glycol!!
Duncan McF
Posted: Tue Oct 17, 2006 11:59 am Post subject: coolant issues? |
Duncan,
Ethylene Glycol!!
The 912 designed for 100% Glycol ? Ducan, can you give further details ?
Gilles
Posted: Wed Oct 18, 2006 12:34 pm Post subject: coolant issues? |
According to recent publication by the UK Rotax agent.
But it didn't work well (jellied coolant, internal deposits) so got watered
down.
Duncan McF
Posted: Wed Oct 18, 2006 9:06 pm Post subject: coolant issues? |
Gilles,
Thanks for all the info, as usual you are a great resource. I'm still
over a year from completing the Europa, but I won't forget this one.
Ralph
XS motorglider
Reno,NV
Gilles Thesee wrote:
<Gilles.Thesee(at)ac-grenoble.fr>
Ralph,
> I also discovered that the 100% solution of antifreeze burns too..."
leak may well produce some heavier-than-air flammable mist under the
cowling.
a clear understanding of what is involved in internal combustion
engine cooling...
Gilles Thesee
Grenoble, France
Posted: Thu Oct 19, 2006 10:07 am Post subject: coolant issues? |
Ralph,
Thank you for your message.
You're welcome.
Best of luck with your project,
Gilles
