kheindl(at)msn.com Guest
Posted: Wed Oct 18, 2006 7:21 am Post subject: IMPORTANT! - Release of MANDATORY Rotax ALERT SERVICE BULLET |
DOES ANYONE KNOW WHAT IS INVOLVED HERE ?
| Quote: | From: "updates(at)rotax-owner.com" <updates(at)rotax-owner.com>
Reply-To: updates(at)rotax-owner.com
To: kheindl(at)msn.com
Subject: IMPORTANT! - Release of MANDATORY Rotax ALERT SERVICE BULLETIN For
912 & 914 Engines
Date: Tue, 17 Oct 2006 18:42:50 -0700
Dear Registered User;
The following MANDATORY ALERT SERVICE BULLETINS have been released by
Rotax:
ASB-912-051,
ASB-914-034,
ASB-912-051UL,
ASB-914-034UL
CHECKING OF MAGNETIC PLUG ON ROTAX ENGINE TYPE 912/914 (SERIES)
These new Alert Service Bulletins may be downloaded from
www.rotax-owner.com
ASB-912-051 -
http://www.rotax-owner.com/si_tb_info/getdoc.asp?USERID=kheindl&DOCID=ASB-912-051&S_TYPE=NW
ASB-914-034 -
http://www.rotax-owner.com/si_tb_info/getdoc.asp?USERID=kheindl&DOCID=ASB-914-034&S_TYPE=NW
ASB-912-051UL -
http://www.rotax-owner.com/si_tb_info/getdoc.asp?USERID=kheindl&DOCID=ASB-912-051UL&S_TYPE=NW
ASB-914-034UL -
http://www.rotax-owner.com/si_tb_info/getdoc.asp?USERID=kheindl&DOCID=ASB-914-034UL&S_TYPE=NW
** Important Note!
Rotax releases separate Service Bulletins for non-certified engine models.
These service bulletins only contain information regarding the
non-certified engine models affected by the service bulletin.
Full service bulletin information and instructions are found in the
certified service bulletin (without the UL designator).
Owners and operators of non-certified engine models must download and
review both the certified and UL versions of the service bulletin to obtain
complete service information. This e-mail update is provided as a free
service to registered users.
SERVICE BULLETIN SUMMARY:
THIS SUMMARY IS GENERAL IN NATURE AND ARE NOT INTENDED TO REPLACE THE
INFORMATION PROVIDED IN THE SERVICE BULLETINS.
ALL OWNERS, OPERATORS AND MAINTENANCE PERSONNEL SHOULD OBTAIN AND CAREFULLY
REVIEW THE FULL TEXT OF EACH SERVICE BULLETIN.
In a limited number of cases, certain conditions may lead to increased wear
on the camshaft and/or hydraulic lifters. Examination of the amount and
consistency of the residue captured on the engine magnetic plug can help to
determine if increased camshaft / hydraulic lifter wear is occurring.
Owners and operators of all affected engines must have the engine magnetic
plug inspected as per the schedules set out in the Alert Service Bulletins.
IMPORTANT NOTE!
Section 1.1 of the Alert Service Bulletins (Engines Affected), sets out
certain serial number ranges where compliance with Section 1.5a (inspection
of magnetic plug prior to engine installation or first engine start up) has
already been accomplished prior to engine delivery. Please note that these
engines must still comply with all of the remaining items found in Section
1.5 – Compliance including a one time inspection of magnetic plug within
the next 5 hours of operation and inspection of the magnetic plug at each
engine oil change thereafter.
If owners or operators have any questions regarding the engine serial
numbers affected by this Alert Service Bulletin or the specific compliance
steps required for any particular engine serial number, they should contact
their nearest authorized distributor or service center as soon as possible.
SERVICE NOTE - REMOVAL OF MAGNETIC PLUG!
Field experience has indicated that extra care must be used when removing
the magnetic plug. To prevent damage to the magnetic plug, removal of the
magnetic plug should only be attempted using a high quality (i.e. Snap-On
brand) TORX 40 driver. DO NOT ATTEMPT TO REMOVE MAGNETIC PLUG WITH AN
ALLEN WRENCH ON AFFECTED ENGINES!
For additional instructions or assistance with magnetic plug removal,
please contact your nearest Authorized Service Center.
This e-mail update is provided as a free service to registered users.
Register with Rotax Owners Association News today!
If you no longer wish to receive automatic service document notifications
through this account, please follow the following link:
http://www.rotax-owner.com/si_tb_info/listremove.asp?action=confirm&id=kheindl
Be the first to hear what's new at MSN - sign up to our free newsletters!
http://www.msn.co.uk/newsletters
riddon(at)sent.com Guest
Posted: Wed Oct 18, 2006 11:20 am Post subject: IMPORTANT! - Release of MANDATORY Rotax ALERT SERVICE BULLET |
Karl.
My understanding is:-
1). Click on the relevant bulletin below or cut and paste the URL into
internet explorer, ASB-912-051 or ASB-914-034 (the UL are for
ultralights), This will load the full bulletin from Rotax provided you
are on line.
2). Check if the bulletin is relevant for your engine. (my engine number
is before that listed in the 912 section). If your engine is not one
listed then ignore the bulletin. If it is, then
3). Unscrew the magnetic plug with a torx 40 driver and check for
particles. If there are a lot of bits stuck to the plug, as in the
picture, then the engine has to be checked before being used again.
I personally check the plug at every oil change and have found virtually
no particles.
Hope this helps.
Richard Iddon G-RIXS
