sadly a kitfox is down
eskflyer(at)lvcisp.com
PostPosted: Sun Oct 15, 2006 6:25 am    Post subject: sadly a kitfox is down Reply with quote
Just read on the ntsb that a kitfox 4 1200 went down on friday N134U two peope were on board and did not make it .
pilot was having fuel problems it says
http://www.ntsb.gov/ntsb/brief.asp?ev_id=20061013X01518&key=1
John Perry
Michel
PostPosted: Sun Oct 15, 2006 8:26 am    Post subject: sadly a kitfox is down Reply with quote
Yes, I learnt about the fatal accident Thursday , as I have "Kitfox" as
a keyword in Google Alert. But your new link seem to shed more light on
the accident, John. I looks like the two pilots did what we should
avoid; try to save the plane by turning back to the runway, and stalled
in the turn, entering a spin.
May this be a lesson to all of us, once an emergency arises, our
beloved planes are merely an expendable cushion between us and mother
earth. I don't know how I would react if this happened to me but, from
all I read, I believe the best way to safe my, and my eventual
passenger's life, is to land almost anywhere but straight ahead.
When I was in Germany, one month ago, for the PocketFMS fly-in, we
assisted a safety conference held by a German aviation safety officer.
In one example, he took a real airfield and demonstrated what were the
alternatives in the event of an engine stop under initial climb. His
opinion was that, for our small aircraft, it was even better to land on
tree tops, than making the possibly fatal 180 turn.
Our thoughts are, of course, with the family of the victims. May God
bless them and relief their pain.
Michel
Kitfox 3 - Jabiru 2200
lcfitt(at)sbcglobal.net
PostPosted: Sun Oct 15, 2006 9:55 am    Post subject: sadly a kitfox is down Reply with quote
John,
Thanks for the report. This is indeed bad news. If the pilot was the
registered owner, then it is someone I have met as he attended the Cameron
Park Kitfox fly-in. I have been unable to find any local news reports of
the accident.
Attached is a photo of the airplane (N134U) taken by John McBean at the
Second fly-in.
Lowell
 Filesize:  104.28 KB
 Viewed:  453 Time(s)
Lynn Matteson
PostPosted: Sun Oct 15, 2006 3:35 pm    Post subject: sadly a kitfox is down Reply with quote
Michel-
I thought the straight-ahead landing was the preferred method, as
opposed to trying to get back to the field...did you misspeak yourself?
Lynn
as a keyword in Google Alert. But your new link seem to shed more
light on the accident, John. I looks like the two pilots did what we
should avoid; try to save the plane by turning back to the runway, and
stalled in the turn, entering a spin.
on tree tops, than making the possibly fatal 180 turn.
Michel
Lynn
Kitfox IV-Jabiru 2200
N369LM
Aerobatics(at)aol.com
PostPosted: Sun Oct 15, 2006 4:23 pm    Post subject: sadly a kitfox is down Reply with quote
Well said. I dont have the nerve to pull to Idle at 300 feet after take off, but I always think of the altitude that I am confident I could at every takeoff.
I think 400 feet would possible if a clear approach, if not I want 500 feet or I am going straight ahead. Period.
I have done quite a few dead stick landings. Engine off, on purpose. The one thing I learned about the KF2, it glides quite well and I needed a bit higher approach speed than I first thought. I glide at 55 to 60, short final 50 fence 45 at least or flair is tough. ALWAYS aim quite a bit down the runway and slip to your spot. Personally, the KF2 is a great side slipping aircraft. Normal accent is 350/400 feet pm in side slip can be well over 1,500.
My ASI seems fairly accurate, but doesn't really matter, it is what indicates on my plane that works for me. I tried a few a bit slower and over the fence at 40 and it not would properly flair.
My CG is on the forward range, I believe it was 28% empty. Also what helped a LOT was closing the gap on the elevator and rudder. Difference was huge. Now if I could close the gap on the ailerons LOL
In any case, knowing your plane is a great idea, fun to do and hopefully makes us safer
Dave
KF582
Float Flyr
PostPosted: Sun Oct 15, 2006 5:48 pm    Post subject: sadly a kitfox is down Reply with quote
I did it from about 250' on floats one day. Just dropped the nose real fast and made a good landing. The term chopped the power really doesn't apply to what I did though, it was more like a normal withdrawal of power. No way was I going to flirt with a stall at that altitude. Turns were out of the question! Airspeed didn't drop below 60mph until just before touchdown.
500' is one of the altitudes I was trained to make a 180 turn into the final flare. That's Ok when the landing spot is directly below you and you have decent flying speed to begin with.
Noel [quote]
Noel Loveys
Kitfox III-A
Aerocet 1100 Floats
janderson412(at)hotmail.c
PostPosted: Sun Oct 15, 2006 6:07 pm    Post subject: sadly a kitfox is down Reply with quote
The way to try this is do it at 3000', I set up in a steep climb at 60kts
high power to simulate t/off. Then snapped the throttle and held the nose up
for a second or two to simulate human responce delay to test the effect. The
nose dropped and the a/c just squashed and as soon as I lowered the nose the
speed built. John A.
Subject: RE: sadly a kitfox is down
Date: Sun, 15 Oct 2006 23:17:06 -0230
Noel
wingsdown(at)comcast.net
PostPosted: Sun Oct 15, 2006 7:07 pm    Post subject: sadly a kitfox is down Reply with quote
For those with a free wheeling prop, add about 400 too 500 FPM extra
sink to your normal for the added drag. It was a real surprise trust me
on that one. Truly sorry for the loss of life and those they left
behind. May we all learn quickly from the ultimate lessons given from
others. I did not know the men, but they will be missed just the same.
Rick
Michel
PostPosted: Mon Oct 16, 2006 3:38 am    Post subject: sadly a kitfox is down Reply with quote
Hello Lynn,
If you understood it that way, then I surely misspoke myself, because the straight-ahead method is what is recommended by everyone.
Second: Congratulations on your Sport Pilot license. A new life opens itself for you.
Third, I also have a Macintosh and I don't remember Frappr displaying wrongly. I'll check that again this evening. (I am on a PC at work but shttt! don't tell anyone! Smile
Michel
Lynn Matteson
PostPosted: Mon Oct 16, 2006 4:01 am    Post subject: sadly a kitfox is down Reply with quote
Thanks for the congrats, Michel. I've already worn out some sectional
charts looking for places to go. : )
Here is the quote that I read from you yesterday (Sunday), and copied
and pasted here:
"I don't know how I would react if this happened to me but, from all
I read, I believe the best way to safe my, and my eventual passenger's
life, is to land almost anywhere but straight ahead."
When I read this, I was sitting here at the computer and a large
"question mark" suddenly appeared above my head. : )
Lynn
Kitfox IV Speedster...Jabiru 2200
On Monday, October 16, 2006, at 07:37 AM, Michel Verheughe wrote:
Hello Lynn,
> From: Lynn Matteson [lynnmatt(at)jps.net]
> yourself?
itself for you.
Michel
Lynn
N369LM
PostPosted: Mon Oct 16, 2006 6:28 am    Post subject: sadly a kitfox is down Reply with quote
One thing I have found for sure is that if the fuel flow is compromised
between the header tank and the carburetors, you will have just enough fuel
in the carb bowls to get you to about the death altitude before the engine
stops or loses significant power. This is important to know. How do I
know?
After the last series of posts on the fatal stall spin accident in the South
East. I was tracing an incipient fuel smell and found a cracked fuel line
at one of the carburetors. It had been cut by the banjo bolt on the right
carb due to too sharp a turn in the line. I changed out all the engine pump
to carb fuel lines and put in new fire shield. I had one of those neat
firesheild clamp tighteners and proceeded to clamp the ends per the book,
RTV and all. I then went up for a test around the pattern and all was in
order.
The next morning I went up for a flight and just about 200 ft, the engine
started running extremely rough. The first thing I did is punch on the aux
fuel pump and reduce power. My first impression was that fuel starvation
was the problem. I felt I was too low for my alternate - straight ahead -
emergency landing point - it is a field a bit to the right of straight
ahead,but is across some commercial buildings and trees.
To make this short, the engine never quit and it was not like I was heading
down at best glide, so I initiated the dreaded 180 and came out over the
runway high enough that a steep side slip was necessary to get down. I made
a note in my trip record sheet and my hand writing betrays the adrenaline
rush I was fighting. The engine ran fine all the way back to the hangar.
I announced to my wife that I would not fly until I found something that I
could definitely attribute to the problem. Everything checked out until I
removed the new fuel lines and sighted down the bore. Apparently the fire
sleeve had relaxed during the night putting pressure on the fuel line,
essentially crimping them nearly closed.
The point of all this is that you can do everything right, taxi,
predeparture checks, run up, and even if fuel flow is compromised, all that
will seem fine. Taxi to the take off point and go and if the fuel demands
exceed the fuel flow, the carb bowls will be sucked dry and the bad things
will start happening just at the point of greatest danger.
Since that time, I am hearing lots of little noises from my engine, I have
never "heard" before and am a bit tense during that transition point from
take off to comfort altitude.
Lowell
dave
PostPosted: Mon Oct 16, 2006 7:12 am    Post subject: sadly a kitfox is down Reply with quote
Lowell, some good points there and one thing I do when diagnosing a fuel
problem before flying it again and everything seems to check out ok out, is
tie it down and WOT for 3 mins on the ground. If you have a fuel delivery
issue it is more than likely to fail/starve or burp at this testing.
Dave
Hundreds of Kitfox Movies
Most viewed Kitfox on youtube
Most popular on youtube
Highest rated on youtube
Float Flyr
PostPosted: Mon Oct 16, 2006 4:52 pm    Post subject: sadly a kitfox is down Reply with quote
There is one take off direction on the pond I use to launch. When the wind
is due west I have to go over a hill that is about 300' high and then about
a mile to the next usable pond for landing. I hate taking off in that
direction because it cuts my options. Easterly wind would be worse for
hills and boreal forest but usually an easterly wind here also brings half
the North Atlantic raining down.
Noel
[quote] --
Noel Loveys
Kitfox III-A
Aerocet 1100 Floats
