echristley(at)nc.rr.com Guest
Posted: Thu Oct 12, 2006 8:06 am Post subject: Anti-rotation washer |
What is a good source for tabbed anti-rotation washers? None of the
toggle switches I bought had them.
,|"|"|, Ernest Christley |
----===<{{(oQo)}}>===---- Dyke Delta Builder |
o| d |o http://ernest.isa-geek.org |
mprather(at)spro.net Guest
Posted: Thu Oct 12, 2006 10:31 am Post subject: Anti-rotation washer |
B and C sells them.. Go here:
http://www.bandc.biz/parts.html
And enter "washer" into the search window. The first hit is the one I
think you need.. Not sure if the diameter of the switches are all the
same, however.
Matt-
<echristley(at)nc.rr.com>
Neal.George(at)hurlburt.a Guest
Posted: Thu Oct 12, 2006 10:52 am Post subject: Anti-rotation washer |
Ernest -
I have bought those washers from both SteinAir and B&C.
neal
What is a good source for tabbed anti-rotation washers? None of the toggle
Posted: Fri Oct 13, 2006 5:06 am Post subject: Anti-rotation washer |
Matt Prather wrote:
same, however.
Matt-
Thank you, Matt. I had looked on B&C's sight before, but couldn't find
the washers listed seperately.
VE3LVO(at)rac.ca Guest
Posted: Sat Oct 14, 2006 7:52 am Post subject: anti-rotation washer |
Beats the devil outta me, Sarge.
(a) The search button is `way at the bottom, after scanning a bunch of lines
(b) When poked, filled with WASHERS, it revealed 17 items, most of which
had no washers except if one is to read each one in order and search by
eyeball for an applicable WASHER,
(c) Thass when I gave up.
Fetch me the dictionary.
Ferg Kyle
Europa A064 914 Classic
nuckollsr(at)cox.net Guest
Posted: Sat Oct 14, 2006 10:53 am Post subject: anti-rotation washer |
At 11:50 AM 10/14/2006 -0400, you wrote:
Ferg Kyle
I presume you're looking for keyway washers for the
standard toggle switch. B&C has them listed in their
"all parts" order form at:
http://www.bandc.biz/cgi-bin/ez-order/order?X358218
Do a an EDIT_Find-in-this-Page search for S700KW
and it will jump to the line item where you can enter
a quantity in their shopping cart utility.
This is a good page to access for B&C. I believe it's a
single url that lists every line item available for sale
irrespective of where it appears in the catalog pages.
