avidsid(at)yahoo.com Guest
Posted: Thu Oct 12, 2006 8:02 am Post subject: tube/fabric aircraft over all aluminum |
And that is the whole point condensed to that message.........he should consider several designs, find a couple that he likes the best, then consider those in a medium, or construction technique, that he is comfortable or experienced in............unless, he wants to learn a whole new method. That is what homebuilding is all about, learning. Its all fun, most find the building just as much fun as the actual flying.
All good points.........
Sid
It's going back a few years, but the original Hawker Hurricane was a 300mph tube and fabric airplane
If there is a must-read for the first time buider, Ron Wantajja's book is a strong candidate. The only problem might be that by the time you're done reading it, you may not only be considering pro/con tube and fabric vs aluminum, but composite and even wood too.
http://forums.matronics.com/viewtopic.php?p=67270#67270
< Download, 7-Day Browse, -> _p; --> ht &nbnics.com/" bsp; -Matt Drcs.com/contribution" target=_blank>http://www.matronics.com/contribution<=============
| | - The Matronics Homebuilt-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?Homebuilt-List |
