tonybabb(at)alejandra.net Guest
Posted: Mon Oct 09, 2006 3:33 pm Post subject: FAA Part 91.205 |
Hello OC,
I'd appreciate a copy of the table you mentioned
<SNIP>
Because this subject is a bit convoluted I have put together a table that
lays the information out in fairly compact reference form. I will send you a
copy of this table attached to a separate email. If anyone else would like a
copy just email me. This table was also published on page 50 of the June
2006 issue of Kitplanes magazine.
<SNIP>
Tony Babb
Velocity SEFG 62% done, 78% to go
www.alejandra.net/velocity
khorton01(at)rogers.com Guest
Posted: Mon Oct 09, 2006 4:27 pm Post subject: FAA Part 91.205 |
I was wondering if you could clearify FAA Part 91.205 for me. As I
understand this FAR it applies to powered civil aircraft with a
standard
category U.S. airworthiness certificate. Is our experimental
airworthiness
certificate under this catagory? It requires a manifold pressure
gauge for
each altitude engine. It does not require a CHT or EGT. This does
not
seem right for experimental aircraft. I would much rather have a
CHT and
EGT than a manifold pressure gauge although I have all three on my
KIS. I
was also wondering if my VFR day only plane needs to have a strobe
and nav
lights?
The reference to an "altitude engine" requires a study of FAR 1.1 to
see that it means "a reciprocating aircraft engine having a rated
takeoff power that is producible from sea level to an established
higher altitude." I.e. it means a turbo-charged or super-charged
engine. Anyone who has such an engine really should have a MP gauge,
whether FAR 91.205 applies to them or not.
Kevin Horton
Ottawa, Canada
