Troy Maynor
Posted: Tue Jan 24, 2006 3:26 pm Post subject: Classics with Skydrive |
"Justin Kennedy" <Justin(at)systemwise.co.uk> wrote:
<<<Our Rotax 912S also has a Skydrive carb heater so I was interested to
hear his take on the
subject. His rule of thumb was to cruise at 90-100 degrees CHT and
100-110 degrees Oil Temp.>>>>
Hi Justin,
As a side issue, did you have any problem with the Skydrive heater causing
the carbs to sit too far aft. I have a Classic cowl and engine mount and
wish to install the Skydrive heaters as well. I have the cold air induction
mod with the rectangular filter box. The filter box is not very far from the
firewall now. If I add the skydrive carb heat mod will I have enough room? I
don't want the air filter box to be hitting the firewall when the engine
shakes during start and shut down. Do you or anyone else see a problem here?
Thanks to all.
Troy Maynor
N120EU Europa Monowheel Classic
Left to finish:
Paint,interior,engine install, wiring.
Weaverville, NC USA
ward.t(at)xtra.co.nz Guest
Posted: Tue Jan 24, 2006 5:48 pm Post subject: Classics with Skydrive |
Troy,
I had no problem regarding space (Monowheel Classic) for the Skydrive carb
heater.The 'cold air induction
mod' I presume is the plenum air chamber that Europa supplied. My plenum
air chamber
is right up against the firewall, not connected, but is secured to the
engine mount (part connected to the engine and not the fuselage) with a 'U'
bolt
coming up through the plenum air chamber.(Peter Davies invention) This then
vibrates with the engine if necessary)
Tim
Tim Ward
12 Waiwetu Street,
Fendalton,
Christchurch, 8005
New Zealand.
Ph +64 3 3515166
Mobile 021 0640221
