914 OIL PRESSURE
SPurpura(at)aol.com
PostPosted: Sun Oct 08, 2006 2:40 pm    Post subject: 914 OIL PRESSURE Reply with quote
Any rotax drivers out there ever experience high oil pressures in cruise flght?Today my oil pressure was in the 97-99 psi. range,changing power/prop setting had no effect,engine ran fine & all temps normal.
Gilles.Thesee(at)ac-greno
PostPosted: Sun Oct 08, 2006 2:50 pm    Post subject: 914 OIL PRESSURE Reply with quote
temps normal.
I'd check the sender (gauge, wiring...). They are subject to much
vibration and radiated heat. We changed ours twice, and are considering
installing it remote.
Gilles Thesee
Grenoble, France
http://contrails.free.fr
grahamsingleton(at)btinte
PostPosted: Sun Oct 08, 2006 4:21 pm    Post subject: 914 OIL PRESSURE Reply with quote
Gilles
standard practice with Lycosaurus is to install the sender remote for
that reason. Can't see why Rotax don;t specify remote, what do they do
on certified 91x installations?
Graham
Gilles Thesee wrote:
<Gilles.Thesee(at)ac-grenoble.fr>
> temps normal.
considering installing it remote.
Gilles Thesee
PostPosted: Mon Oct 09, 2006 2:37 am    Post subject: 914 OIL PRESSURE Reply with quote
Graham
that reason.
Yes
Can't see why Rotax don;t specify remote, what do they do on certified
91x installations?
I must say that the low cost VDO sender seems far more reliable than the
two units we got from UMA. The UMA failed, and we had to resort to a VDO
sender+gauge as a temporary fix.
Gilles Thesee
Grenoble, France
rparigor(at)suffolk.lib.n
PostPosted: Mon Oct 09, 2006 9:10 am    Post subject: 914 OIL PRESSURE Reply with quote
Hello Gilles
"The UMA failed, and we had to resort to a VDO sender+gauge as a temporary
fix."
What is exact wrong with using the VDO as a permanent fix??
Ron Parigoris
davidjoyce(at)doctors.org
PostPosted: Mon Oct 09, 2006 9:23 am    Post subject: 914 OIL PRESSURE Reply with quote
Have twice experienced this sort of problem. The first time showed pressures
in excess of 6 bar , which is the Flydat alarm level. It turned out that one
wire had come loose at the sender, and fixing it gave normal pressures
again. Two years later I had an episode of pressures creeping up again and
cleaning the terminals on the sender sorted it. Regards, David Joyce G-XSDJ
PostPosted: Mon Oct 09, 2006 10:30 am    Post subject: 914 OIL PRESSURE Reply with quote
Hi Ron,
fix."
The VDO sender is not compatible with our 270°, red and green-arc UMA
gauge http://contrails.free.fr/images/DSCF1622.JPG
Using the VDO sender, we must use the 90° swing, smaller diameter,
black-rim VDO gauge. In our area, those gauges are used on mopeds and
lawn-tractors....Wink
You can see the temporary gauge on the frontispice at
http://contrails.free.fr/instruments_tableau_phif.php
Best regards,
Gilles
kpaviat(at)verizon.net
PostPosted: Mon Oct 09, 2006 2:52 pm    Post subject: 914 OIL PRESSURE Reply with quote
Hi Sam! This is typical problem when the sender fails. I like the idea about mounting the sender remotely to avoid the high frequency vibrations where the sender is on the engine. The newer senders have the heavy bronze ring to damp this problem but it is usually only a matter of time before failure. Good Luck!
kp [quote][b]
PostPosted: Mon Oct 09, 2006 3:50 pm    Post subject: 914 OIL PRESSURE Reply with quote
Listen to this guy, He has a lot of experience, 2 generations of it in fact!
Graham
kp
jodel(at)nildram.co.uk
PostPosted: Tue Oct 10, 2006 6:51 am    Post subject: 914 OIL PRESSURE Reply with quote
I looked at a CofA Tecnam in our hangar today. The sender is mounted direct
to the engine as normal.
Simon
peterz(at)zutrasoft.com
PostPosted: Tue Oct 10, 2006 7:48 am    Post subject: 914 OIL PRESSURE Reply with quote
... and was also a common problem (symptom = false high oil pressure) on the cert'd Kanata I trained on.
PostPosted: Tue Oct 10, 2006 8:35 am    Post subject: 914 OIL PRESSURE Reply with quote
For what it's worth, I talked to Ed from UMA, and they use VDO senders for
most of their oil pressure instruments (except perhaps the electronic),
the part number would include a "V" in it.
Anyway he said they are troublesome if mounted on the motor. He recommends
remote mounting, and using a .015" or .010" restrictor close to the
engine.
He likes .010" but OP will take a while to build upon first start up.
Ron Parigoris
PostPosted: Tue Oct 10, 2006 10:18 am    Post subject: 914 OIL PRESSURE Reply with quote
Ron
that approach sounds sensible to me
Graham
engine.
Ron Parigoris
SPurpura(at)aol.com
PostPosted: Tue Oct 10, 2006 3:26 pm    Post subject: 914 OIL PRESSURE Reply with quote
I found the Rotax replacement part priced at $220.00 a bit ridiculus for an automotive sensor.NAPA auto parts catalog has a oil pressure sending unit for marine applications,several similar to choose from,(single wire,120psi & 1/8" pipe threads) for $18.00,so I ordered 1.
I'll post how it came out.
PostPosted: Tue Oct 10, 2006 4:18 pm    Post subject: 914 OIL PRESSURE Reply with quote
Have a good search round for the right fittings to connect it. It should
be easy but they do tend to put obstacles in your way!
Graham
PostPosted: Wed Oct 11, 2006 7:39 am    Post subject: 914 OIL PRESSURE Reply with quote
Amazing how much that bronze ring costs!!
I got my replacements from a VW supplier at a reasonable cost. Anyway, the next time my sensor fails I’m mounting it remotely...
kp [quote][b]
acrojim(at)cfl.rr.com
PostPosted: Wed Oct 11, 2006 4:31 pm    Post subject: 914 OIL PRESSURE Reply with quote
I know that some of the early Katana's had a Service Bulletin or AD to move the oil pressure sender from the engine to the firewall, and to hook it up with flexible hose.
The oil pressure sender is just not happy mounted on the engine.
Jim Brown
ami(at)mcfadyean.freeserv
PostPosted: Thu Oct 12, 2006 12:10 am    Post subject: 914 OIL PRESSURE Reply with quote
Or transfer the 'bronze' ring; it's only glued on!
Duncan Mcf.
