FLYaDIVE(at)aol.com Guest
Posted: Fri Oct 06, 2006 9:03 am Post subject: Roll Trim - RV-6A |
Hey Group:
I have been fighting with trimming out the unwanted roll to the right of an RV-6A. Things I have done:
1 - Installed the center mounted manual trim. That worked for a while but seems the springs or hook up wire has stretched and the plane is back to doing rolls.
2 - I found the flaps to be out of trim when in the FULL UP position. By giving them the slightest blip of down the roll rate decreases about 75%. I also do not notice any change in IAS.
I found the flap problem when taking measurements while the plane was bubble level on the ground. One flap pulls UP just a bit more than the other.
So, I am now thinking about trim tabs on the ailerons. I heard about using a seam tool to squeeze the trailing edge. But, other than hearing about it I have not read about it. Also, this seems like a permanent action, no means to correct if over done.
I would appreciate to hear about your experience and cures.
Thank you,
Barry
"Chop'd Liver"
sbuc(at)hiwaay.net Guest
Posted: Fri Oct 06, 2006 9:41 am Post subject: Roll Trim - RV-6A |
FLYaDIVE(at)aol.com wrote:
<snip>
| Quote: | So, I am now thinking about trim tabs on the ailerons. I heard about using a
A search on "squeezing & aileron" (leave off the quotes) on the
Matronics search engine yielded 103 hits on this very frequently and
extensively discussed topic:
http://www.matronics.com/searching/search.html
Sam Buchanan
Posted: Sat Oct 07, 2006 12:16 am Post subject: Roll Trim - RV-6A |
Sam:
Thank you for the information and the link, I'll try it.
Barry
