nuckollsr(at)cox.net Guest
Posted: Wed Oct 04, 2006 9:41 am Post subject: Coax Crimp tools |
At 11:19 AM 10/4/2006 -0500, you wrote:
<frank.hinde(at)hp.com>
Radioshack also has one for 11 bucks
Frank
I think the 'low cost' coax tool at RS is for television
"F" connectors. They also list a tool with hex dies and
a "small" hole for about $18.00
See http://tinyurl.com/jbn46
For MOST of the RG-58/RG-400 connectors out there you
need a reasonably accurate .213" hex die (shield sleeve)
and a .068" square or hex die (center pin). I've
encountered tools that were properly marked but in
fact were slightly over or under-sized and didn't
produce the desired crimp.
You can take a pair of calipers with you to the store
http://tinyurl.com/8b18 and check the tool before you
buy it. Go for .213" minus .000" plus .001" and
.068" plus/minus .001"
These tools are made and offered by dozens of folks
from all walks of technology and while most are pretty
good, you don't want to find one that's not so good
AFTER you've bought the tool and are needing to FINISH
the job.
frank.hinde(at)hp.com Guest
Posted: Wed Oct 04, 2006 10:13 am Post subject: Coax Crimp tools |
Good point. The Radioshack deal is in fact listed for RG58 and appeared
to work very well.
FWIW
Frank
FLYaDIVE(at)aol.com Guest
Posted: Thu Oct 05, 2006 3:55 pm Post subject: Coax Crimp tools |
In a message dated 10/4/06 1:46:08 PM Eastern Daylight Time,
nuckollsr(at)cox.net writes:
| Quote: | I think the 'low cost' coax tool at RS is for television
the job.
Listen to what Bob says!
Or you can simply use the soldering pencil you already have.
And the wrench already in your tool box.
And not have to worry or bring a caliper to the store.
And not have to drive to the store.
And save the gas for the plane.
AND learn the simple task of how to make a moisture protected wrench and
solder BNC.
Guad, I love being old school. I don't have to learn new ways to do old
thing and reinvent the wheel.
Kisses Bob
Barry
"Chop'd Liver"
"Show them the first time, correct them the second time, kick them the third
time."
Yamashiada
