hugo rv10
gommone7(at)bellsouth.net
PostPosted: Wed Oct 04, 2006 7:21 am    Post subject: hugo rv10 Reply with quote
Hi all,still with antennas questions,
almost everybody suggest to use rg400u coaxial cable ,good, i ordered,now the choice in the usual catalogs have a very restricted choice of BNC connectors (only one tipe )will fit the RG 400,and can't be solder,ok order allready the 70 dol crimping tool.but still one part missing wich is a metal sleeve wich slide over the conection and allow to be crimped,if I'm rigth ,no body sale thats sleeve,can some one help me to understand or a place to order the part.
thanks ,and sorry for my lack of knoledge in electrical systems
Hugo
klehman(at)albedo.net
PostPosted: Wed Oct 04, 2006 7:48 am    Post subject: hugo rv10 Reply with quote
Hi Hugo
The steinair website may help you.
http://steinair.com/connectors.htm
I believe that any connector that fits RG-58 will fit RG400 and I used a
$20. imported crimper that worked fine for me.
Ken L.
Hugo
nuckollsr(at)cox.net
PostPosted: Wed Oct 04, 2006 8:16 am    Post subject: hugo rv10 Reply with quote
Ken is correct. Dimensionally, RG-58 and RG400 are close enough
to use the same connectors and application tools. The only 'catch'
is to get your 'cheap' tool and connectors from the same supplier . . .
presumably, like me, they'll make sure that their connectors are
compatible with their tools. It's a rare problem but NOT zero risk.
Alternatively, one can purchase mil-spec connectors and tools from
anyone with a high expectation for mix-n-match between tools and
connectors.
At 11:48 AM 10/4/2006 -0400, you wrote:
Hi Hugo
Ken L.
>Hugo
-- incoming mail is certified Virus Free.
Checked by AVG Anti-Virus.
< with experiment. >
< --Lawrence M. Krauss >
frank.hinde(at)hp.com
PostPosted: Wed Oct 04, 2006 8:19 am    Post subject: hugo rv10 Reply with quote
Radioshack also has one for 11 bucks
Frank
PostPosted: Wed Oct 04, 2006 9:36 am    Post subject: hugo rv10 Reply with quote
Thanka at all.
hugo
Thanka at all.
hugo
PostPosted: Wed Oct 04, 2006 3:07 pm    Post subject: hugo rv10 Reply with quote
Thanks again for the answer,but personaly never purchase cheap tools,use few times but allways do perfect job.
Now my next question.
ELT antenna,in a 180knots airplane I thinks a flexible spring antenna will be out of question ,I belive can't be mount inside an a aluminum plane,I found a spot under the vertical stabilizer ,the 10 use a thin fiberglass fairing,what you guys thinks will work?,.eventualy need to work only one time,in a shallow accidents probably don't needed but in a bad one ,the the antenna will be pointing up and almost at the highest point,(sorry for the humor)
here the pictures ,
thanks again ,Hugo
 Filesize:  31.95 KB
 Viewed:  361 Time(s)
 Filesize:  28.33 KB
 Viewed:  405 Time(s)
