gcrowder2
Joined: 09 Jan 2006 Posts: 136 Location: Golden, Colorado USA
Posted: Tue Oct 03, 2006 3:31 pm Post subject: 200hp EA81 now on website |
The Ram Engines 200 hp EA81 is now on Rams website. I have been in email
contact
with the San Diego builder who is installing this engine in a Europa mono
planning out his
cooling system. This engine is only running 6 lbs boost with the Rotrex
supercharger and does not need an intercooler. Thats good because I have no
idea where you would put one in the
Europa!
At cruise rpm (4600), rated power is 148 hp and 156 ft/lb torque. 200hp
and 210 ft/lb
torque at 6000 rpm. Total weight claimed is 155 lbs, thats without exhaust,
cooling system or redrive. Ron uses Rotrex's smallest charger at 6.4 lbs!
This will probably swing something like
a 64 x 74 3 blade I'm guessing. I'm thinking climb rate should exceed 2500
fpm at sea level!
I have Ron starting on a new dual port 150 hp NA engine that will have a
complete roller
cam and rockers that will run on pump gas or 100LL. A complete roller cam
setup should be
good for 15 hp over my current regrind cam with no more heat generated.
This will use the
RWS redundant fuel injection with dual ECU's. I want to use an Ellison
Model 3 TBI as the
throttle plate with the fuel still attached to the TBI so in an emergency, I
can shut down
the MPFI injection and switch to the Ellison for a complete standby fuel
system.
I will retain the dual Electroair ignitions that I have now as they have
been faultless. I have a dual battery system with fault detection that
switches over automatically in case of low or high
voltage. Thats the plan till next week when it will change again!
Glenn
Posted: Tue Oct 03, 2006 4:41 pm Post subject: 200hp EA81 now on website |
Glenn,
As I recall, you bought your plane in flying condition with a custom
cowl (of unknown origin)...What's the guy in San Diego going to use for
a cowling, motor mount, redrive? Who is he, or will his name remain a
mystery?
Fred
A194
On Tuesday, October 3, 2006, at 04:30 PM, GLENN CROWDER wrote:
<gcrowder2(at)hotmail.com>
email contact
mono planning out his
cooling system.
Glenn
gcrowder2
Posted: Tue Oct 03, 2006 6:37 pm Post subject: 200hp EA81 now on website |
Hey Fred! The builder has not been on the list. I can check with him if
you would like to
contact him. He has the standard XS cowlings that he will have to modify
somewhat to add a cooling scoop. He is using the Marcotte M150 drive, same
as the one I'm using and very happy with. I think he's planning on a Catto
prop. I have a 9" x 12" custom rad with two rows of
one inch tubes. I think he will need three or four rows to keep that beast
cool! I am sending him my motor mount welding jig so he will be able to do
a mount similiar to mine.
The original NSI mount with my engine was scary! My new one is 5/8" od
.049 wall which
everyone thinks is very stout. Cheers!
Glenn
| Quote: | From: Fred Klein <fklein(at)orcasonline.com>
Reply-To: europa-list(at)matronics.com
Subject: Re: 200hp EA81 now on website
Date: Tue, 3 Oct 2006 17:40:34 -0700
Glenn,
As I recall, you bought your plane in flying condition with a custom cowl
(of unknown origin)...What's the guy in San Diego going to use for a
mystery?
Fred
A194
>email contact
>planning out his
>cooling system.
>Glenn
